Old Sep 28, 2005, 01:01 AM
ronang is offline
Find More Posts by ronang
Singapore
Joined Oct 2003
Head speed of stock HB CP2 / Blade 3D
Has anyone measured the stock hovering headspeed of the HB CP2 / Blade 3D? I am trying to set up the heli with a Futaba 9CHP. I noticed that the blade tracking goes haywire when the headspeed changes and that the blades will track only at a certain speed. I guess that the stock speed must be that sweet spot.
ronang is offline Find More Posts by ronang
Old Sep 28, 2005, 10:29 AM
beemer is offline
Find More Posts by beemer
Seemed like a good idea!
beemer's Avatar
Bolton, Ontario, Canada
Joined Jun 2005
I just tested my Blade CP headspeed using a full contact tachometer. My Blade is completely stock except for heat sinks and sym woodie blades. Average headspeed for a 1 foot hover is 1380RPM. Maximum attained head speed, in idle up with neutral blade pitch was 2036 RPM.
I'm going to put on my flat bottom woodies (with the tips trimmed off) and see what the difference is. I'll post back shortly.
Edit: I forgot to mention that the flybar weights have been removed.
beemer is offline Find More Posts by beemer
Old Sep 28, 2005, 11:05 AM
beemer is offline
beemer's Avatar
Joined Jun 2005
With the flat bottom woodies (trimmed about 1/4" off the tips) it hovers at about 1300RPM.
Maximum headspeed was 1803RPM in idle up (neutral blade angle).
Hope this is what you were looking for.
Old Sep 28, 2005, 06:00 PM
ronang is offline
Singapore
Joined Oct 2003
Thanks Beemer,
That is exactly what I wanted to know. I noticed when settig up the heli with a Futaba that the blades only wanted to track at a certain RPM range.
Ron
Old Sep 28, 2005, 06:07 PM
beemer is offline
beemer's Avatar
Joined Jun 2005
You're welcome.
Old Oct 01, 2005, 01:09 PM
t.edwards is offline
Find More Posts by t.edwards
Joined Aug 2005
You got me curious so I checked headspeed, Blade Cp.
3s lipo
stock motor w/8t
flat bottom blades (new, no dingers)
seperates: pixie 7 & 20 escs, GY 240, JR 610, JR XP6102, DD tail
hovers @ 1870 rpm, hits 1980 rpm with pitch reduced.
Hope this helps, Tom
t.edwards is offline Find More Posts by t.edwards
Old Oct 01, 2005, 01:21 PM
ClarkOfKent is offline
Find More Posts by ClarkOfKent
ClarkOfKent's Avatar
Kent, Ohio
Joined Jun 2005
This is good timing.
I borrowed a tach, and I'm heading out to set up my BCP to use with my Optic 6.
ClarkOfKent is offline Find More Posts by ClarkOfKent
Question Do replacement HB CP2 Blade grips come with bearings included? elan Micro Helis 2 Apr 03, 2006 10:31 AM
For Sale FS: HB CP2/Blade CP Parts: Blades, CNC Head, and Tail Bundles probe3 Aircraft - Electric - Helis (FS/W) 2 Mar 20, 2006 09:22 PM
Discussion FS: HB CP2/Blade CP Parts: Blades, CNC Head, and Tail Bundles probe3 Micro Helis 0 Mar 20, 2006 12:50 PM
what should head speed and throtle curves for normal and 3d be on hornet 2 falcon41176 Micro Helis 8 Dec 20, 2004 02:48 PM
WTT: Stock HB Tail Blade for Main Rotor Head Yoke EddieNewYork Aircraft - Electric - Helis (FS/W) 0 Jul 20, 2004 11:47 PM
