I ordered an Excite F5D as well. Will try an Aveox 27/26/1.5Y, TP2100, and a 5x5 prop for ~ 35 amps. I would also like to fly it hotliner style (it looks like a mini RW2) with the same motor, but on 10 GP2000, a 3.3 (or 4.3) gb and a RFM 12.8x13 folder. Bring yours out to the VA F5B. |
Fairfax, VA
Joined Mar 2002
Ok, guys
Keep those hints and advice coming in (thanks plinse, for pic). I'm a sport flyer. My "small" fast planes are the Sokol and the Vortex ( on 10 cells) and I decided I wanted something "among the fastest." So, Excite is my first F5Der. Have never flown competitive pylon, but maybe one day it'll come to Virginia. After all, F5B contests came last year. Buy it, fly in, and they will come (ha, ha) |
As I have some D60 lying around, I will be using a D60 on my new Batleth that I just pulled from the molds. But according to the setup the Tokoloschi is better to compare with the Excite as the handling takes place from in front by removing to motor-cone. Even though the Batleth is a F5D according to the 2005 rules the setup has little to do with setting up an Excite. I discribed the whole setup of the Tokoloschi here, text is in German but there are many pictures. http://www.speed-mania.de/toko_ausbau.html Looking at the English part of my homepage I just saw that I have not changed the links there so just some of the pictures are displaied. It is also not discribed as precisely as English is still a language issue to me - especially in technical things. Quote:
I don't know where the CG of the Excite is - I just discribe my experiences setting up an F5D-airframe where the batterie is changed by removing a motor-cone. As the pictures on the strat homepage (www.strat.at) just show the airframe with the wing and the T-Tail put together I also asked whether there are service-openings below the wing. Or is the fuselage a closed pipe? This might make the diffrence between having to put the elevator servo onto a removable device or just bonding it to the fuselage. Can you access the place where you will have to mount it easily? The diffrences between Tokoloschi and Excite that make diffrences between my way to set up a Tokoloschi and the propably easiest way to set up an Excite are: The fuselage and wing of the Tokoloschi are glued together - the linkages are kind of finally assembled - no easy access later. Actually no solution that could be used on a commercial airframe. As the aileron servos of the Excite are inside the wing, there are no linkages and servos in the fuselage below the wing being in your way when changing the batterie, ... . Is there access to the elevator servo and the linkage when just gluing it into the fuselage? Or would an opening weaken the fuselage when cutting one in as it is not recommended? If you need to use a removable device: As I build my airframes myself I don't use plywood for mounting the things on - I prefer a part from an old fuselage or just build a small fiberglas part out of the fuselage mold - Plywood is about as good but just a little more work to make it fit well but that for you don't need the mold. At the moment I am just enjoying the perfect fit of the Batleth parts and the standard fuselage. The motor cone has the advantage to be able to adapt the fuselage to a slope glider or hotliner application. But the setup is more work and access to the components being installed is more difficult as well. On my 3 years old Tokoloschi I had to do some service some time and it really was a pain. As the aileron servos of the Excite are placed in the wing this is much better - easy access and simple linkages - on the other hand it is kind of vanity that I don't like linkages, visible on the outside on pylon racers. But we will see what the tests on my first batleths show - there is still the opportunity to make the 2 flap wing a 4 flap one and then there will be linkages visible as well .Eike |
Calgary, AB, Canada
Joined Oct 2002
I went for a 2 aileron wing at first - the webs for a full span aileron are molded in and according to the experiences I make with flutter I can cut them further as well as there is the remaining opportunity to install servos on the outside with covers - I could not mold them in anyway. The pictures so far are on my homepage: http://www.speed-mania.de/ -> Whats new -> Batleth I will go into some more details later but I don't think I am going to start a thread about it. Are you involved into getting the plugs to Canada? Eike |
Calgary, AB, Canada
Joined Oct 2002
. Might be interesting to contact them before the plugs are returned to Europe if building your own airframes is an option to you.The airfoils on the airframes have not changed dramatically so they are still thin - evolution but not revolution - and the wing root chord of the Batleth is similar to the wing root chord of the Tokoloschi. The main thing that was really changed to increase the wing surface is the aspect ratio that was increased quite a bit. Comparison between Tokoloschi and Batleth is quite impressive though. Especially as the aspect ratio of the Tokoloschi was about 10 already! I am looking forward to the maiden flight .Eike |
| Thread Tools | |
| Download Excite F5D lightweight - video | down_shift | High Performance | 23 | Feb 07, 2006 04:02 PM |
| Discussion Excite F5D Fastest Setup | soulys | High Performance | 42 | Jan 18, 2006 04:05 PM |
| Excite F5D lightweight | down_shift | High Performance | 57 | Jan 14, 2006 02:17 PM |
| Sold Excite F5D | MarcusT | Aircraft - Electric - Airplanes (FS/W) | 2 | Nov 28, 2005 09:24 AM |
| News from the Excite F5D + !! videos !!! | Elektrofly | High Performance | 15 | Sep 27, 2005 10:29 AM |
