Old May 09, 2002, 05:53 PM
climber is offline
Find More Posts by climber
Joined Sep 2001
APC folding prop adaptor for Hacker motors
HI THERE;
What would be the best prop adaptor to attach an APC
9x5 folding prop with a 30mm spinner to a Hacker B20-xxx
with the gearbox attached?
Thanks, eh.
Craig
climber is offline Find More Posts by climber
Old May 09, 2002, 06:18 PM
MKH is offline
MKH
Find More Posts by MKH
MKH
Ohio
Joined Mar 2000
I looked into this once, but didn't get very far. Someone else posted that Icare could supply the right stuff, but I never got around to writing them. Thay are an Ezone sponsor. Also, Azarr sells APC folders and small Hackers, so he may have some info. Ecubed is his company name.
MKH
MKH is offline Find More Posts by MKH
Old May 10, 2002, 05:56 AM
Azarr is offline
Find More Posts by Azarr
RIP Azarr - "Old age is not for sissies"
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
Since the APC Folders have an 8mm prop hole, the real problem is finding a prop adaptor with a 3mm motor/gearbox shaft and an 8mm prop shaft, haven't found one yet, but with patience, you can shim the prop using various tubing combinations.
Azarr
ecubedrc.com
Azarr is offline Find More Posts by Azarr
Old May 10, 2002, 02:52 PM
GordonTarling is offline
Find More Posts by GordonTarling
Supersonic Engineering
GordonTarling's Avatar
UK, Greater London, Uxbridge
Joined Mar 2001
Forget the adaptor and use an integrated solution! I can supply a HM Lightspinner in whatever diameter you need, with the metal yoke bored to fit the 3mm shaft of the Hacker gearbox.
Gordon
GordonTarling is offline Find More Posts by GordonTarling
Old May 10, 2002, 07:26 PM
Sal C is offline
Find More Posts by Sal C
Giddy up!
Sal C's Avatar
Woodridge, Illinois
Joined May 2000
I bought an adapter from Kirk @ New Creations. I think it's a MP Jet. He supplied me with a sleeve also to fit inside the hub of the APC folder.
Sal C is offline Find More Posts by Sal C
Old May 11, 2002, 05:59 AM
Azarr is offline
Azarr's Avatar
Joined Jan 2000
Gordon
Unfortunately APC chose to go against convention and their blades are not drilled for a pin, you're required to use their hubs with their blades unless you modify/drill them yourself.
A shame really, since the blades seem very efficient. Of course, the spinner/yoke solution is a great solution for other brand folders.
Azarr
ecubedrc.com
Folding Prop Spinner for a Hacker B20 SteveR Electric Sailplanes 7 Apr 19, 2005 09:05 PM
5mm prop adaptor for APC props? Steph280 Flying Wings 2 Oct 30, 2004 06:01 PM
Finding a prop adaptor for APC SF? Anders Norrlid Power Systems 5 Oct 12, 2004 12:36 AM
Spinner for APC folding prop? pullin-gs Electric Plane Talk 2 Jan 08, 2004 05:19 PM
APC Slo Fly prop adaptor for GWS 100C GB costath Parkflyers 9 Nov 19, 2003 07:25 PM
