Old May 12, 2002, 11:29 AM
WrongwayFeldman is offline
Find More Posts by WrongwayFeldman
Joined Jan 2002
@!#$ Stripped mini servo screw!!!!
I tried to remove a control arm from a new Hitec (blue?) mini
servo and I could not get it off and I stripped the head. Do they
put these things on with an air hammer!!!!Sigh...
Anyway, I suppose I will need to drill the head off the screw but I
am afraid that there will not be enough screw left to get a hold of...any suggestions?
In retrospect, I guess something like the screw driver found in an eye glass repair kit is the proper tool for the job, I originally used a jewelers screw driver but it would not budge...started to turn the servo arm which is probably not good for the gear train...
Any hints or help would be greatly appreciated, I'm sure I'm not the only one who has buggered up one the puppies before...then again
Mark
WrongwayFeldman is offline Find More Posts by WrongwayFeldman
Old May 12, 2002, 12:12 PM
Steve McBride is offline
Find More Posts by Steve McBride
Steve McBride's Avatar
Agra, Oklahoma
Joined Feb 2000
Use a it that is about the same diameter as the head of the screw. You want to drill just enough so that the head can be pulled off. Once the servo arm is off, there should be enough of the screw protruding to grab it with a pair of small diagonal cutters and unscrew it. The diagonal cutters get a better grip on a smaller area than pliers.
Radio Shack has a set of small screwdrivers that seem to work well. The small ones seem to fit best, but then you have no grip, so use a pair of pliers to turn the screwdriver while holding the servo arm to prevent it from turning (you need 3 hands to do this though -).
Good luck!
Steve McBride
Steve McBride is offline Find More Posts by Steve McBride
Old May 12, 2002, 02:20 PM
Ralph A. D'Amelio is offline
Find More Posts by Ralph A. D'Amelio
Ralph A. D'Amelio's Avatar
United States, MA, Chelmsford
Joined Jul 2000
Its happen to me on 3 - 55 servos until my LHS sold a great tiny phillips head that they use on electric cars. The head is a different material and its the best tool for 55.
Having said that the best wayI found since I don't want to drill is to take a sharp blade #11 say and cut away the arm next to the screw..you will be able to get a needlenose and grab and turn the #$5@ screw. It works.
Ralph A. D'Amelio is offline Find More Posts by Ralph A. D'Amelio
Old May 12, 2002, 05:54 PM
Joined Jan 2002
Thanks for the help!
Thanks for the replys guys, guess I'm not the only one that stripped these before...it would be nice if someone came across some miniature allen head screws for these as an after market replacement I suppose...I should thumb through my McMaster-Carr catalog to see what's available.
Thanks again...think spring and calm winds!
Mark
Old May 12, 2002, 06:17 PM
ZAGIZAGI is offline
Find More Posts by ZAGIZAGI
ZAGIZAGI's Avatar
Los Gatos, CA
Joined Apr 2001
Hitec support is really good and they have fast turnaround. They'll repair broken stuff for cheap.
-ZZ
ZAGIZAGI is offline Find More Posts by ZAGIZAGI
Replacing servo screw tabs tenover Electric Plane Talk 2 Feb 05, 2003 08:19 PM
servo screw replacements brimann77 Electric Plane Talk 2 Oct 23, 2002 10:20 AM
GWS Mini servo 24.3g street price $9.99 GWS4CEO Parkflyers 3 Nov 15, 2001 09:34 AM
Expert SL451 Mini Servo Steven9026 Parkflyers 15 Oct 23, 2001 10:10 AM
What's the hot mini servo these days? Mr. Wiz Electric Plane Talk 36 Aug 05, 2001 11:56 PM
