Old Sep 15, 2005, 05:30 PM
borgs is offline
Find More Posts by borgs
Bristol, England
Joined Jan 2003
Overlord - which way should motor turn?
Hi,
I have an edge RC overlord with a standard Multiplex 400 motor on it (out of a Multiplex Cub). I reversed the prop on the motor as its a pusher configuration now. Looking from the back the prop is turning anti-clockwise and air seems to be being pushed towards the front of the plane. Does this sound like I have the motor wired the wrong way around?
If this is the case, what is the best way to fix it please. Can I simply re-reverse the prop (although it is superglued on mind)? Or, will the motor only work at full speed if I leave the prop as it is and reverse the motor connections?
Thanks alot,
Regards,
Steve
borgs is offline Find More Posts by borgs
Old Sep 15, 2005, 05:35 PM
birdofprey is offline
Find More Posts by birdofprey
The Magician.
birdofprey's Avatar
Lucas, Kansas
Joined Nov 2002
Steve,
Your only option is to reverse the motor. If you flip the prop over, it will still push the air the same direction. The prop must rotate clockwise when viewed from the behind the plane.
Justin
birdofprey is offline Find More Posts by birdofprey
Old Sep 15, 2005, 05:48 PM
borgs is offline
Bristol, England
Joined Jan 2003
Justin,
Thanks for the very quick reply!
I'll resolder tomorrow and then its time for the maiden flight - looking forward to it.
Cheers,
Steve
which direction should the rudder turn the tail? AkshunJebus Micro Helis 3 Sep 10, 2004 06:23 PM
which way does a motor pul crudpuppy Power Systems 4 Sep 04, 2004 01:21 PM
Which way should my prop turn? Mr.Dickles Power Systems 2 Apr 19, 2003 12:35 AM
which way should prop turn Rugerman Power Systems 7 Dec 22, 2002 09:23 PM
Wingo Porter - which way should the engines spin? pgesler Parkflyers 1 Jun 15, 2002 10:53 PM
