Old Oct 02, 2005, 08:39 PM
GGRN is offline
Find More Posts by GGRN
One eyed Corsair
GGRN's Avatar
PARIS
Joined Jul 2005
Build Log
Dassault Super Etendard build thread
This new thread about an exotic jet (for U.S), the Dassault Super Etendard.
They served in French Navy since 1978, and bombed Bekaa in Lebanon in 1983, Yugoslavia and Bosnia during the 90's, and now Talibans in Afganistan.
Of course, they served gloriously in Argentina's Navy during the Falklands War when they sank destroyer HMS Sheffield and freighter Atlantic Conveyor With Exocet missiles.
This little parkjet, powered with feigao 4100kv and 3 cells lipo 700 or 850mA, is entirely depron made
Let's see how to build it ; pics are better than speaking...
Link to video :
http://www.rcgroups.com/forums/showthread.php?t=485085
Link to plans :
http://www.parkjets.com/etendard.html
GGRN is offline Find More Posts by GGRN
Old Oct 02, 2005, 09:08 PM
GGRN is offline
One eyed Corsair
GGRN's Avatar
PARIS
Joined Jul 2005
Some specs :
Length : 785 mm / 30,9"
Wingspan : 575 mm / 22;6"
Weight : +:- 220g / 7,74oz
Radio : 3 servos (2 for ailerons, 1 for elev)
Building rear fuselage : -Glue formers on the bottom view of mid fuselage (cut out of 3mm depron)
-Glue the sheet (3mm bent depron) on formers.
Old Oct 02, 2005, 09:23 PM
Tanguy&Laverdure is offline
Find More Posts by Tanguy&Laverdure
France
Joined Aug 2005
Interesting project! I like it. Are you also planning to add the 'hook' under the fuselage to make the landing shorter? Imagine you land the plane on a ping-pong table like on a carrier!
Tanguy&Laverdure is offline Find More Posts by Tanguy&Laverdure
Old Oct 02, 2005, 09:31 PM
GGRN is offline
One eyed Corsair
GGRN's Avatar
PARIS
Joined Jul 2005
Rear bottom fuselage
Old Oct 02, 2005, 09:41 PM
GGRN is offline
One eyed Corsair
GGRN's Avatar
PARIS
Joined Jul 2005
Then, glue formers of top fuse on the other side and assemble elev. servo.
At the same time you glue the fuse up sheet, cut depron from the view of mid fuse and formers for lightness.
Old Oct 02, 2005, 09:45 PM
GGRN is offline
One eyed Corsair
GGRN's Avatar
PARIS
Joined Jul 2005
Arresting hook
I tested it for you on my Breguet 1050 Alizé, but it was not to land on table-tennis.
Old Oct 02, 2005, 09:55 PM
GGRN is offline
One eyed Corsair
GGRN's Avatar
PARIS
Joined Jul 2005
Tail cone will be ende later, just after glueing fin.
Fin is cut out of 6mm depron. Mechanism for elevator is made of 0,4 and 1mm plywood.
Old Oct 02, 2005, 10:03 PM
GGRN is offline
One eyed Corsair
GGRN's Avatar
PARIS
Joined Jul 2005
Elevator : Depron 3mm, balsa 3mm and 0,4mm plywood. In fact, light 3 mm balsa is better for the elev.
Old Oct 02, 2005, 10:09 PM
GGRN is offline
One eyed Corsair
GGRN's Avatar
PARIS
Joined Jul 2005
Nose :
Glue parts of 6mm depron and sand...
Old Oct 02, 2005, 10:11 PM
GGRN is offline
One eyed Corsair
GGRN's Avatar
PARIS
Joined Jul 2005
double post
Old Oct 02, 2005, 10:12 PM
GGRN is offline
One eyed Corsair
GGRN's Avatar
PARIS
Joined Jul 2005
...And glue the nose on rear fuselage.
Old Oct 02, 2005, 10:21 PM
Hawker is offline
Find More Posts by Hawker
Fly Brushless!
Hawker's Avatar
Las Vegas
Joined Aug 2002
Philippe,
Wow, looks great!
Did you build all that in one day?
Hawker is offline Find More Posts by Hawker
Old Oct 02, 2005, 10:23 PM
GGRN is offline
One eyed Corsair
GGRN's Avatar
PARIS
Joined Jul 2005
Wings :
Cut intrados and extrados out of 3mm depron.
Glue 2mm balsa spar on the intrados and then the extrados.
Old Oct 02, 2005, 10:33 PM
GGRN is offline
One eyed Corsair
GGRN's Avatar
PARIS
Joined Jul 2005
Hi, Pete
No it was built in 3 ...evenings because i often work during the night i was in the Army before (Firemen of Paris) and i get used not to sleep a lot. It's the same thing in my new job, in the Senate...
Now, it's 4 AM...
Thanks for compliments.
Greetings from Paris
Philippe.
Old Oct 02, 2005, 10:38 PM
im-sad is offline
Find More Posts by im-sad
Or am I...
Bournemouth, Dorset, UK
Joined Jan 2005
OOOOOOHHH I love the S.entendard. will there be plans??
im-sad is offline Find More Posts by im-sad
Gallery Dynaflite Super Decathlon build thread tomerj Giant Scale Airplanes 142 Jan 03, 2014 01:33 PM
Mini-Review Page Aviation 40" Super Cub Build Thread Bill K. Scale Kit/Scratch Built 268 Sep 03, 2009 09:55 AM
Super Bandit Build Thread CBflyguy Pusher Prop Jet Models 20 Dec 10, 2005 10:12 PM
ultimate series super hornet build thread 6mmflyrc.com jazsop Pusher Prop Jet Models 0 Nov 05, 2005 10:32 AM
Laird Super Solution Build Thread! boomerace Parkflyers 178 Oct 29, 2003 08:20 PM
