Old Sep 21, 2005, 07:42 PM
what_the?! is offline
Find More Posts by what_the?!
Adelaide,South Australia
Joined Jul 2003
high kv low kv high amp low amp
http://www.totalerc.com/rcstuff/highkvvlowkv.htm
im very interested in this so called phenom.
please look at the table at the link.
what i see that is interesting for me at least is that there is a tradeoff for performance v flight time at the expense of weight (more cells). The efficient current range of each respective motor is related to it's winds so for each respective efficiency i cant see the difference.
we all know that transformers step up and down voltage/current to reduce heat losses especially over large distances, but for me i cant see a great benefit in going higher voltage.
am i missing something here? it appears that the bang for buck is in the current carrying capacity of the cell, not the extra voltages..i.e longer flight times.
the heat losses are interesting and i wonder what the inertial losses- if significant are with extra winds, larger gauges etc etc and so on.
seems swings and roundabouts to me.
im sure this will open debate...any gurus care to explain concisely the benefits?
dont get me wrong, not a nay sayer, rather want to quantify the gain precisely.
cheers.
what_the?! is offline Find More Posts by what_the?!
Old Sep 21, 2005, 08:03 PM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
United States, TX, Katy
Joined Nov 1999
Watts are watts, no matter how you do the math(low voltage, high amperage or high voltage, low amperage). If you are just taking one size/type fan and juggling motors in it there will be combinations where performance(rpm) is nearly the same, just a personal choice to me. I like lightweight setups and airplanes usualy fly better when lighter. One thing you might look at is the thrust to weight of the fan system, the total weight is more relavent to the aircraft flying performance than just the electrical system and its associated parts. Higher amps systems use larger wire diameters to buss the current without turning to liquid as compared to lower kv so a system where the fan and battery is seperated by some distance becomes pronounced as the wire weight becomes a problem. Just my 2 cents(US).
Eric B.
AirX is offline Find More Posts by AirX
Old Sep 21, 2005, 08:08 PM
Joined Jul 2003
Originally Posted by AirX
Watts are watts, ......... One thing you might look at is the thrust to weight of the fan system, the total weight is more relavent to the aircraft flying performance than just the electrical system and its associated parts.
Eric B.
Eric, your post has been my thoughts exactly, but i wanted to make sure- and esp the total weight not just the components... (my bad for the charts)
it was more a bee in the bonnet about some i think exaggerated claims that the setups are night and day.
personally, i like the ease and availability of the standard run of the mill 3s pack that i can move from plane to plane/heli to heli.
horses for courses. thanks so much for the reply.
tim.
Old Sep 21, 2005, 08:09 PM
Joined Jul 2003
....Just my 2 cents(US).
Eric B.
we call it 2 bob's worth here in Aust (equiv to 20c Au)..which is about the same as 2c US.
Old Sep 21, 2005, 08:17 PM
Kevin Cox is offline
Find More Posts by Kevin Cox
EDF Jet Jam 2016, June 16-19
Kevin Cox's Avatar
St. Louis Intl, Missouri, United States
Joined Jan 1997
This is interesting. For me the advantage usually goes to the low cell count higher current setup. This is due mainly to the cost of high cell count controllers. If you are flying the smaller stuff it isn't as big of a problem. For the larger stuff it adds up quickly, especially on a twin
As far as higher cell count/lower current vs low cell count/higher current goes, it really depends on the motor and batteries selections. The higher current can be hard on batteries and motors if you make the wrong choice. Cooking a motor appeared to be the norm for awhile as one tends to try and fly longer with a high cell count. Everything else being equal.....watts is watts
I'd call it a draw.
What Eric said.....I simply type too slow
Kevin Cox is offline Find More Posts by Kevin Cox
Old Sep 21, 2005, 08:20 PM
AirX is offline
EDF rules... :)
AirX's Avatar
Joined Nov 1999
Yup..
Eric B.
Old Sep 21, 2005, 08:30 PM
AirX is offline
EDF rules... :)
AirX's Avatar
Joined Nov 1999
I am in the process of gathering larger equiptment for a midifan sized jet, the lower kv higher voltage has taken me by surprise as to the level of pricing but overall I think that since I am getting new equiptment I will go that direction as I am not getting new eq to take the place of older eq. I think working on this project when it starts will be fun and enlightening. All my small fans are geared for 3s, seems to be a nice size for me too.
Eric B.
Old Sep 21, 2005, 08:36 PM
kriptonic is offline
Find More Posts by kriptonic
kriptonic's Avatar
Los Angeles
Joined Aug 2004
If you have the $$$ for a high volt set up, then that is the way to go, I'm planing on that for my midi-fan A-10 i can't beat the low weight of a 12s1p set up per side going with the HV as compaired to the high weight 6s3p lower voltage set up. then again it's up to your own preference and wallet size........
Gene
kriptonic is offline Find More Posts by kriptonic
Old Sep 21, 2005, 08:43 PM
AirX is offline
EDF rules... :)
AirX's Avatar
Joined Nov 1999
Gene,
Your right, and that is the direction I am leaning.
Eric B.
Old Sep 21, 2005, 09:03 PM
Joined Jul 2003
is the high volt setup more expensive?
i think that its the cost of more cells + higher cell count ESC versus the larger , higher amp ESC and the higher capacity Cell pack.
thatd be a nice little equation to see the comparison...maybe when i have time ill do it for fun.
tim.
Old Sep 21, 2005, 09:31 PM
NCC-1701 is offline
Find More Posts by NCC-1701
Joined Oct 2002
HIgh voltage set-ups weren't really practical until Lipos came along. With Nicads, and to a lesser extent, MiMH cells, you gained too much weight trying to build a high voltage system.
Rob
NCC-1701 is offline Find More Posts by NCC-1701
Old Sep 21, 2005, 09:37 PM
NCC-1701 is offline
Joined Oct 2002
tim.
Tim,
With Lipos, not necessarily. You may get away with building a high voltage system with the same total cell count as in a high current system. It all depends on the kv of the selected motor(s). We used to not have much choice in HV speed controls. There was Jeti and Hacker and both of their HV controllers were a bit on the expensive side. Now that Castle has HV versions of their Phoenix controllers, the price of a HV system has certainly gone down.
Rob
Old Sep 21, 2005, 10:32 PM
PhilLin is offline
Find More Posts by PhilLin
Oshkosh, WI
Joined Nov 2002
tim.
I'm not sure about your assumption that the hi-volt system has more cells & is heavier. I flew my Midi f-18 with 6s4p (24-cells) before switching to 8s2p (16-cells). Because of the lower amps even at higher power, one ends up with less "P's" & also lower maH for same duration, therefore less weight. Now that CC is into even higher volts & with new 16C to 20C packs, may be time to bump up volts some more. Remember, one still fly at same output watts at cruising speeds, so 9s1p or 10s1p can be viable (if wide format packs becomes available)
Phil
PhilLin is offline Find More Posts by PhilLin
Old Sep 21, 2005, 10:52 PM
sguty is offline
Find More Posts by sguty
Senior Member
sguty's Avatar
Redmond, WA, USA
Joined Oct 2000
My take on it is as follows:
* with pre-LiPo technologies, from both a weight and cost perspective, volts were expensive and amps were cheap
* with LiPos, amps are expensive (especially as you cross "Xp" barriers) and volts are cheap.
I fly all my jets on 1p packs. Looking forward to going over the 7p barrier (the practical limit for the non-HV CC ESCs) with one of their 45 HVs.
Steve G.
sguty is offline Find More Posts by sguty
Old Sep 21, 2005, 11:04 PM
scratchandbash is offline
Find More Posts by scratchandbash
scratchandbash's Avatar
Grove City PA basement/park
Joined Feb 2005
Higher Voltage Advantages:
1. Less weight due to thinner power cables and less copper mass in the windings. this is due to lower current needed to maintain the same power level.
2. Less IR (resistance) losses due to lower current needed to maintain same power level. Lower IR losses mean less waste heat, and heat is not good for anything in an rc airplane: ESC, motor, battery, connectors, the plane itself, etc...
These are the main reasons the cordless power tool industry have gone to higher voltages. They save money in copper, and make money by offering a more powerful tool.
scratchandbash is offline Find More Posts by scratchandbash
High V, low KV revisited Darren Hintze Power Systems 89 Feb 20, 2009 06:58 AM
Discussion Question running high V on low Kv motors (himax, 2025 series) badinstincts Power Systems 20 Mar 08, 2006 05:26 PM
low kv high voltage maximilian Power Systems 3 Sep 30, 2004 08:01 PM
High KV or Low KV RockyTse Power Systems 2 Apr 26, 2004 09:51 AM
High Kv small pinion vs low Kv large pinion? Nicke Power Systems 13 Oct 16, 2003 02:38 AM
