Old May 06, 2001, 01:44 PM
lrsudog is offline
Find More Posts by lrsudog
Go get them Meg!
lrsudog's Avatar
Cabin 21...
Joined Jan 2001
I use a hitec peak detection charger that works fine for nimh batteries. False peaks tend to happen more with nimh packs at higher charge levels. I charge 270s at less than 1 amp, and 600s at less than 1.5 amps. This seems to keep false peaks to a minimum, and lets me fly right away without waiting for the pack to cool.
Lithium cells need a special charger.
lrsudog is offline Find More Posts by lrsudog
Old May 06, 2001, 01:45 PM
lrsudog is offline
Go get them Meg!
lrsudog's Avatar
Cabin 21...
Joined Jan 2001
To be clear, I believe most peak detection chargers will work, not just Hitec.
Old May 06, 2001, 02:37 PM
Bill Glover is offline
Find More Posts by Bill Glover
Bill Glover's Avatar
United Kingdom, Bracknell
Joined Nov 2000
Although many people do use them successfully, be aware that there are a few posts out there about Hitec chargers missing the peak when charging Nimh cells. I use a Super Nova, which has a specific setting for Nimh.
Bill Glover is offline Find More Posts by Bill Glover
Old May 06, 2001, 02:43 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Be sure and get one that was designed for charging NiMH cells. The "peak" of NiCd's and NiMH batteries is different and it is important that the circuit be designed to recognize the NiMH peak. The peak V drop detection for NiCd is 15-20mv/cell. For NiMH it's 5-10mv/cell. For an 8 cell pack, that is 160mv for a NiCd and 80 for a NiMH. If the charger was designed to look for the 160mv "drop" in voltage for a NiCd, it would probably cook a NiMH cell waiting for the "big" voltage drop.
Having said all that, The Astro 110D is just one of many that was designed to "see" the NiMH peak. Check the manufacturers specs before you buy is my recommendation.
hoppy
ps... Manufacturers recommend 1C as max. Check your charger manual to see what they recommend.
[This message has been edited by hoppy (edited 05-06-2001).]
hoppy is offline Find More Posts by hoppy
Old May 06, 2001, 04:01 PM
Fred Bronk is offline
Find More Posts by Fred Bronk
Our Daddy and Heli Junkie
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
The Orbit chargers have a nimh setting, and so do the Schultz(infinity?) units.
The Mutiplex/Dymond new mini charger does them too up to 8 cells and is $40.
Fred Bronk is offline Find More Posts by Fred Bronk
Old May 06, 2001, 08:01 PM
realglow is offline
Find More Posts by realglow
Eat, Sleep, Fly!
realglow's Avatar
Joined Mar 2001
The Great Planes ElectricFly Peak Charger, GPMM3000, indicates it will peak charge both NiCd and NiMH packs, 6 to 8 cells, at 200 or 600 mA (selectable; pulsed charge). I have used it extensively on NiCds but have not tried NiMHs. It plugs into your car's 12v power port or cigarette lighter and is conveniently small.
realglow is offline Find More Posts by realglow
Old May 06, 2001, 08:38 PM
Pat Daily is offline
Find More Posts by Pat Daily
Pat Daily's Avatar
United States, VA, Chesterfield
Joined Mar 2001
i like the Astro 110D and have been using it for a year to charge NIMH from the little ones (110ma) the John Worth sells to the larger ones from Hobby Lobby for the 280 sizes (550ma). I use mostly 270ma NiMH in my planes and liked the charger so much that I just bought another. You know how it is--I have to have a "lifetime" supply of goodies that I use in modeling!
Pat
Pat Daily is offline Find More Posts by Pat Daily
Old May 07, 2001, 12:20 AM
clchen is offline
Find More Posts by clchen
Lafayette IN, USA
Joined Apr 2001
Is there a Charger that will automaticlly charge the NIMH?
clchen is offline Find More Posts by clchen
Old May 07, 2001, 04:45 AM
tic is online now
tic
Find More Posts by tic
tic
thunderscreech
tic's Avatar
United States, MI, Gaylord
Joined Dec 2000
I have both the hitec cg-335 and a newly acquired dymond supersmart.. Although the hitec works on NiMH.. peaks are a bit warm, and you really should monitor the charge.. The dymond charger does them perfect everytime do to a dedicated NiMH mode.. Dymond charger was also only 109 bucks... Hitec was 89 I think.
tic is online now Find More Posts by tic
Old May 10, 2001, 10:30 AM
frankenfoamy is offline
Find More Posts by frankenfoamy
Strange Plane Central
frankenfoamy's Avatar
Poway (near San Diego), CA US
Joined Dec 2000
The SIRIUS charger use peak prediction rather than detection. Claims to minimize overcharge damage.
frankenfoamy is offline Find More Posts by frankenfoamy
Old May 10, 2001, 11:12 AM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
I haven't used a peak prediction charger, which I assume means it cuts the charger off on the upside of the peak rather than the downside, but from my experience and info from the temp/V graphs, most of the battery heating takes place after the battery reaches peak voltage. Therefore, it sounds like a great idea. Wish I had it on my Astro 110D.
hoppy
Old May 10, 2001, 11:39 AM
wayne is offline
Find More Posts by wayne
Millarville,Alberta,Canada
Joined Jun 2000
I have a Great Planes ElectricFly Charging ant tried it with 600NimH 7 cells. Worked great, took 55mins then it flashed 12 times, then goes into 15ma trickle charge. Happy with it so far.
Wayne
wayne is offline Find More Posts by wayne
Old May 10, 2001, 08:39 PM
Tom Smith is offline
Find More Posts by Tom Smith
Rhinebeck CD-99,00,01,02
Tom Smith's Avatar
New Bern, NC
Joined Mar 2001
For $42.90 from Hobby Lobby try the Graupner Ultramat 5. It is designed for NCD and NMH and will charge up to 8 cells with anything from .1 amp to 5.0 amps, all automatically. Mine works great and it comes with a plug already on it for your cigarette lighter. Tom
Tom Smith is offline Find More Posts by Tom Smith
Old Jul 10, 2001, 01:47 AM
Erik Johansson is offline
Find More Posts by Erik Johansson
Gothenburg, Sweden
Joined Jan 2001
Orbit all the way. My Microlader V6.0 will easily handle nimh and pretty much everything else. And itīs cheap too!
/Erik
Erik Johansson is offline Find More Posts by Erik Johansson
Old Jul 10, 2001, 11:03 AM
fly4fun is offline
Find More Posts by fly4fun
Joined Jun 2001
I have use the Electrifly charger on my Nimh batteries and have been very happy with it. I believe after its done charging each flash represents 5 minutes of charge time it took.
fly4fun is offline Find More Posts by fly4fun
Reply With Quote  (Disabled)
Lipo Charger that will charge multiple packs? Tram Batteries and Chargers 23 Apr 06, 2005 09:23 AM
Charger that will charge 2 NiMh's or 2 Lipo's at the same time? Tram Batteries and Chargers 3 Oct 12, 2004 07:28 PM
Least expensive Li-Po charger that will charge a 3s1p Etec? The Blue Max Batteries and Chargers 18 Oct 02, 2003 09:33 PM
someone recommend charger that will slow charge billyboy Electric Plane Talk 4 Mar 07, 2002 11:08 AM
Is there a Charger that will automaticlly charge the NIMH? Bill Glover Electric Plane Talk 3 May 07, 2001 12:08 AM
