Old Oct 03, 2005, 11:49 AM
rdeis is offline
Find More Posts by rdeis
AMA 353531
rdeis's Avatar
United States, CO, Colorado Springs
Joined Aug 2003
What prop? 7.2V 2 cell direct drive
Or, perhaps the better question would be what motor?
I'm running the stock brushed 7.2V speed-400 with a 6.6x3 graupner folder and 2 cells lipo in my Ascent.
The performance is adequate, really, but the efficiency stinks and the motor gets quite hot. If I can keep similar performance numbers but get either a lighter or more efficient combination I'd be much happier. (Especially if I could go lighter, this thing is seriously nose-heavy...)
Constraints are:
1> Gotta stay brushed
2> Probably has to stay direct drive- the shape of the nose would require a planetary box and I don't want that weight or expense.
3> 2 Cells lipo and max of 10 or 11 amps
Is there something better than what I'm using?
rdeis is offline Find More Posts by rdeis
Old Oct 03, 2005, 11:58 AM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
Ask Vintage, but a Long Can 400 might do well - though you probably need 3s to get the most from it.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Oct 03, 2005, 12:35 PM
rdeis is offline
AMA 353531
rdeis's Avatar
Joined Aug 2003
Which makes 2 increases in weight. Bummer.
The brantuas calculator suggests that a speed-300 and 4.5x2.7 give similar results to what I have now, a hair more thrust and a little less pitch speed. 10 amps, though, which probably cooks a speed 300, doesn't it...
Question What is the Amp draw of 180 brushed motor DD with 5030 prop running on 2 cell lipo? hklam Power Systems 0 Mar 01, 2007 01:13 AM
brushed motor choice for 35amp 6 cell/direct drive? mattk17 Power Systems 4 Dec 02, 2004 11:14 PM
Dedicated Thread for Mega 16/15/7 motor used in a Direct Drive Capacity Michael Heer Power Systems 15 Mar 29, 2004 03:14 AM
Slowstick with 7.2 S400 Direct Drive, will it fly? flipnidaho Parkflyers 7 Sep 01, 2003 01:00 PM
Mega 16/15/7 on 2 cell 1200 E-Tec? Christo Power Systems 5 Jun 09, 2003 11:01 AM
