Go Back   RC Groups > Article Archive > Liftzone Archive
Old Oct 01, 2007, 08:59 AM   #31
I know this thread has been long down, but just wanted to see if any other flyers are still flying this model.
A friend of mine built this for me, a copy, but im glad it performs very similar to the DD.
Gopedasia is offline Find More Posts by Gopedasia   Reply With Quote
Old Aug 21, 2008, 05:01 PM   #32
Nice job on the Review Andy.
You still flying this bird?
aeajr is offline Find More Posts by aeajr   Reply With Quote
Old Aug 26, 2008, 05:58 AM   #33
That sickening crunch..
Andy W's Avatar
No, sold it a little while back. Great model, but I have several larger models now.
..a
Andy W is offline Find More Posts by Andy W   Reply With Quote
Old Aug 26, 2008, 07:50 PM   #34
monster8's Avatar
My Dad and I just purchased one and put it together. Went with the AXI 2820/10, and Jeti 40 amp ESC.
We have two ThunderPower 3s 2100 prolite lipo packs in parallel. We can't balance the model with these packs. We have found, that it is going to take 3.6 ounces of weights near the motor to balance. I am hoping that will be ok? We are planning on just epoxying the weights in really well.
I am not sure how much weight we will lose by going with carbon fiber pushrods.
monster8 is offline Find More Posts by monster8   Reply With Quote
Old Aug 27, 2008, 06:12 AM   #35
Andy W's Avatar
Not much, but because it is so far behind the CG, you can lose a good bit of that lead.
..a
Old Sep 07, 2008, 11:24 PM   #36
LittleG's Avatar
Just ordered this model...
LittleG is offline Find More Posts by LittleG   Reply With Quote
Old Sep 13, 2008, 09:56 PM   #37
avee8r
Windmilling Prop
We have the AXI 2820/10, and Jeti 40 amp ESC turning a 13x7 CAM Folding Prop. The prop continues to windmill even after several adjustments to make sure that it will fold back without resistance if you hand hold the plane vertical. Any thoughts as to what we can do for a countermeasure to prevent the windmilling prop?
avee8r is offline Find More Posts by avee8r   Reply With Quote
Old Sep 13, 2008, 10:00 PM   #38
You have to set the BRAKE on the ESC to stop the motor. Then the prop will fold.
Old Sep 14, 2008, 12:02 AM   #39
avee8r
Brake, okay! We thought it was enabled, because the manual says by default it is enabled. But we just checked, and it was not enabled. So, we have switched it and that should fix it. thanks!
Old Sep 17, 2008, 11:22 AM   #40
LittleG's Avatar
Mine finally came in... Inspected the contents of the kit and surmised that the fuselage is a little thin... perhaps it is built this way to save on weight.
Old Sep 17, 2008, 11:53 AM   #41
Andy W's Avatar
Not at all.. it's quite sturdy.
..a
Old Sep 17, 2008, 01:23 PM   #42
LittleG's Avatar
How come there is so little talk about this glider on rcgroups? I would think this glider is comparable to E-flite's Ascent and there are so much more posts about the Ascent.
Old Sep 21, 2008, 08:41 PM   #43
tcarter's Avatar
I have been flying my Dust Devil for almost 2 years now, many flights. I have a Multiplex 4:1 gear drive motor with 13" folding prop. 2 Hitec 81 servos, and a Polyquest 2500 ma 3S battery (needed the nose weight). Awhile back I installed the winged shadow altimeter, I have had lots of thermal flights above 1600'. My longest thermal flight was 2 hours with a 6 second engine run to launch, landed cause my neck was getting tired. I fly it in winds, calm, whatever. Its a great plane for the cost, only thing I could say bad about it is I could never equalize out the downward pitch when spoilers are deployed, ran out of mix throw, but that may be a transmitter problem. . But I am used to it now and its a non issue. One other thing, I used carbon fiber rods to the tail instead of the wire pushrods, way better and saved nose weight. Also, I added an aluminum skid fin to the fuse bottom to help stop it on landing. Buy one and enjoy, I love it....
tcarter is offline Find More Posts by tcarter   Reply With Quote
Old Sep 21, 2008, 10:17 PM   #44
LittleG's Avatar
Can you post photos of the skid-modification or any modifications you made on this plane?
Old Mar 22, 2009, 11:18 PM   #45
SlightlyChilled's Avatar
I would like that
SlightlyChilled is offline Find More Posts by SlightlyChilled   Reply With Quote
Article Cox Models Christen Eagle ARF Review Thomas B Foamies (Kits) 74 Oct 15, 2009 11:01 PM
Article Cox Models new EP-380 Electric Trainer ARF Review Andy W Ezonemag Archive 17 Feb 04, 2009 05:15 PM
Article Dymond Model Sports Double Blitz -- the Blitz 2 -- Powered ARF Glider Review Don Sims Ezonemag Archive 14 Dec 23, 2006 10:40 PM
Cox Models Dust Devil reviewed on LiftZone Andy W Electric Sailplanes 0 Sep 17, 2005 08:32 AM
Cox Wings Dust Devil wattsup_kz Electric Sailplanes 2 Jul 29, 2005 11:16 AM
Bored? Want to fight?
Join the RCGroups clan!
