Old Sep 13, 2005, 03:20 PM
Ahhgh! Not ANOTHER new plane!
Robert Stinson's Avatar
San Diego, CA
Joined Dec 2001
Slow-G Twin Rotor Autogyro build thread
I received one of "Iter's" conversion kits, to make a GWS Slow Stick in to a twin rotor autogyro. I won't be able to pick up a SS until next week. Although eventually I will "brushless" it, I'm going to start out with the stock plane. Iter, which motor setup do you recommend? I presume at least the 300, and probably the 400?
Robert Stinson is offline Find More Posts by Robert Stinson
Old Sep 13, 2005, 04:10 PM
iPhly R/C with iPhone
iter's Avatar
Silicon Valley, Calif
Joined Jan 2005
I've seen people put all sorts of torque monsters into Slow-Gs, but all of my prototypes and production test models have flown quite well with the stock Speed 300 motors in "C" or "D" gearboxes. Because Slow-G works at low airspeeds, a "D" with a 1180 prop may work better than a "C" with a smaller prop.
Keep it light, and you won't need a large motor :=)
Hope you enjoy the kit!
Ari.
iter is offline Find More Posts by iter
Old Sep 14, 2005, 09:59 PM
San Diego, CA
Joined Dec 2001
Hi Ari;
I'm assembling your kit now. Everything is fitting together neatly. Hurrah for lasers! I do have a question; I think I goofed regarding the parts you sent me. I thought they were replacement caps for the 1/32" ply pieces, so I glued the 3/8" balsa hub to the rotor base. How about if I glue the 3/32" ply cap on top of the 3/8" balsa? That should work, right? The shaft is long enough to accommodate this.
You're right about those e-clips on the GWS rotor shafts! One went flying through the air. I've done that enough with small parts that I know to go silent & motionless to hear where it lands, and I found it.
Oh, by the way, what battery did you use with the 300 C or D?
Old Sep 14, 2005, 11:24 PM
iter's Avatar
Joined Jan 2005
I use ThunderPower 730.
As for 3/16 doublers, the reason I introduced them was that the 3/8 balsa squares were too soft. After you've been flying your Slow-G for a while, you find that they sag.
If you haven't glued the wedges and blades on yet, I'd say cut the balsa squares off, sand the base plate and put plywood parts there. If you have already glued the blades on, don't worry about it, just make sure you check that your top nuts are tight before every flight. If you're feeling adventurous, you can trim the balsa squares flush with the blades, that way there won't be as much balsa to sag (make sure the top is parallel to the base plate). Use 3/32 doublers to reinforce cut-down balsa. If you keep full-height balsa spacers, it doesn't matter much which plywood you use to reinforce the top.
HTH, Ari.
Old Sep 15, 2005, 07:02 AM
San Diego, CA
Joined Dec 2001
Thanks. Since the wedges are already in place, I'll shave the squares flush with them.
Old Sep 15, 2005, 07:45 PM
San Diego, CA
Joined Dec 2001
I covered the blades with Monokote trim sheets. They are adhesive-backed and don't require shrinking,which might warp the blades. Three white and one black blade on each side.
Ari; are the advancing blades inboard or outboard? Just checking.
Old Sep 16, 2005, 05:48 PM
iter's Avatar
Joined Jan 2005
With the rotor marked "R" on the right and "L" on the left, you should get advancing blades on the inside. If you don't, check that you assembled the rotorheads corectly :=) See some discussion about this here: http://www.rcgroups.com/forums/showthread.php?t=408555
Ari.
Old Sep 16, 2005, 06:42 PM
San Diego, CA
Joined Dec 2001
I have it correct - just checking. I imagine advancing inside reduces the chances of blade strikes. Well, I got a Slow Stick, so before too long we'll have a launch...
Old Sep 16, 2005, 08:00 PM
iter's Avatar
Joined Jan 2005
Good luck and let us know how it goes!
Ari.
Old Sep 18, 2005, 05:48 PM
San Diego, CA
Joined Dec 2001
First flight today: pretty "staggery" thru the sky. Had a cross wind most of the morning, finally backed enough so I could ROG it. Did a few circuits, finally made a downwind turn that I couldn't recover from. Crashed, shed the blades.
Fortunately, the weak point of the setup is the wedges. They break before a blade does, and one can simply glue them back. My problem appears to be that one rotor hub spins easier than the other. It's not the relative bearing of the wind, because it happens when the wind is on either side, or from dead ahead. Dunno if it is a bearing problem, or a blade problem. I'll be switching the hubs to see which it might be.
It's a lot of fun in the air, though. It'll fly again next week.
Old Sep 20, 2005, 01:14 PM
San Diego, CA
Joined Dec 2001
Switched gearboxes left to right. It's definitely the gearbox, since now it's the left side that doesn't spin as fast. Guess I'll shop for a replacement. Iter, what was the GWS stock number?
Old Sep 20, 2005, 01:45 PM
iter's Avatar
Joined Jan 2005
GWS part numbers are listed in the manual:
gearbox housings GWS part #LPS5A
gearbox shafts GWS part #LPS6A
ball bearings GWS part #LPS2A
But let me see if I understand this right. The rotor on the right ("R") was spinning slower, then you swapped rotors around and now the rotor on the left ("R") is spinning slower? If this reading is correct, the bearings are working fine.
Ari.
Old Sep 21, 2005, 10:05 AM
San Diego, CA
Joined Dec 2001
No,, I swapped gearboxes. If I'd swapped rotors, they'd be rotating the wrong way (backward inboard).
Old Sep 21, 2005, 03:32 PM
iter's Avatar
Joined Jan 2005
I see. I have gearbox parts in stock, let me know if you can't find them locally and I'll be happy to mail you what you need.
Ari.
Twin Lizzy Electric Build Thread Ragwing Vintage & Old-Timer Designs 30 Aug 29, 2009 11:54 AM
Discussion Slow G autogyro build questions GyroRon Auto Gyros 3 Mar 17, 2007 04:45 PM
Twin Boom A/P Slow Stick "Dragon" pusher build thread. CactusJackSlade Aerial Photography 37 Apr 28, 2006 10:07 PM
My very short G-Ride build thread Abomination Parkflyers 24 May 02, 2004 11:21 AM
Worst builder on ezone G-Ride build thread Goleith Parkflyers 3 Apr 14, 2004 06:39 PM
