Old Jan 06, 2007, 12:05 PM
HorribleHarry is offline
Find More Posts by HorribleHarry
Irregular... need..fiber!
HorribleHarry's Avatar
a snazzy little suburb of L.A. called Encino
Joined Jul 2005
Nice orange boats!!! LOL that's the first thing i'm going to do!
oh yeah, nice VII too!
CH!
HorribleHarry is offline Find More Posts by HorribleHarry
Old Jan 07, 2007, 12:06 AM
SJ is offline
SJ
Find More Posts by SJ
SJ
SJ's Avatar
Denmark EKCH
Joined Apr 2001
SJ is offline Find More Posts by SJ
Old Feb 11, 2007, 12:47 PM
cougar33 is offline
Find More Posts by cougar33
cougar
cougar33's Avatar
waterloo . Ontario
Joined Sep 2005
ok first things first
thanks guys for TELLING ME THE PARTS JUST SNAP OUT . lol aftr working witha scroll saw, sharpe knife and excato blade, band saw. my friend came over and looked at it. then SNAPPED IT OUT. grrrrrrrrrrrrrrr. anyway all parts are out in less than 1 hour. and in real good shape. all they needed was a little cleaning up . dont you hate these young guys who just come in and in 5 minutes make you feel sooooo old .
anyway. the tray is done. and the center hull is now out. just needs to be cleaned up. i did notice that the deck is alot wider that the hull. but that could also be , just trimming needed.
the one question i have for all the u47 drivers here. how did you hook up your bow planes. i saw somebody glueing the servo to the top of the wtc. this looks good at first? but what if you need to get access to it?. has anybody thought of making a little wtc in the bow. you can get access to that thought the deck. of thought the bottom hatch?. not sure yet how you would attach it to the reciever.
but the boat is under way now. and with luck . i should have pictures soon
i think 750-800 ml ballast tank should be enough to sink this thing
cougar33 is offline Find More Posts by cougar33
Old Feb 11, 2007, 01:04 PM
SJ is offline
SJ
SJ
SJ's Avatar
Denmark EKCH
Joined Apr 2001
I installed mine in the front of the WTC...and yea it will be a pain to get at if something goes wrong. Just make sure the setup is bulletproof before installing it :-)
Old Feb 12, 2007, 02:06 AM
magpie90 is offline
Find More Posts by magpie90
Boat-aholic
magpie90's Avatar
Melbourne Australia
Joined Dec 2005
My servo is under the sail/tower and the wire goes through the back end cap via brass through rods glued in and more wire up to the ADC4 at the front of the tray. It works well and the sail comes off easily to get to the mount screws for the servo. I've had it out a few tomes for oring replacement and checking and no worries mate!
As I posted earlier, it's all on my build pages at http://magpieyachts.com/building7.html
Jason
magpie90 is offline Find More Posts by magpie90
Old Feb 18, 2007, 06:01 PM
dunc2504 is offline
Find More Posts by dunc2504
I SEE NO SHIPS
dunc2504's Avatar
Somerset England
Joined Feb 2007
myu47
Hi.
I am reaching completion of my ROBBE U47.
Only the weathering to do now.
What a great builders model.
I used an Engel tank,Pihrana mech tray,Uboot conning tower and deck set,Homemade watertight enclosure for forward dive plane servo.
I will post further pics of the Mech tray later,as it is much better than the plastic Robbe item.
I allso used the prop shaft seal kit from Uboot,which is 100%watertight.
[IMG][/IMG][IMG][/IMG][IMG][/IMG][IMG][/IMG]
dunc2504 is offline Find More Posts by dunc2504
Old Feb 19, 2007, 07:45 AM
SJ is offline
SJ
SJ
SJ's Avatar
Denmark EKCH
Joined Apr 2001
VERY VERY NICE ! :-)
looking forward to pics from the inside.
Old Mar 29, 2007, 06:45 AM
SJ is offline
SJ
SJ
SJ's Avatar
Denmark EKCH
Joined Apr 2001
That turned out pretty well... :-)
Congratulations!
Old Mar 30, 2007, 03:02 AM
herrmill is offline
Find More Posts by herrmill
Shanghai'd Expat
herrmill's Avatar
Xiaoshan, China
Joined Jun 2006
Looks like a very nice build. Be sure to post your launch & maiden voyage photos.
herrmill is offline Find More Posts by herrmill
Old Apr 01, 2007, 02:01 AM
dunc2504 is offline
I SEE NO SHIPS
dunc2504's Avatar
Somerset England
Joined Feb 2007
Thanks for the comments.
I have found info on a website on how to build and fire torps powered with airbrush proppelant, soI am going to fit out the lower tubes.
I will post the results when I have a workins sollution.
Worst part will be cutting open the lower doors in the hull.
dunc2504
Old Apr 01, 2007, 09:57 AM
aferguson is offline
Find More Posts by aferguson
Joined Apr 2006
How far will the torpedoes shoot and where are you going to get the torpedoes?
aferguson is offline Find More Posts by aferguson
Old Apr 01, 2007, 10:42 AM
himszy is offline
Find More Posts by himszy
Scratch Builder
himszy's Avatar
Birmingham, England
Joined Sep 2004
You make(cast) the torps
Michael
himszy is offline Find More Posts by himszy
Old Apr 01, 2007, 02:23 PM
dunc2504 is offline
I SEE NO SHIPS
dunc2504's Avatar
Somerset England
Joined Feb 2007
I am using ally tube and turned nylon to make my torps.
I have made valves for the firing section at the rear, rather than just ramming a pin into the back ( seems rather hit and miss to me ).
So to open the valve I use a firing pin to push the assembly 2mm forwards.
I am still playing with nozzle sizes , but the valve system works vey well.
I use a woods type valve under the front cover for filling.
dunc2504
Old Apr 16, 2007, 05:52 PM
castor3 is offline
Find More Posts by castor3
Joined Apr 2007
static u47
[hello, i'm french and i'm building a static u47, why have you put 825 and not 750 ballast ?, what is the best receipter (robbe rokraft 120)
thanks for your help
here is the photo of my first u47
castor3 is offline Find More Posts by castor3
Problems with Robbe U-47 English Nige Submarines 29 May 26, 2015 01:17 AM
Build Log Building the Robbe U-47 P. Tritle Submarines 61 Nov 09, 2008 10:53 AM
For Sale FS: Robbe U-47 Complete ThunderboltV12 Boats (FS/W) 2 May 28, 2007 08:18 AM
Sold Robbe U-47 vett Boats (FS/W) 0 Jun 11, 2006 08:09 AM
Robbe U-2540 1jordis Submarines 0 Nov 15, 2004 04:18 PM
