Old Sep 20, 2005, 10:58 PM
SJ is offline
SJ
Find More Posts by SJ
SJ
SJ's Avatar
Denmark EKCH
Joined Apr 2001
I want to make mine the 1939 version like the first picture.
It seems to have the small wave breaker (wintergarden?) on the conningtower.
The robbe tower has the full wavebreaker, which only the later models had right?
the 1938 u-47 had no wave breaker at all as picture 2.
The third picture shows the little wavebreaker on the tower, but Im not sure that this is the U-47. It seems to have too many flooding holes right under the tower section on the hull.
Its not easy
I have found pictures of a scale model, that seems to be acurate....exept the color scheme. Last 2 pictures
What do you think ?
SJ is offline Find More Posts by SJ
Old Nov 24, 2005, 02:46 PM
scot101 is offline
Find More Posts by scot101
Joined Nov 2005
SJ - what did you find to be the best method of cutting the plastic parts from their sheets? I've tried a fresh bladed stanley knife, but it doesn't seem particularly effective. Was thinking of using a cutting disc on a dremmel or similar but worried about melting the plastic. Any thoughts would be appreciated. regards Roddy
scot101 is offline Find More Posts by scot101
Old Nov 24, 2005, 03:16 PM
SJ is offline
SJ
SJ
SJ's Avatar
Denmark EKCH
Joined Apr 2001
no no no......much easier :-)
Take a piece of scrap plastic. Then just scribe a line in it. Then bend the plastic over the scribbed line, SNAP! it says it now in two parts with a very clean "cut"
Each hull piece only takes 2 minutes to remove the surounding plastic.
Old Nov 24, 2005, 04:14 PM
Ron Keller is offline
Find More Posts by Ron Keller
Ron Keller's Avatar
holland
Joined Nov 2005
hello,
The easy way is not always the best way .
cutting the platic with a sharp stanley knife is better ,it takes a while.
But it is better because when you break it you displace all the molecules
in the plastic and is bad for your model.
my best regards,
Ron
Ron Keller is offline Find More Posts by Ron Keller
Old Nov 24, 2005, 05:56 PM
SJ is offline
SJ
SJ
SJ's Avatar
Denmark EKCH
Joined Apr 2001
how is this bad for the model Ron ?
Old Nov 24, 2005, 06:01 PM
U812 is offline
Find More Posts by U812
Joined Sep 2002
I've been doing it like that for years. Merriman shows it over and over again in his instruction videos. I have never had any problem scoring and breaking. Ever.
Steve
U812 is offline Find More Posts by U812
Old Nov 24, 2005, 06:44 PM
spongjim is offline
Find More Posts by spongjim
jim
United States, AL, Bessemer
Joined Jan 2005
Try a scroll saw to cut out the parts, alot faster and very easy . I bought one the first day I got the 47 kit and bought a table top belt sander the next day. Makes this kit alot easier to build. Oh yea you will need a good shop vac. also, makes a big mess.The 200.00 to 250.00 you spend will be worth it to you in the long run.
SJ how is your sub going ?
Jim
spongjim is offline Find More Posts by spongjim
Old Nov 24, 2005, 06:48 PM
Ron Keller's Avatar
holland
Joined Nov 2005
sj,
the bulkheads gives no problems but the boat it self must at all cost
cut with a stanley knife so you need not much to sand .
Your boat lookes very nice but the paint does not compare with the real
U-47,and I know I have the same problem.
How do I place a picture on this forum?????
my best regards,
Ron
Old Nov 24, 2005, 07:06 PM
U812 is offline
Joined Sep 2002
Ron,
Go to advanced post. Write your post. Then scroll down and you'll see manage attachments. Click on that and you'll get a new window. Link on the little boxes that say browse and select a picture from you hard drive and click ok. Then click load image. When it's done close the window and post you're reply.
Steve
Old Nov 24, 2005, 07:18 PM
SJ is offline
SJ
SJ
SJ's Avatar
Denmark EKCH
Joined Apr 2001
Jim, I have not built any more than the pictures show. Im building a jet at the moment which is taking up my time :-) Ill get back to the sub as soon as possible :-)
I have used the "snap plastic" method for 15 years now all ranging from RC to static models without any problems at all.
Anyway, the grey paint is primer.
What are the true colors of these boats anyway ?
Old Nov 24, 2005, 07:33 PM
Ron Keller's Avatar
holland
Joined Nov 2005
sj,
you need a few days patient I must look for the colours and comparisons of the U-47
And THEN I must place them on this forum.
cheers,
Ron
Old Nov 25, 2005, 04:59 AM
scot101 is offline
Joined Nov 2005
SpongJim
What type of scroll saw did u use? I have an old one here with a woodcutting blade, but it tended to melt the plastic rather than cut it!
regards Roddy
Old Nov 25, 2005, 07:49 AM
17b is offline
17b
Find More Posts by 17b
17b
17b's Avatar
Viersen, Germany
Joined Jul 2004
Hi U-47 Lovers,
two little tips:
Some Guys in Germany use an additional Ballast System in the Bow and Stern to make it come out higher out of the water. They use a gearpump (hope this is the right word) to pump water in and out a tank made of plasticsheets or PCB material. The air within the tanks escapes somewhere in the top of the sail. With this they preflood the Sub and kill the leftover buoyancy with a Pistontank which can be smaller (500ml).
Most Guys over here hate the original sail and substitute it with one of those highly detailed resin sails. Unfortunately they are much heavier than the original one even when thea are dremeled out, so they blow polyurethane foam into the space between WTC and Hull and add some lead in the bottom of the hull. This works very good and makes the hull more stiffy.
Regards
Stefan
17b is offline Find More Posts by 17b
Old Nov 25, 2005, 08:45 AM
SJ is offline
SJ
SJ
SJ's Avatar
Denmark EKCH
Joined Apr 2001
Stefan you need to find pictures of this! :-)
it sounds very interesting
Old Nov 25, 2005, 09:50 AM
Sub culture is offline
Find More Posts by Sub culture
Man from Atlantis
Sub culture's Avatar
London
Joined Nov 2003
You could also utilise the saddle tanks as space for additional ballast tanks.
You must flood them completely though, to avoid sloshing.
Andy
Sub culture is offline Find More Posts by Sub culture
Problems with Robbe U-47 English Nige Submarines 29 May 26, 2015 01:17 AM
Build Log Building the Robbe U-47 P. Tritle Submarines 61 Nov 09, 2008 10:53 AM
For Sale FS: Robbe U-47 Complete ThunderboltV12 Boats (FS/W) 2 May 28, 2007 08:18 AM
Sold Robbe U-47 vett Boats (FS/W) 0 Jun 11, 2006 08:09 AM
Robbe U-2540 1jordis Submarines 0 Nov 15, 2004 04:18 PM
