Old Apr 17, 2007, 03:40 AM
dunc2504 is offline
Find More Posts by dunc2504
I SEE NO SHIPS
dunc2504's Avatar
Somerset England
Joined Feb 2007
825 V 750 Engel tank
Hi
I put in the 825 tank because I could.
The metal mech tray allowed the bigger tank to fit.
I use the extra tank capacity to set the boat perfectly on the waterline without messing with lead ballast.
I can allso take the boat right under , or any level I want as the tank is fully preportional.
From what I have read the 750 is perfectly ok fpr static dive ,but the bigger capacity just gives me more flexibillity.
dunc2504.
dunc2504 is offline Find More Posts by dunc2504
Old Apr 17, 2007, 01:36 PM
castor3 is offline
Find More Posts by castor3
Joined Apr 2007
i have read that the 75 was not big enough and the consequence is that the boat wasn't perfectly on the waterline
castor3 is offline Find More Posts by castor3
Old Apr 18, 2007, 03:17 AM
dunc2504 is offline
I SEE NO SHIPS
dunc2504's Avatar
Somerset England
Joined Feb 2007
Hi
You may be right.
But I think that the 75 is the biggest you can get in with the standard plastic tray.
I used an aftermarket metal tray which has lots of room for an 825 tank.
Regards.
dunc2504.
Old Apr 18, 2007, 01:08 PM
castor3 is offline
Joined Apr 2007
you have used piranha "Technikgerüste " ? is it big enough ?
Old Apr 18, 2007, 02:45 PM
castor3 is offline
Joined Apr 2007
hello, i have forgotten to ask you 2 questions:
which accus have you put
which speed controler
thanks a lot for your help
Old Apr 18, 2007, 05:47 PM
dunc2504 is offline
I SEE NO SHIPS
dunc2504's Avatar
Somerset England
Joined Feb 2007
Hi
No problem.
That is what I used.
dunc2504
Have you any pictures?
Old Apr 22, 2007, 11:35 AM
dunc2504 is offline
I SEE NO SHIPS
dunc2504's Avatar
Somerset England
Joined Feb 2007
Working torpedo setup
I have finally managed to fit in my version of airbrush proppelant powered torps.
The torps are alloy tube with alloy valves for filling and ptfe noxxle at rear.
I was going to use a valve arrangement but tried the pin method first , it works fine for me.
Torps are fitted with the pins ang given a liquid charge.
Pushed down the tubes and the pins clipped onto the servo links , ready to go.
I used a Futaba servo , warerproofed with epoxy and a viton "o" ring under the servo arm, Seems to work fine.
Fired the system on dry land and the torps exit the tubes with quite some speed.
Torps tested in circular test pool ran for arround 15 seconds on a liquid charge.
All that remains now is to test the whole plot in the local pool , when I get the chance.
I will try to get some pictures of the event.
dunc2504
Old Apr 22, 2007, 12:30 PM
SJ is offline
SJ
Find More Posts by SJ
SJ
SJ's Avatar
Denmark EKCH
Joined Apr 2001
hehe...that is fantastic Dunc.
The detail you have given your sub is amaizing.
SJ is offline Find More Posts by SJ
Old Apr 26, 2007, 09:39 AM
ThunderboltV12 is offline
Find More Posts by ThunderboltV12
Joined Jan 2007
Originally Posted by dunc2504
I have finally finished my Robbe U Boat.
Well when I say finished , I meen until I work out how to actuate the bow doors and fit a carbon dioxide system to fire the tubes.
I spent days putting the rivet and weld details on the hull , as it looked just too smoothe and uninteresting.
I have taken some shots of how I packed all the radio and stuff into the watertight compartment.
Comments please, especially from anyone who has fitted working tubes to one of these boats.
Stupid question. Why does your U-47 look so much different on the inside than my U-47?
ThunderboltV12 is offline Find More Posts by ThunderboltV12
Old Apr 27, 2007, 02:09 PM
dunc2504 is offline
I SEE NO SHIPS
dunc2504's Avatar
Somerset England
Joined Feb 2007
Hi
If you read the text on my posting , you will see I have used an aftermarket mech tray and Engel piston tank to give static dive.
I assume your u47 is standard.
dunc2504
Old Apr 27, 2007, 03:19 PM
castor3 is offline
Joined Apr 2007
hello, is it possible to use 12 volt for the motors and 6 volt for the motor piston tanks ?
Old Apr 27, 2007, 06:04 PM
dunc2504 is offline
I SEE NO SHIPS
dunc2504's Avatar
Somerset England
Joined Feb 2007
Hi
Of course you can use whatever voltage you want if you use seperate cellpacks for the drive motors and radio/piston tank.
dunc2504
Old Apr 28, 2007, 02:11 AM
castor3 is offline
Joined Apr 2007
this is what you've done ?
Old Apr 28, 2007, 02:47 AM
dunc2504 is offline
I SEE NO SHIPS
dunc2504's Avatar
Somerset England
Joined Feb 2007
Hi
No, I used 9.8 volts fordrive and 6 volts for radio and tank, as that was all the cells I could fit in. It was getting a little cramped in there.
dunc2504
Old Apr 28, 2007, 11:09 PM
Joined Jan 2007
Who makes that tray? I want to get that instead of the thing I have there right now.
Problems with Robbe U-47 English Nige Submarines 29 May 26, 2015 01:17 AM
Build Log Building the Robbe U-47 P. Tritle Submarines 61 Nov 09, 2008 10:53 AM
For Sale FS: Robbe U-47 Complete ThunderboltV12 Boats (FS/W) 2 May 28, 2007 08:18 AM
Sold Robbe U-47 vett Boats (FS/W) 0 Jun 11, 2006 08:09 AM
Robbe U-2540 1jordis Submarines 0 Nov 15, 2004 04:18 PM
