Old Sep 13, 2005, 08:06 PM
_Lunchbox_ is offline
Find More Posts by _Lunchbox_
Hodgehound # 3
_Lunchbox_'s Avatar
Adrian, GA
Joined Mar 2005
Just flew my e-starter for the first time, now I have some questions.
I just finished the first flight of my e-starter. This is my first flight with a plane with ailerons. Overall, I am pleased with the flight. It did seem that the plane was underpowered though. It had a tendency to stall when climbing and when banking. It may be my dumb thumbs, but it was stalling at a relatively mild angle...say 45-50 deg. I do realize that the plane will not do straight vertical, but I really had to baby it to climb and I lost a good bit of altitude when turning also.
I am running it with the provided GWS EPS400c with a "D" gearing. I am using the included 1060 prop and a 9.6v 730Mah battery.
According to the GWS website the 1060 is a direct-drive prop. should I be using a 9070 or 1047 prop with this motor? will that battery handle the current draw from a 1047? According to the GWS website, that setup will pull about 11.6 amps. That is @ 15c right?
I would like to upgrade to Lipos, but it isn't an option right now as I have been grounded from the credit cards, paypal, and the checkbook.
I do have a 1600 Mah 9.6v battery, but I don't want to use it unless I have to. I would have to cut out part of the battery section in the plane in order to use it, and I wanted to wait to do any cutting until I did have a Lipo and a brushless motor for it. I do want to fly in the meantime though, so I need some help getting this plane flying better, or I'll wind up planting it.
_Lunchbox_ is offline Find More Posts by _Lunchbox_
Last edited by _Lunchbox_; Sep 13, 2005 at 08:34 PM. Reason: Just thought I'd include a couple of pics also as I am proud I didn't crash it
Old Sep 13, 2005, 08:47 PM
SuperHornet is offline
Find More Posts by SuperHornet
500FT & Climbing
SuperHornet's Avatar
Australia/Victoria
Joined May 2005
Jstone
I wouldnt cut out foam from your estarter just yet, I would go for a 3s 11.1v lipo and run the 9x7 gws prop, which would give you excellent performance, plus the lipo being lighter.
Your 400 series brushed motor will handle 11.1v easy as stated by gws technical support.
The 1047 will give you more thrust & less speed than the 1060, 9x7 is by far the best prop I have tried so far.
Just open the hole bigger in the nose and possibly cut 2 air intakes on the sides to allow the motor to cool with proper airflow.
SuperH
SuperHornet is offline Find More Posts by SuperHornet
Old Sep 13, 2005, 09:03 PM
Montag DP is offline
Find More Posts by Montag DP
Sink stinks
Montag DP's Avatar
Joined Apr 2005
A 10x4.7 propeller should draw less current than your 10x6, and so would most likely take away power from your airplane, with all else being the same. I guess the only exception to this would be if the 10x6 was too much and the motor overheated and lost efficiency, but I doubt that. I have to agree with SuperHornet, though; go to lipos and you'll never look back!
Montag DP is offline Find More Posts by Montag DP
Old Sep 13, 2005, 09:07 PM
Hodgehound # 3
_Lunchbox_'s Avatar
Adrian, GA
Joined Mar 2005
I'd like to upgrade to lipos, but lack the funds. Actually.... I'd LOVE to upgrade to lipos.
Is there a difference in the SF and the Direct drive props? I know the SF props look more curved and the DD look more straight,,,
Old Sep 13, 2005, 10:06 PM
NanoSio2 is offline
Find More Posts by NanoSio2
Remember the 131st TFW MO ANG
NanoSio2's Avatar
USA, MN, Apple Valley
Joined May 2005
Hi - An E-Starter was also my first aileron plane. Stick with it - it is a great little bird. I am thinking about buying another one (first one took quite a beating with some major crashes, and it is carrying a lot of epoxy around now, but still flies) and building it up as a bush plane. I will probably put some larger foamy wheels on it, flaperons, and go brushless, plus give it a cool paint scheme.
Anyway - mine had the 400 motor as well and it was nose heavy. I had to add weight to the tail to get it to balance. It climbed like a pig but was fun to land because of a solid glide and scale appearance. A buddy just built one and used the GWS 350 motor (lighter). Admittedly, he is running a 2-cell, 1400mah lipo, but I noticed a difference in mine just by moving from a NiCd to a 8.2 700mah NiMH. You may want to consider the lighter motor - I think the motor is probably around ~$10. He did not have to add any weight, so his is lighter, and although it does not go vertical either, it climbs with a lot more authority. I forget what my All Up Weight was but I think it was around 19oz, which is pretty heavy for an E-Starter. I think his is around 14-15. Also, he opted to not use the struts, and instead secures the wing with rubber bands.
Good luck!
Scott
Edit P.S. I was flying it with the stock 10x6 prop as well
NanoSio2 is offline Find More Posts by NanoSio2
Old Sep 13, 2005, 10:55 PM
babblefish is offline
Find More Posts by babblefish
Yes, that is Jamie
babblefish's Avatar
SF Bay Area, CA
Joined Jul 2002
Your motor is probably starving for voltage preventing it from reaching maximum RPM. Please be aware that your 730mAh battery pack cannot supply 15C worth of current. The most you're going to get is 5 or 6C from those cells before the voltage starts to drop off significantly. Since you're on a tight budget, try either a KAN 1050mAh or GP 1100mAh battery pack. These will weigh less than your 1600 pack and they can supply 15A and 20A respectively.
babblefish is offline Find More Posts by babblefish
Old Sep 13, 2005, 11:10 PM
rgoble is offline
Find More Posts by rgoble
rgoble's Avatar
Dayton Montgomery, Ohio, United States
Joined Sep 2004
Somone once told me that GWS Direct Drive props are thinner so you can get away with going up a size bigger, however I am not sure if it correct or not. I flew mine with the GWS 400 speed motor and the D gearing, but I used an 1180 DD prop with a 3s1p 1200mAh lipo and it flew decent. Although I did burn out my first motor so that may not be the best idea.
My friends eStarter flew like a brick with the stock motor/prop and a 750mah NiMH. He had to stay at almost full throttle the whole time to keep it in the air. Also as Scott pointed out some people have gotten them to fly better by using the smaller 350 motor.
rgoble is offline Find More Posts by rgoble
Old Sep 13, 2005, 11:29 PM
tic is offline
tic
Find More Posts by tic
tic
thunderscreech
tic's Avatar
United States, MI, Gaylord
Joined Dec 2000
I would sell the e-starter and buy an RFM surprise 13 or 14 with a Neu motor... It won't stall even at 90 degree climb angles!
tic is offline Find More Posts by tic
Old Sep 14, 2005, 08:05 PM
flypaper 2 is online now
Find More Posts by flypaper 2
I use foam to hold my hotglue
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Size for size the HD and DD props are more efficient than the SF props. I've found, for the same performance, the throttle is noticeably lower and the batts last longer.
flypaper 2 is online now Find More Posts by flypaper 2
Old Sep 14, 2005, 08:12 PM
Hodgehound # 3
_Lunchbox_'s Avatar
Adrian, GA
Joined Mar 2005
I have a couple of extra 350 motor/GBs that I use on my SS laying around. I think I will fix one of them and give it a shot.
I did find that the e-starter was nose heavy and had to add a 1/4 and 1/8 oz sinker to the tail to get it to balance. Even then it is still a little nose heavy.
What size prop is best for a 350 on the e-starter? I'm using a 12x6 on my ss now. that would be too much prop wouldn't it?
Old Sep 14, 2005, 09:44 PM
Sink stinks
Montag DP's Avatar
Joined Apr 2005
Now that would be a good first aileron plane.
Old Sep 14, 2005, 11:26 PM
OhioPete is offline
Find More Posts by OhioPete
Lazy dog
OhioPete's Avatar
Lakewood, Ohio
Joined May 2005
Hi! I'm "the buddy" I just weighed my plane with battery at 14.7 oz. I put a 350C "C" gear motor in mine with a 1047SF prop instead of the supplied 400C "D" gear with a 1060DD(IIRC). I added a longer than stock length of CF rod in the wing instead of the bamboo skewer and left off the associated wing attaching pieces. I left off the wing struts as well since all they are is weight and drag with the CF rod in the wing. I use rubber bands to secure the wings. I run either a 2S 1700 Etec or a pair of 2S 700's that I wired in parrallel. As Scott mentioned it will move out pretty good. He even found out that it will fly with the prop on backwards I had Scott maiden my plane since he's had one a while. I figured he could tell me if it was setup properly. Well, I handlaunched it for him and to his credit he flew it pretty well. He did comment that it seemed awful sluggish and low on power. Well I took a look after he brought it in...dummy me put the prop on backwards After I got that taken care of he flew it again. It moved out very well. His initial climb out was probably at about a 60-70% angle. It's flown well for me since then.
Other than maybe taking the gear off to save a little weight and getting a more powerful battery I don't know of any other way to make it work better. I would invest a couple of bucks in a 350C motor and a prop myself. Step up to lipos when you can afford it.
EDIT: The DD props are noticable "thicker" than the SF props, they have less flex to them and are made to spin at higher RPM's (Direct Drive) than the SF (SlowFlyer) props which are made to run slower on geared motors. They also have more "squared off" ends. I use a 1060DD on my Spitfire which is running a 400C "D" gear with a 3S (11.1 volt) lipo.
OhioPete is offline Find More Posts by OhioPete
Old Sep 15, 2005, 09:02 PM
kave_man is offline
Find More Posts by kave_man
....PieMaster....
kave_man's Avatar
United States, GA, Warner Robins
Joined Aug 2004
Put the 350 with a c gear in the e-starter and a 9X7 prop. This is what i had for a while.
(brushless)
kenny
kave_man is offline Find More Posts by kave_man
Old Sep 16, 2005, 05:31 PM
Hodgehound # 3
_Lunchbox_'s Avatar
Adrian, GA
Joined Mar 2005
Would a 350 "D" work ok with a 1047 prop and a 9.6v battery for the e-starter.?
I was thinking of putting thw 400 "d" on my Slow stick. Would it be ok to put a 1260 prop on that? I can't find a 1260 on any of the 400 motor/GB charts.
Old Sep 16, 2005, 05:33 PM
Hodgehound # 3
_Lunchbox_'s Avatar
Adrian, GA
Joined Mar 2005
where can I look this plane up at?
My b-day is coming up..... I was thinking of brushless for the e-starter, but.....
How long should I charge my transmitter battery for the first time?? KZZ Batteries and Chargers 14 May 04, 2008 01:16 PM
Discussion I flew my Pike Superior for the first time today. Lance Prior Sailplane Talk 2 May 11, 2007 06:43 AM
Discussion Finally flew my easy star for the first time!!! IamLegend Parkflyers 2 Sep 25, 2006 03:58 PM
My son soloed for the first time. Even landed! eBird Parkflyers 9 May 25, 2003 09:50 AM
I took my baby up for the first time blixem Foamies (Kits) 2 Nov 19, 2001 03:05 PM
