Old Sep 15, 2005, 03:57 AM
Flying for the fun of it
beep684's Avatar
Brisbane
Joined Sep 2005
how to find motor thrust
I've been reading a threaqd in the 3-d section, and there is a thread about a plane that runs off a cd-rom motor. Lot's of people have posted about their own Cd-rom motors, and almost all have said how much thrust it produced eg: 300g.
I am trying to figure out how to find out the amount of thrust. Do you need to attach a propeller and hang the motor from a set of scales? Can someone please help me find out how to find the amount thrust produced?
Beep.
beep684 is offline Find More Posts by beep684
Old Sep 15, 2005, 04:00 AM
Renewed interest
ozace's Avatar
Melbourne , Australia
Joined Jun 2002
If you do a search for motor test stands you will see the contraptions that are used to measure thrust. Some of the motor gurus have posted pics and diagrams of the tools they use.
ozace is offline Find More Posts by ozace
Old Sep 15, 2005, 05:30 AM
Naples
Joined Nov 2004
That is what you need - works great!
http://slofly.com/cart/index.php?cPath=27_139
hans
Loefflerh is offline Find More Posts by Loefflerh
Old Sep 15, 2005, 06:30 AM
beep684's Avatar
Brisbane
Joined Sep 2005
Thanks, very clever. Do you think that i could build one myself, or would the wooden arms have to be an exact length so as to not give mechanical advantage?
Old Sep 15, 2005, 06:53 AM
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
Try this link with pictures of the "new" Dick Hanson designed stand: look at Post #25 on.
http://www.rcgroups.com/forums/showt...thrust+checker
I've attached some additional photos
Cheers, Phil
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Sep 15, 2005, 12:03 PM
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Phil neither link works.
Charles
Old Sep 15, 2005, 01:24 PM
galloping gimp's Avatar
Ohio, USA
Joined May 2002
Another approach is to measure the RPM, then use a thrust calculator, such as the one at GoBrushless.com. If your prop is one of the 50+ props available in the calculator, the calculated thrust is reasonably accurate.
Actual measurement on a thrust stand is preferred, but for those of us who still haven't built one, the calculator is a nice tool. Thanks to JayC, MorrisM, and Dr. Kiwi for creating it.
- Jeff
galloping gimp is offline Find More Posts by galloping gimp
Old Sep 15, 2005, 02:49 PM
Dr Kiwi's Avatar
Joined May 2003
Charles
Sorry Charles - Try the edited version now.
Old Sep 15, 2005, 02:51 PM
Dr Kiwi's Avatar
Joined May 2003
- Jeff
I've mentioned this elsewhere, but I believe the calculated thrust outputs are a bit lower than they should be (old stand v. new stand!). We should update the data base.
Old Sep 15, 2005, 03:00 PM
MorrisM's Avatar
Oklahoma City
Joined May 2004
Phil, If you have new data from the new stand please email it to Jay and me. Maybe you even have some new props to add
I really appreciate all the time you have spent collecting prop data... thanks much
Morris
PS - Send to Rod(badcockr) also. His spreadsheet is nice.
MorrisM is offline Find More Posts by MorrisM
Discussion how to find a motor mount to change a motor for a plane nashiem Electric Motor Design and Construction 4 Aug 23, 2007 10:47 AM
How to get more thrust from my 920kV motor OzStriker Power Systems 8 Nov 23, 2005 04:47 AM
How to find Amps on can motor andyg Power Systems 1 May 27, 2005 10:38 AM
Still need info on how to retime a motor with an Astro Super Whattmeter Joe Elston Electric Plane Talk 8 May 19, 2001 11:42 PM
How Much Motor? How Many Batteries? hoppy Electric Plane Talk 3 Apr 29, 2001 05:16 PM
