Old Sep 24, 2005, 01:36 PM
Keith R. is offline
Find More Posts by Keith R.
Goodpasture's FTW
Keith R.'s Avatar
Joined Jun 2004
Hitec RX w/ JR TX
Hi everyone. What is the best hitec RX will work with my JR6102? I need to fly tomarrow, and i cannot get a JR RX, so i was going to pick one up to see how it works.
Keith
Keith R. is offline Find More Posts by Keith R.
Old Sep 24, 2005, 01:47 PM
Cody WIlson is offline
Find More Posts by Cody WIlson
plane obsessed
Cody WIlson's Avatar
Denver, CO.
Joined Nov 2003
Dude whatever Hitec Dual conversion (positive shift!!!) reciever you choose will work fine! I have Super 8's, and 555's. NEVER had an RX problem wiht any of 'em. I like the super 8 because its a bit more 'robust' and holds up to the slope pretty well, but the 555 is just as good, and small-ish to fit in smaller planes.
Doooo Eeeet!
Cody WIlson is offline Find More Posts by Cody WIlson
Old Sep 24, 2005, 02:10 PM
Keith R. is offline
Goodpasture's FTW
Keith R.'s Avatar
Joined Jun 2004
Are there any hitec PCM Rx's? So the 6102 is duel conversion?
Old Sep 24, 2005, 02:29 PM
Terminator is offline
Find More Posts by Terminator
Yorba Linda, Ca.
Joined Oct 2003
Jr?
I dunno why you can't find a JR.
7oo is ppm
770 is spcm single conversion.
Most Horizon lhs have them in stock or certianly can oder them.
Hitec does not support pcm.
Tom Copp has stock on these and higher end units as well.
Gyro hobbies in Laguna Hills also has them in stock well as Ultimate Hobbies in Orange.... Call ahead.
Depends on what your using it in for space considerations.
I fly Spcm's single conversions in my area due to the fm rich enviroment..hitecs glitch alot.
Another good alternative is the Berg 5 very clean glitch wise for a PPM.
RC Direct has those in SanDiego...858 560 9633....
Good luck.
Alan
Terminator is offline Find More Posts by Terminator
Old Sep 24, 2005, 02:45 PM
hydrogin is offline
Find More Posts by hydrogin
Santa Barbara, CA
Joined Feb 2004
I believe all PCM receivers must be used with the same brand Tx, so a JR Tx can only be used with a JR PCM Rx. This of course isn't the case for run-of-the-mill PPM Rx's.
Lance
hydrogin is offline Find More Posts by hydrogin
Old Sep 24, 2005, 02:57 PM
Keith R. is offline
Goodpasture's FTW
Keith R.'s Avatar
Joined Jun 2004
I cannot get out to a hobby store that carries jr recievers...Will a hitec crystal work with my JR Tx as long as they are the same frequency?
Keith
Old Sep 24, 2005, 03:18 PM
SlopeKing is offline
Find More Posts by SlopeKing
Auckland, New Zealand
Joined Apr 2002
no... it wont
Rule of xtals: Same Brand, Same type as device being used in! i.e. (Hitec DC RX gets Hitec DC Xtal, and Jr TX gets Jr TX Xtal)
SlopeKing is offline Find More Posts by SlopeKing
Old Sep 24, 2005, 04:37 PM
Keith R. is offline
Goodpasture's FTW
Keith R.'s Avatar
Joined Jun 2004
I just tested my TX with the 555 and super slim (8ch) and both of them did not work. I tried it with 2 seperate RX crystals and there was nothing. They were both + shift and the crystals worked with my JR RX....go figure. Also, i acidently riped the antena out of one of my r700 rx's and aft er i soldered it backl on, it went out of range about five feet away....any sugestions?
Keith
Old Sep 24, 2005, 04:39 PM
flusterfly is offline
Find More Posts by flusterfly
None
Joined Sep 2005
Hmmmmm....You CAN use your JR Tx with a Hitec positive shift receiver with a Hitec receiver crystal. As SlopeKing says, always use the same brand receiver and receiver crystal (Hitec RX & Hitec Xtal, Berg RX & Berg Xtal, etc.) You should be able to use any brand of positive shift receiver with it's mated Xtal.
flusterfly is offline Find More Posts by flusterfly
Old Sep 24, 2005, 04:45 PM
Yorba Linda, Ca.
Joined Oct 2003
Ripped out?
Geez.
That sucks...just open the case of the receiver up and locate the position of the antenna wire...and re solder it...CAUTION...use flux and rosen core solder.... a solding iron on low...quick movements here do not over heat the circuit board....or for that matter smear solder over any where other than where it is intended....obvious reason.
You may use the correct shift crystal in the 555 receiver match the channel to module in your tranney....if channel 60 in the tranney like wise in the receiver....use a hitec in a hitec and so forth. The 700 receiver is a good unit try to repair it and use it.
Again good luck.
Alan
Old Sep 24, 2005, 04:56 PM
Joined Apr 2002
Breaking the antenna and resoldering it will not neccessarily work, as the impedance will no longer match...
theres no such thing as a 'shift crystal', a crystal is just an oscillator.
Hitec in Hitec, futaba in futaba, jr in jr... simple as that...
Old Sep 24, 2005, 04:57 PM
Keith R. is offline
Goodpasture's FTW
Keith R.'s Avatar
Joined Jun 2004
Doh, i thought you guys were saying use the JR crystal...my bad. I guess i will try it again...
Keith
Old Sep 24, 2005, 04:58 PM
Keith R. is offline
Goodpasture's FTW
Keith R.'s Avatar
Joined Jun 2004
Should i just send the rx to horizen and see if they can solder it on correctly.
K
Old Sep 24, 2005, 06:00 PM
Keith R. is offline
Goodpasture's FTW
Keith R.'s Avatar
Joined Jun 2004
It worked. Thanks for fixing my blond moment.
Keith
(who has blond hair)
Electron 6 RX w/ JR TX questions ortoyegon Slope 29 Sep 10, 2005 10:03 PM
Hitec Rx with JR Tx Warbird_SIN Radios 4 Apr 02, 2005 04:24 AM
GWS gwr-4p Rx w/ JR xf421 TX? HELP! saint152 Scratchbuilt Indoor and Micro Models 2 Jun 15, 2002 05:54 PM
GWS gwr-4p Rx w/ JR xf421 TX? HELP! saint152 Power Systems 3 Jun 15, 2002 05:31 PM
New Jr Batt, New Jr Servos, Hitec Rx W/xtl, Electronic Mixer saint152 Aircraft - Electric - Airplanes (FS/W) 2 Mar 15, 2002 12:26 PM
