Old Jul 11, 2001, 09:18 PM
sms is offline
sms
Find More Posts by sms
sms
N.C.
Joined Jun 2001
gear drive or not?
HI, i,ll try to be breif, so here goes.
i have built a tiny that i got plans for from Todds models page. Instead of the dc1717 i used a much cheeper s-280. wing span 24" approx 215-220 sq. inch. My all up has come to be about 10.5 oz. more than i wanted.
I justed finished tonight.
My question is, with this size and weight plane should i use a gear drive with the 280? It is now set up as direct drive with a prop off of a firebird XL. 6.5" tip to tip, have no idea of the pitch, its not much.
So what do you all think.
Thanks, Steve
sms is offline Find More Posts by sms
Old Jul 12, 2001, 01:56 AM
Fred Bronk is offline
Find More Posts by Fred Bronk
Our Daddy and Heli Junkie
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
It depends on the plane really, but geardrive tend to be more effecient unless you want just speed.
Is the AUW 10.5 oz, or is it 10.5 over what you wanted?
The Tiny is not a speed machine, and AUW will be important. You may want to look at a GWS setup if the 1717 is to $$$.
Many of these little planes are designed for certain motors and props, without much leeway.
Fred Bronk is offline Find More Posts by Fred Bronk
Old Jul 12, 2001, 10:06 AM
Megowcoupe is offline
Find More Posts by Megowcoupe
Balsa Flies Better!
Stamford, CT
Joined Oct 2000
Go with a 3:1 geardrive- the Titanic units don't add much weight at all and will increase your thrust plenty- important for vertical maneuvrability. Your real question is batteries- you may be able to get away with an 8 cell 300 NiMH which will save some weight, or the next lightest is a 7 cell 350 nicad. At that weight though, you may be happiest on an 8 cell 720 NiMH pack. Don't use 600 AE nicads.
Sam Brauer
Norwalk, CT
Megowcoupe is offline Find More Posts by Megowcoupe
Old Jul 12, 2001, 01:07 PM
sms is offline
sms
sms
N.C.
Joined Jun 2001
Yes the aup is 10.5 oz. total. Just had to try it. 7 cell 270 It glids great, straight to the ground after about ten yards with full power. got to do something. Must go now. will check back soon. Steve
Old Jul 12, 2001, 02:11 PM
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
You need thrust, not airspeed so use a GB.
Discussion Question on gear drive or direct drive Wyatt Electric Motor Design and Construction 2 Feb 20, 2006 07:03 AM
**To Drive or Not to Drive this is the question hubdave Micro Helis 7 Oct 31, 2005 04:46 PM
Help! hb training gear? to use or not to use? ejs04 Micro Helis 5 Aug 20, 2004 03:56 PM
Strip noise today-go to BELT drive? Or not? albireo Electric Heli Talk 9 Dec 18, 2003 04:14 PM
Speed 280BB - direct drive or not? Tyson Electric Plane Talk 9 Jun 04, 2001 06:12 AM
