Old Oct 04, 2005, 12:12 AM
A_Langman is offline
Find More Posts by A_Langman
Joined Sep 2005
Rave
Scratch building a P-51 or Spitfire
Hi All,
I'd like to scratch build a P-51 or Spitfire. I have a bit of experience building models, however, I haven't built a scale warbird yet. I'd like to have a 60-80" wing span (I'd like to was a 90 size engine). I'd like help in two areas:
1) What are the best set of plans you have used to build a P-51 or a spitfire and where can I get them?
2) A "Techniques and tips for scratch building a model plane" web page or book or similar. I have not done a lot of curved work in balsa, so hints on "planking" and similar stuff would be good.
Many thanks,
Adam L
A_Langman is offline Find More Posts by A_Langman
Old Oct 04, 2005, 09:22 PM
Joined Sep 2005
any one?
Old Oct 04, 2005, 10:45 PM
hul is online now
hul
Find More Posts by hul
hul
hul's Avatar
Switzerland
Joined Mar 2003
are you after a plan or a 3-view to make your own plans?
There are lots of plans on the Profili website: www.profili2.com, probably none in the size you want, but scaling is easy.
Have a look at the Spitfire by Dave Philpotts. There are a few build threads for this plane, not many actually flew though.
Some 3-views here: http://www.airwar.ru/other/drawe.html
Planking isn't hard for mildly curved surfaces (most of the typical fuselage). Three dimensional shapes can be strip planked: http://www.modelairplanenews.com/how...rip_plank1.asp
Read all the build threads you can find and learn as much as you can from them.
Hans
hul is online now Find More Posts by hul
Old Oct 04, 2005, 10:59 PM
Joined Sep 2005
Hi Hul,
Thanks for the reply I'm looking for full plans (ie an outline of all the parts required to be cut, assembly instructions etc)
Thanks for the link to the construction page. I'll read all I can before starting.
I have decided on the P-51. I'm keen to put a dropable bomb under her
Cheers,
Adam L
Old Oct 05, 2005, 12:40 AM
hul is online now
hul
hul
hul's Avatar
Switzerland
Joined Mar 2003
don't think there are many plans of that size for electric planes. You'll probably have to use glow plans and redesign them to make them lighter and to fit the batteries. Or scale a smaller electric plan up to the size you want.
http://www.rcscalebuilder.com/ has forums for each of the major scale plane designers.
69" P-51D here: http://www.bhplans.com/bt2.htm
These articles may be interesting too:
http://members.aol.com/kmyersefo/page3.htm#TOP
http://members.aol.com/kmyersefo/page37.htm#TOP
Hans
Old Oct 05, 2005, 11:05 AM
thomanie is offline
Find More Posts by thomanie
thomanie's Avatar
Trondheim, Norway
Joined Jun 2003
150% Rittinger design?
You could perhaps send Mark Rittinger (mrittinger) a PM and ask him nicely for a ~150% version of his excellent P-51 plan? 150% size would give 60" WS.
It's not 100% Top Gun scale, but close enough They are pretty easy builds, and yield a magnificent looking and great flying bird! Wing and stab both have scale outlines, but the fuselage has been slimmed somewhat. You can check out the 100% version in the Old Crow build thread I did here in the scale forum.
...just my 2cents
Thomas
thomanie is offline Find More Posts by thomanie
Old Oct 05, 2005, 04:51 PM
Chad Veich is online now
Find More Posts by Chad Veich
Scale Builder
United States, AZ, Litchfield Park
Joined Jul 2002
Adam, you say you would like to use a 90 size engine so I am going to assume you mean glow and not electric power. This is the electric forum you have posted in which may explain the lack of response. Bob Holman Plans can supply you with several plans/accessory options for the Spit and Mustang within the size range you are looking for. He has a web site, www.bhplans.com, but it does not show anywhere near all that he has available. Give him a call and order his catalogs, you won't be dissapointed.
Chad Veich is online now Find More Posts by Chad Veich
Old Oct 05, 2005, 05:02 PM
markmm is offline
Find More Posts by markmm
Joined Jul 2005
...just my 2cents
Thomas
I have tons of P51 plans and most, if not all, are terribly off scale (and I mean really way off). Mark Rittinger's plans are about the closest I've seen to scale (as far as shape and look). You might want to alter his plans somewhat depending on how scale you want it to be. Mark, I think altered his plans just a bit on the nose, but they look quite good.
The P51 is my favorite plane, much less warbird, and if you need any info I have a lot to share...including an authentic 1945 P51 parts catalog that shows exploded assembly drawings of every single part, right down to every gauge and bolt. Just let me know and I'll try to help.
markmm is offline Find More Posts by markmm
Old Oct 05, 2005, 07:19 PM
Scale Builder
Joined Jul 2002
If you're talking electric, then I suppose you are right. However, if you are talking Mustang plans in general, Brian Taylor, Doss Steed, Jim Meister (Master Scale), and Dave Platt have all done good Mustang plans. Yes, I'm sure all have errors, but these are darn good.
Old Oct 05, 2005, 10:29 PM
Joined Sep 2005
Hi All,
Many thanks for the replies. To stop further confusion, I had intended the model to be glow powered. I apologise for posting it in the electric section. May be this thread should be moved?
Sorry all.
However, I'm starting to lean towards a Bob Holman kit. I had intended to totaly scratch build, but since it would be the first really large plane that I've built, may be a basic kit is a good start.....
Thanks you all
Cheers,
Adam L
Old Oct 06, 2005, 07:58 AM
markmm is offline
Joined Jul 2005
Of course, yes I'm talking electric. If you go over to http://www.rcscalebuilder.com/forum/ you'll see lots of excellent P51 scale builds from plans that are quite large. There are some awesome P51 builds over there...truly amazing!!!
Dave Platt's look very interesting indeed.
Adam, If you want some detail information or photos of certain areas, let me know. The offer to share still stands.
Old Feb 08, 2010, 06:47 PM
daveweagel is offline
Find More Posts by daveweagel
Joined Aug 2007
re: doss stead p-51
markm,
do you know of any photos and or a construction article describing a p-51 build using the doss steed plans ?
was there an actual flying model built from these plans ?
are these plans still available ?
as i recall, bob holman sold the steed plans at one time. very expensive but supposedly the best available in terms of accurate scale detail.
the best P-51 B-C plan i ever saw was the M.C. BEAULIEU's "shang ri la"
the best P-51 D plan i've seen was DAVE PLATT's rendering.
thank you,
dave
thank you,
dave
daveweagel is offline Find More Posts by daveweagel
Old Feb 08, 2010, 07:28 PM
WTFLYR is offline
Find More Posts by WTFLYR
WTFLYR's Avatar
West Central PA
Joined Dec 2008
If you're like me and don't want to invest in plans, you may be able to find a Guillows or other scanned design, and enlarge. I'd send you mine if you were serious about building it, but I already sent them to a guy here who never built from them.
This 300% Guillows build looks nice:
http://www.rcgroups.com/forums/showp...8&postcount=11
WTFLYR is offline Find More Posts by WTFLYR
Old Feb 08, 2010, 09:25 PM
Xanadu is offline
Find More Posts by Xanadu
Xanadu's Avatar
Canada, MB, Winnipeg
Joined Nov 2006
Like this?
Xanadu is offline Find More Posts by Xanadu
Discussion Scratch building a p-51 jwims01 Glow to Electric Conversions 2 Mar 15, 2007 02:26 AM
Anyone converted Kyosho P-51D or Spitfire? PortAh Scale Kit/Scratch Built 9 Dec 21, 2004 06:14 PM
Alfa P-51 or FS Spitfire?? jimflint80 Parkflyers 6 Jun 03, 2003 01:45 PM
Hobby Lobby's P-51 and/or corsair denverone Foamies (Kits) 3 Jul 11, 2002 06:47 PM
Ace Simple P-51 or Extra, etc anyone electrified these? NewbieX Electric Plane Talk 4 Apr 22, 2001 05:24 PM
