Go Back   RC Groups > Aircraft - Electric - Airplanes > High Performance
Old Oct 26, 2005, 09:18 AM   #46
Balsa!!!
Send a message via MSN to csisfun
OK Paul,
Thanks for the heads up. I'll try to see what I can do. Another question if it doesn't bother you: how do I mark the aileron outlines on? Do I do it before (I don't think so, after all the planing, the markings would disappear!!!), or after planing and sanding? If so, how?
Uzzy
csisfun is offline Find More Posts by csisfun   Reply With Quote
Old Oct 26, 2005, 09:41 AM   #47
Site Sponsor
pldaniels's Avatar
Send a message via AIM to pldaniels Send a message via Yahoo to pldaniels
uzzy,
For the ailerons, once you have completely finished your wing (yes, you wait till that stage), you then flip it over so that the bottom faces up, take your wing plan printout and either push a pin through the plan/wing at the corners of the ailerons or use a pencil and push through. After that you can cut through the two sides of the aileron and then cut -almost- through to the other side with the long part of the aileron (if you've covered the wing with film), this allows you to have your ailerons hinged without needing to use any tape Don't worry if you cut all the way through though, you can just use tape like normally done.
Ultimately, don't worry - it's not supercritical with the size of the ailerons, after all, I just used TLAR principles .
Paul.
pldaniels is offline Find More Posts by pldaniels   Reply With Quote
Old Oct 26, 2005, 12:45 PM   #48
Fly by grace
rkhoo's Avatar
A newbie question:
Would a Graupner 6x3 folder prop work on 8cells on this plane? It gives more thrust to aid in lauching but with a lower top-speed. It will sure help to prevent broken props on landing...
pldaniels, I would like to see what you will come up wih on a landing gear setup for this wonder plane.
rkhoo is offline Find More Posts by rkhoo   Reply With Quote
Old Oct 26, 2005, 03:03 PM   #49
Balsa!!!
Yup, yup. One night's worth of work. I construct horribly.
  • Name: DSCN1685.JPG
  • Name: DSCN1686.JPG
  • Name: DSCN1688.JPG
Old Oct 26, 2005, 03:21 PM   #50
Balsa!!!
Oh noooooooooooooooooooo!!! The plan says use 3.2mm sides, but I used only 1/16" balsa. Heh! Maybe I shall glue another layer of 1/16" on the sides. Ha ha!
Old Oct 26, 2005, 08:38 PM   #51
Site Sponsor
pldaniels's Avatar
Launching thrust is all about throwing hard, fast and up at the right angle A 6x3 on 8 cells might actually be a bit too excessive. Can you get something more like 5x2.5 ~ 3 ?
Yes, so will my props
Paul
Old Oct 26, 2005, 08:41 PM   #52
Site Sponsor
pldaniels's Avatar
*laugh* don't feel so bad. Actually, yes you can just add another sheet of 1/16" on the outside, it'll be stronger (assuming it's glued right) than a single sheet of 1/8".
I see you're going to be using a BL motor - which one is that?
Paul.
Old Oct 26, 2005, 11:39 PM   #53
Balsa!!!
It's a Justgofly 300DF - supposed to be a direct 400 motor replacement. Since I feel a bit cheapskate (didn't want to buy a new motor) and had the motor lying around, I thought I might as well use it for more power.
Old Oct 26, 2005, 11:51 PM   #54
Site Sponsor
pldaniels's Avatar
I'm sure it'll be very good fun What's its Kv rating? What prop are you going to throw on it ? Since it's an outrunner will you need to rather use a larger prop?
Paul.
Old Oct 27, 2005, 02:19 AM   #55
Balsa!!!
Not really, it's a 400 replacement. Kv is about 2200. I think I'll use a 5x5 APC on 2s. The problem is, it comes with a 3mm shaft, and I will have to do a spinner myself! The shops don't sell them.
Ah yes... this plane looks like a winner. I just finished planking the sides with another 1/16" piece!
Old Oct 27, 2005, 02:32 AM   #56
Site Sponsor
pldaniels's Avatar
2200 @ 7.4V ~= 16krpm, not too bad, on a 5x5 prop you've got a theoretical 125km/hr top speed.
How did you plank the sides? What glue did you use?
Paul.
Old Oct 27, 2005, 08:01 AM   #57
Balsa!!!
I just added another sheet of 1/16" balsa to the sides. Glued the whole piece down with CA and cut it out using the current sides as a "ruler".
Nice 125km/h! I need a spinner! I bought a prop adaptor, but it didn't come with a spinner. Let's see what we can do. Ha ha.
Old Oct 27, 2005, 08:18 AM   #58
Site Sponsor
pldaniels's Avatar
I got my spinner from Aircraft World, it's a MPJets 30mm spinner with a 2.3mm collet, obviously with your 3mm situation you're going to run into some issues. You could always make one out of balsa/foam.
Paul.
Old Oct 27, 2005, 10:44 AM   #59
Balsa!!!
Cool! Fuse is done, shaped and rounded! I even got something extra from the Master Airscrew plane - a cut on the thumb! The fuse wasn't spared with my building skills, I got a banana !
Yeah!!!
  • Name: DSCN1690.JPG
  • Name: DSCN1699.JPG
  • Name: DSCN1698.JPG
Old Oct 27, 2005, 10:58 AM   #60
curmudgeon in training
Bronze Member
Arbo's Avatar
Looking good...
Arbo is offline Find More Posts by Arbo   Reply With Quote
Sold Sokol Speed 400 pylon racer with motor and props neilo Aircraft - Electric - Airplanes (FS/W) 10 Jun 14, 2005 12:43 AM
T-Strike Sp 400 Pylon Racer mitc99kd Aircraft - Electric - Airplanes (FS/W) 1 May 22, 2002 04:06 PM
Fast Composites Sliver ARF 400 Pylon Racer for sale! Dave Campbell Aircraft - Electric - Airplanes (FS/W) 1 Feb 26, 2002 08:38 PM
FS: Stinger 400 pylon racer ghanson Aircraft - Electric - Airplanes (FS/W) 2 Dec 23, 2001 09:15 PM
WTB- Speed 400 pylon racer nib or unflown flyerman Aircraft - Electric - Airplanes (FS/W) 0 Oct 13, 2001 05:55 PM
Bored? Want to fight?
Join the RCGroups clan!
