Sep 27, 2005, 11:34 AM
Louisville KY
When the smaller battery begins to poop-out it's current output will begin to drop as if it's seeing a larger resistance at whatever voltage the larger battery can sustain. From the point of view of the smaller battery it doesn't know the larger battery is even there, all it knows is that the resistance is dropping at some voltage well above 3 volts per cell. .
The internal resistance of the 6c battery partly means it has a higher internal resistance that will throttle it so that it doesn't put-out as many amps as the 10C battery it's in parallel with, but you probably shouldn't bank on it, or as suggested, you might overheat it. Perhaps you might try a current output half way between the calculated ideal combination of the two batteries and twice the current capability of two times the smaller battery. This will take advantage of the throttling effect but be conservative, but do short runs at first and check the temperature of both batteries after every run. I always check my batteries to see how warm/hot they get anyway. I plan to try this myself at some point. I have a ammeter and will be able to compare the current sharing between the batteries.
POD
