Old May 10, 2002, 12:37 AM
Martin Hunter is offline
Find More Posts by Martin Hunter
Leave me alone!
Martin Hunter's Avatar
Kamloops, BC, Canada
Joined Feb 2002
Sterling C/L and/or rubber powered models
Hi gang!
There's a flurry of Sterling models available on Ebay... all around the 30 to 35" range, perfect for IPS or M100 power... models like the Stinson Reliant SR-8, Jenny, A-26, etc...
PLEASE!
Someone talk me out of one of these, or all of these... tell me how bad they are to build or how heavy the wood is or something. My credit card will thank you for it.
Martin Hunter is offline Find More Posts by Martin Hunter
Old May 10, 2002, 07:17 AM
buzzsaw 46 is offline
Find More Posts by buzzsaw 46
buzzsaw 46's Avatar
Spring Valley. MN
Joined Jun 2000
Dreamer
Sorry cant help your credit card, I built the Sterling Extra last fall and it flew great right after the first successfull flight I ordered up a Sterling Sukhoi and the building has been even better I think the dies were dull for the Extra because I had to cut every piece out by hand but the Sukhoi the parts practicly fell out of the sheets I havnt finished the Sukhoi yet but it should fly even better than the Extra did.
buzzsaw 46 is offline Find More Posts by buzzsaw 46
Old May 10, 2002, 09:10 AM
DBCherry is offline
Find More Posts by DBCherry
Worcester, MA.
Joined Nov 2001
Dreamer,
The wood is crap, most die cutting is plain god awful, it's heavy, plans have many errors, they're over-priced, the box cardboard is cheap, the graphics stink.... (can't have you bidding against me! )
DBCherry is offline Find More Posts by DBCherry
Old May 10, 2002, 09:17 AM
cathode is offline
Find More Posts by cathode
End User
cathode's Avatar
United States, IN, Nashville
Joined May 2002
I've been looking at those too I want to convert something like that to elec rc... i'm wondering if the current crop of micro-electronics would power something like that? ( I know nothing)
cathode is offline Find More Posts by cathode
Old May 10, 2002, 09:23 AM
Leave me alone!
Joined Feb 2002
cathode, haven't you heard? No one flies radio control any more. Besides, not even 2 servos would fit inside a 30" airplane, let alone let it get off the ground! You'd do better with a .60 sized slimer.
kidding
as dbcherry said, can't have you bidding against me! lol
That's exactly why I'm looking at them... for park flyer electric R/C
Old May 10, 2002, 09:26 AM
cathode is offline
End User
cathode's Avatar
Joined May 2002
heh... well as a rubber-elec conversion newbie, I'd not want to jump into anything till I hear from someone that it's possible
Or, perhaps we can agree on different models and live in harmony
Old May 10, 2002, 09:43 AM
dave1135us is offline
Find More Posts by dave1135us
dave1135us's Avatar
kahoka mo usa
Joined Jun 2001
I have a guillow's cessna 170 kit I bought at hobby lobby( the arts and craft store, not the r/c one) I found it while waiting for my wife to buy some plastic flowers. I was surprised that they had any models, but they did,mostly free flight, but some beginner r/c planes too. it can be powered by rubber, a cox .020 glow, or electric. I'm going to use a dx/a motor and 2 micro servos. it has a 24 inch wing span and should weigh about 4-5 ozs. when done.
dave1135us is offline Find More Posts by dave1135us
Old May 10, 2002, 10:03 AM
cathode is offline
End User
cathode's Avatar
Joined May 2002
Nice, is the kit laser cut? It'e been awhile since I've built a balsa rubberband plane, I've heard laser diecut models are the way to go
Old May 10, 2002, 10:21 AM
Megowcoupe is offline
Find More Posts by Megowcoupe
Balsa Flies Better!
Stamford, CT
Joined Oct 2000
Re the Sterling kits
1) These are exact scale and haven't been designed to fly. Really display kits. I have built 3 so far- a Citabria, a Jenny, and a P-40. I was still learning about e-flight when I did the Citabria and the Jenny but I would not recommend any of them unless you're willing to bash a lot. You will need to lighten up the structure a great deal which manages to come out both heavy and weak (but scale) I did get the Jenny to fly on a direct drive Speed 280 and a 3 cell Tadiran pack. It looked rather neat up there- had problems with warps, needed lots of rebuilding. Landings were always arrivals. The problem is that the wings are high aspect ratio- and heavy which meant that once they started turning, they didn't want to come out easy. Note- it was easy to X-acto a lot of wood out of the fuse, I just should have really worked on the wings too. Hung up in a kid's bedroom.
Citabria- direct drive, speed 300 and a 6 cell 350 pack. Flights were nasty brutish and short. Tail feathers too small. It eventually spun in and I was happy. This airplane might have a shot with a lighter covering and a gear drive, but it wasn't fun to fly. need to enlarge tail feathers. In trash can.
P-40 Still undergoing flight testing- the lightest of the 3- Speed 280 geared 3:1 on an 8 cell 300 mAH pack- I think it's at 8 ounces. So far it's had a nasty tendency to fall off on a wing- and yes, I have some washout in. Still need s more. tail feathers too small (sense a trend here?)
A-26- Comet kit (not Sterling) Built mine for twin electric FF at about 4 ounces. Lead sled-High aspect ratio wings suck below 6 ft. in span. I can't even make it fly rubber. Saw one years ago, flown by a master. It did fly, but also broke up readily upon landing. I'm going to hang mine up or I'll have to try gearing. Needs bigger stab- rudder probably too large. Don't expect any molded parts in Comet kits.
Do you get the sense I'm slightly frustrated with all the airplanes you mentioned?
Note- I have the Sterling Extra kit- it's a newer series and looks to be a much better design. Not true scale which should clearly be avoided for flying airplanes.
Recommendations:- save your money and stick to the Dumas and Herr kits- better engineered, lighter, and folks have been much more successful converting. Either that or you're a good builder- can come up with your own structures using plans as an outline (different tail feathers, probably airfoils) and the plastic parts. You'll probably throw away the wood (their stripwood is OK though.)
CL scale kits- not suitable for conversion. (Some stunters may work, but need built up structures.)
Good luck...
Sam
Megowcoupe is offline Find More Posts by Megowcoupe
Old May 10, 2002, 10:30 AM
Comatose is offline
Find More Posts by Comatose
Dimension Engineering
Akron, Ohio
Joined Jan 2002
Sterling kits are much better than Guillows kits, but that isn't saying much. Not as nice as the Herr kits, Bell kits, Peck kits, Micro-X kits, and on and on.
But, if the price is right, then hey, why not?
Comatose is offline Find More Posts by Comatose
Old May 10, 2002, 10:32 AM
cathode is offline
End User
cathode's Avatar
Joined May 2002
hey Megowcoupe thanks for the info on this... I was looking for someone with experience trying to get these to fly.
Old May 10, 2002, 10:39 AM
dave1135us's Avatar
kahoka mo usa
Joined Jun 2001
I got the kit for $8.00, so couldn't go wrong. it is die-cut, some of the sheets are cut well, some not, but I ran a xacto around the parts before I pushed them out, so no problems. the plans are laid out well, but the instructins are vague, a beginner would have problems. I am modifying mine, strengthing some areas and making the control surfaces movable. should work out ok, I hope.
Old May 10, 2002, 12:15 PM
Leave me alone!
Joined Feb 2002
megowcoupe, Thank you! You've saved my credit card I do love Herr kits, and will be keeping an eye out for any of theirs on ebay, though the prices are up there a bit. I've also been eying up the Hacker kits, or 30" Dumas per another thread on them. I'll keep shopping!
Old May 10, 2002, 12:39 PM
Balsa Flies Better!
Stamford, CT
Joined Oct 2000
Happy to oblige- it didn't sound like they were what you were looking for. (I swear, my most expensive mistakes have begun with the phrase- but I got it on a good deal!) It's beginning to dawn on me after reading lots of conversion stories and doing a bunch of my own, that successful electric conversions are made from airplanes that fly well under rubber power- or at least glow FF. Most of the successful conversions seem to be based on FF designs which work outdoors. As an example, I'd bet the Golden Age kits may be a little problematic, unless you're using really light gear- these airplanes fly well indoors. If the FF guys don't like a kit- be very careful. An exception- some of the Guillows WWI designs don't work well for rubber because of the short nose moment- but that's easy to fix using electrics. Note that these airplanes did fly using glow motors.
By the way- a great source for FF stuff is Penn Valley Hobby center pennvalleyhobbies.com
There are a lot of kits available that should work well as electric conversions such as RN and Midway. The scaled down old timers in the 30-36" size range fly wonderfully as e conversions- I know this first hand. And they're not even that pricey- a lot of the kits go for $20 or so.
Sam
Conversion of rubber powered model planes to electric R/C dave_lilley Scratchbuilt Indoor and Micro Models 24 Apr 09, 2003 07:20 PM
Conversion of Rubber-Powered Models E-Challenged Scale Kit/Scratch Built 0 Nov 08, 2002 06:19 PM
Conversion of rubber powered model planes to electric R/C dave_lilley Site Chat 0 Nov 08, 2002 01:28 AM
Conversion of rubber powered model planes to electric R/C dave_lilley Scratchbuilt Indoor and Micro Models 0 Nov 08, 2002 01:28 AM
Article Conversion of rubber powered model planes to electric R/C Gary Gullikson Electric Plane Talk 0 Nov 08, 2002 12:00 AM
