Old May 14, 2002, 02:18 PM
Helibee is offline
Find More Posts by Helibee
Wisconsin, USA
Joined Jan 2001
Weight/Loading differences between LT40 and Kadet Senior
Topic says it all. I learned on a Senior and have decided to build another, but wondering about a comparison in weight and loading. TIA, Todd
Helibee is offline Find More Posts by Helibee
Old May 14, 2002, 07:34 PM
Dsegal is offline
Find More Posts by Dsegal
Dave Segal
Philadelphia PA USA
Joined Jun 2001
I can offer a comparison that may be of some use if you look at the smaller Sig trainers as I built both the Seniorita and the LT-25.
The Seniorita wing area is 746 sq.in., weight complete (taildragger) 61 oz. for a wing loading of 11.8 oz./sf. The LT-25 wing is 724 sq.in., weight 68 oz. with a loading of 13.5 oz/sf. Both planes had the same OS.25 engine and similar radio gear and covering material.
Now for the comments which you did not ask for. (G)
Both planes are fine fliers. The Seniorita is lovely to look at and the LT-25 is graceless. The Seniorita instructions are hopelessly out of date (how to use silkspan, why to consider using a throttle!) and it is excessively complex in the cabin area. The LT-25 is a masterful redesign to take advantage of laser cutting technology which produces a marvelous light, strong, accurate wing and the instructions are excellent. As you are experienced builder you can just take your choice. But I would steer any newcomer away from the Seniorita.
Dave Segal
Dsegal is offline Find More Posts by Dsegal
Discussion Kadet Senior Completion / Weight? CG? Rhathid Fuel Plane Talk 2 May 05, 2007 12:18 PM
Discussion weight differences between 18ga and 16ga wires cyclonite Power Systems 0 Nov 24, 2006 11:14 AM
What thrust line for twin Kadet Senior? temacc Sport Planes 13 Jul 21, 2001 10:02 AM
Kadet Senior ailerons? flaps? wesdjohn Electric Plane Talk 5 Jun 02, 2001 11:37 AM
Differences between DX motors vs. 280 atsiang Parkflyers 2 May 19, 2001 12:36 AM
