Old Sep 25, 2005, 04:44 PM
Darx-starz is offline
Find More Posts by Darx-starz
Basingstoke Hampshire UK
Joined Sep 2005
Zoom 400:- How do I fit the Canopy so it does not fall off?
Ok so it flys now so I am trying to fit the Canopy. I can see 2 pins sticking out the side of the side frames. Trouble is its not that secure. It looks a bit better if I put the Fuse on top of the battery tray but creates a problem with battery placement.
How do you guys fit the canopy?
Darx-starz is offline Find More Posts by Darx-starz
Old Sep 25, 2005, 05:43 PM
TheX is offline
Find More Posts by TheX
Old new guy
TheX's Avatar
United States, TX, Austin
Joined Sep 2004
I used rare earth magnets. Glued one to each pin and the inside of the canopy. They are VERY strong and small. Not sure where you might find them but I got them at Radio Shack in the US.
TheX is offline Find More Posts by TheX
Old Sep 26, 2005, 01:17 PM
Minimole is offline
Find More Posts by Minimole
Sponsered By My Wallet!
Minimole's Avatar
Colwyn Bay, North Wales, UK
Joined May 2004
You should have some little pins pointing outwards below where the battery goes (underside of frame, near the LG), and there should be a rectangle cut out of the bottom canopy, which slides just above the pins.
Bit hard to explain, hope you understand.
Duane.
Minimole is offline Find More Posts by Minimole
Zoom 400, 'must do' Mods? Brill 1 Mini Helis 4 Aug 01, 2004 11:33 PM
New micron 400. How do you fit everything???? argarre High Performance 1 Jul 16, 2004 05:55 PM
How do I fit a new pinion gear on the IPS motor ? Gaz Power Systems 0 Mar 10, 2004 06:14 AM
How do you make Hornet gear not wobble? Terkan Micro Helis 6 Nov 06, 2003 07:53 AM
