Old Sep 30, 2005, 02:11 AM
fxdcon1@aol.com
fxdcon1@aol.com
Guest
n/a Posts
dual voltage - 12v dc motors and 6 volt servo..Please help
I am attempting to control 6 volt servos and 12 volt dc motors with a
hitech 6 channel transmitter modified for ground with a hitech
receiver. How can I control the motors with 12 volts and the servos
with 6 volts with one transmitter? The speed controller does not have a
BEC. Please try to keep it simple. Thanks!!
Old Oct 01, 2005, 06:11 AM
TA02
TA02
Guest
n/a Posts
Re: dual voltage - 12v dc motors and 6 volt servo..Please help
On 9/29/05 10:24 PM, in article
1128047082.887927.134850@g43g2000cwa.googlegroups. com, "fxdcon1@aol.com"
Key words here are "voltage regulator". I am sure you can find on of those
car lighter to multiple voltage regulators. Either find a used one or a
cheap one that gives you 6 volts and remove the electronics from the
cigarette lighter shaped casing. My local surplus electronics store has tons
of them for under 10$.
The other option is to make yourself one with a 7812 regulator chip.
Radioshack(the Source) used to have them on the rack and they had the
schematic right on the back page showing a typical setup.
TA02
Miniature Lathes and Millings
http://clisby.macphreak.com
Old Oct 03, 2005, 02:11 PM
Techpriest
Techpriest
Guest
n/a Posts
Just throwing out another option. You could use a battery pack to
power the electronics. I paid less then $20 for a good NIMH pack for a
nitro truck.
Pros: Plug and play, no soldering or fancy wiring. Can use still
electronics when primary battery fails.
Cons: Added weight. Another battery to charge. Space considerations
possibly.
Discussion Dc-10 Profile Aircraft Guy Please Help FEDEXDC10 Foamy EDFs 5 Jun 15, 2006 09:09 PM
Question high esc current=burned micro servo; please help me lostrider DIY Electronics 9 Aug 17, 2005 04:27 AM
Problem with HS-81 servo! Please help larsen2000 Electric Heli Talk 2 Oct 30, 2004 12:39 AM
Just ruined 2 motors and have pinion puller, please help cruzomatic Electric Plane Talk 4 Aug 03, 2002 11:17 PM
10 amp 250 volt fuse - please help locate towlebooth Power Systems 4 Oct 11, 2001 07:44 AM
