Old Sep 20, 2005, 09:02 AM
finishman2000 is offline
Find More Posts by finishman2000
nooobama
United States, PA, Stroudsburg
Joined May 2004
hooking up lipo's in series
I have purchased a DC-3 from Polk hobbies and it has 2-600 size brushed motors. I may go brushless if it doesn't fly. There are mixed opinions on this plane with the stock set-up
Instead of a heavy huge brick of NiMh's i would like to buy 2 or 3 batteries, 3 cell, 2100mah lipos and hook them up in series. They would only be used in this plane or anther like it, always together. Good idea? I'm not fond of buying a big lipo pack, for like $200 and crash and damage the pack and have to through it away. Also can I charge the lipo brick as a reg 3 cell (all together)?
Thanks, Cas
finishman2000 is offline Find More Posts by finishman2000
Old Sep 20, 2005, 09:43 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
I believe you mean connect in parallel not series. A 3 cell LiPoly battery would be 11.1 volts (nominal) and 12.45-12.6 V charged. Connecting two 2100 mAh ones in parallel would still be 11.1 V but would be 4200 mAh capacity. Please note that many brushed motors do not handle this high of voltage well. One LiPoly cell is approximately equivalent to 3 NiCad or NiMH cells.If you use LiPolys you will need a LiPoly safe ESC or time your flights and watch voltage very closely. LiPolys are seriouly damaged by overdischarging them.
http://www.rcgroups.com/forums/showp...28&postcount=2
Charles
Old Sep 20, 2005, 09:51 AM
nooobama
Joined May 2004
your right, my bad.
Old Sep 20, 2005, 10:28 AM
msg73 is offline
Find More Posts by msg73
Joined Jul 2004
If you hook up three 3s1p 2100 lipos in series, you will have a 9s1p 2100...That's over 33 volts! Are you sure you didn't mean hooking them up in parallel? This will get you a 3s3p 6300 mAH pack at 11.1 volts.
Either way, you can do it. Just make sure you are using similar packs and that they are within .1 volts before you connect them. If you connect them in parallel with some Y-connectors, then you just charge them like a normal 3 cell lipo but just bump up the amps to charge at 1C.
msg73 is offline Find More Posts by msg73
Old Sep 20, 2005, 11:29 AM
hall woo is offline
Find More Posts by hall woo
Permanently Banned
San Jose Ca / RSA flyer
Joined May 2003
Two Mega 5 Turn
seen used in a DC3 by Tom at the RSA field
hall woo is offline Find More Posts by hall woo
Discussion Connecting Lipo's in series. TravisR Batteries and Chargers 3 Aug 07, 2006 09:22 AM
Need a Lipo Charger (dual) that charges up to 4 lipos in series tdab Batteries and Chargers 4 Oct 25, 2004 02:26 PM
Charging LiPo's in series? pbrokaw Batteries and Chargers 3 Sep 18, 2004 07:04 PM
Charging LiPo's in series -> *max 4.2V per cell* GregoryJ Batteries and Chargers 1 Dec 08, 2003 07:28 AM
EDF's in series? Anyone tried it? vintage1 Electric Ducted Fan Jet Talk 5 Sep 23, 2002 04:19 PM
