Old Sep 16, 2005, 01:34 AM
MoD_Eagle is offline
Find More Posts by MoD_Eagle
MoD_Eagle's Avatar
Joined Sep 2004
need help setting engine
I am very new at RC and have a question about my os .46fx I understand the needle valve settings but then there is the adjustment screw right inside the throttle/carborator. I don't know what it does or how to use it.
MoD_Eagle is offline Find More Posts by MoD_Eagle
Old Sep 16, 2005, 02:15 AM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
That's the slow-running adjustment. To check if you need to change its setting, start the engine and get it running nicely by adjusting the main needle (if you haven't already done so). Then open the throttle quickly from idle to full and observe what happens. If the engine speeds up smoothly without hesitation, no adjustment is needed; if the engine sounds like it's choking, and then dies, the slow-running needs to be leaned-off a bit; if the engine just dies without choking (no smoke), the slow-running needs to be opened up a bit.
Make only very small adjustments, as the idle needle is very sensitive. Turning it clockwise will lean it, and anti-clockwise will open it.
abenn is offline Find More Posts by abenn
Old Sep 17, 2005, 01:09 AM
MoD_Eagle's Avatar
Joined Sep 2004
hey, thanks man, I appreciate you helping me.
Old Sep 17, 2005, 07:58 AM
Viper Pilot is offline
Find More Posts by Viper Pilot
God is good
Viper Pilot's Avatar
Banjul
Joined Jan 2001
Originally Posted by abenn
That's the slow-running adjustment. . . .
ALso called the "idle valve".
Viper Pilot is offline Find More Posts by Viper Pilot
Need HELP Setting up an ECO8 with Futaba 8U in the Bay Area, California ropuri Electric Heli Talk 4 May 14, 2002 01:43 PM
Need HElp Setting up Voyager E in Southern California SoCalHeli Electric Heli Talk 2 May 07, 2002 04:38 PM
Need help setting up Hornet! Spaulding Electric Heli Talk 23 Mar 20, 2002 01:02 AM
Need help setting up Schulze ESC for heli... Jason M Electric Heli Talk 5 Feb 09, 2002 03:52 AM
Need help setting up Hornet Eddy Electric Heli Talk 0 Sep 15, 2001 05:12 PM
