Old Sep 19, 2005, 11:58 AM
PhillipE is offline
Find More Posts by PhillipE
Joined Nov 2004
Hot Wire Bow - Train Transformer
Hello, I have a 30 year old Lionel Train transformer. The specs on it show
a maximum output of 15 volts and 45 watts. That tells me this puppy has
3 amps output max.
Question, can this power up to a 24" bow using .020 stainless steel wire
for cutting EPS. I know for cutting EPP I'd probably need more power.
Phil
PhillipE is offline Find More Posts by PhillipE
Old Sep 19, 2005, 12:01 PM
ImaBiggles is offline
Find More Posts by ImaBiggles
Master of 1 point landing
Naperville, IL
Joined Jul 2005
3 amps output max.
Phil
if you are using the full 24" for panel cuts - you may be underpowered, Rat Shack has a 5am 12 volt transformer if you are - else you can try a car battery charger.
ImaBiggles is offline Find More Posts by ImaBiggles
Old Sep 19, 2005, 02:02 PM
PhantomII is offline
Find More Posts by PhantomII
Phantom Mechanic
PhantomII's Avatar
Westpoint Utah
Joined Jul 2005
I tried a train transformer and it was not hot enough. Your better off with the battery charger or a home built power supply.
PhantomII is offline Find More Posts by PhantomII
Old Sep 19, 2005, 08:09 PM
rocstar is offline
Find More Posts by rocstar
Joined Sep 2004
I use a train transformer for small jobs, usually a few inches. Works great for that, but I never tried a 24" sheet. I use guitar string. You might be able to get 24" with the thinnest guitar string.
rocstar is offline Find More Posts by rocstar
Old Sep 19, 2005, 09:00 PM
dayhead is offline
Find More Posts by dayhead
SlingWinger
San Bernardino, California, United States
I plug a cheapo car battery charger into a light dimmer or fan speed controller. Works great and have used up to 30" of .015 piano wire. There was plenty power available, I'm sure it will run much longer wire. The dimmer/controller switch cost I think about $8 and the car battery charger I got at a garage sale or thrift store for $10. The dimmer controls input to the charger and is easy to adjust.
dayhead is offline Find More Posts by dayhead
Old Sep 19, 2005, 09:26 PM
PhillipE is offline
Joined Nov 2004
Thanks everyone for the suggestions! It looks like battery charger/light dimmer may be an easy solution.
Phil
Old Sep 20, 2005, 03:09 PM
Flyin Brick is offline
Find More Posts by Flyin Brick
Flyin Brick's Avatar
Santa Clarita, CA
Joined Jan 2005
I use a 5 amp variac transformer i picked up on ebay for only 30bucks....works perfect....
Flyin Brick is offline Find More Posts by Flyin Brick
FS: MM2001 CNC Hot Wire Driver Board + Transformer tomi Aircraft - Electric - Airplanes (FS/W) 0 Mar 31, 2005 12:50 AM
best hot-WIRE and BOW Grantman Composites Fabrication 1 Jan 26, 2005 10:30 PM
Hot Wire Bow Pictures hoppy Foamies (Kits) 2 Jan 15, 2004 04:01 PM
variac and hot wire bow Podo The Builders Workshop 5 Nov 25, 2003 08:39 PM
Could you use this to power a hot wire bow emoone Electric Plane Talk 4 Oct 01, 2002 08:37 PM
