Old Sep 15, 2005, 08:26 PM
SJ is offline
SJ
Find More Posts by SJ
SJ
SJ's Avatar
Denmark EKCH
Joined Apr 2001
a few more pics
SJ is offline Find More Posts by SJ
Old Sep 15, 2005, 08:36 PM
afc is offline
afc
Find More Posts by afc
afc
Massachusetts, USA
Joined Jun 2004
SJ,
I like the detail on you con-tower. You boat will turn out quite nicely (I am now inspired to upgrade the detail on my con-tower).
afc
afc is offline Find More Posts by afc
Old Sep 15, 2005, 09:10 PM
U812 is offline
Find More Posts by U812
Joined Sep 2002
Man your moving. Nice build. And guess what? It will never hit the pavement and burst into flames! I hardly fly anymore but I still love it and still do.
Steve
U812 is offline Find More Posts by U812
Old Sep 15, 2005, 10:03 PM
spongjim is offline
Find More Posts by spongjim
jim
United States, AL, Bessemer
Joined Jan 2005
Originally Posted by canpan
The waterproof servo for front vane is a very innovative indea for me. I am building my Robbe seawolf V2 at the moment. I also want to use the waterproof servo for more powerful front vane. Would you mind to share your experience on how to construct waterproof servo?
I took the servo and coated the outside with epoxy ,all around the seams and around the wire lead real good, then went to hardware store and got a flat rubber washer that was just big enough to fit over the output shaft of the servo. Grease the washer real good and install on servo then install you horn and tighten .I tested this setup for three hours in a test tank and not a drop of water in the servo. Easy to do and dont have to fight the linkages. I hope this helps you out canpan.
Jim
spongjim is offline Find More Posts by spongjim
Old Sep 15, 2005, 10:21 PM
canpan is offline
Find More Posts by canpan
Joined Jul 2005
Thanks, Jim.
canpan is offline Find More Posts by canpan
Old Sep 15, 2005, 10:27 PM
spongjim is offline
jim
Joined Jan 2005
You are welcome .I hope that helps you.
Steve , pictures are on the way (oops I forgot to mail them monday sorry)
Jim
Old Sep 16, 2005, 02:48 AM
SJ is offline
SJ
SJ
SJ's Avatar
Denmark EKCH
Joined Apr 2001
Thanks for the comments guys.
So I guess ill make a waterproof servo then :-)
Why install it under the tower?
Isn`t it easier or better to install it in the front end where the dive planes are ?
Old Sep 16, 2005, 04:14 AM
gunner508 is offline
Find More Posts by gunner508
gunner508
UK
Joined Jul 2005
Hi SJ
As Jim said in an earlier post, the servo is easy to get to and the servo lead isn't too long.
If fitted forrard you'll need a long servo lead from the WTC and the front deck will have to be removable.
It's not too difficult to do but it's easier when the boat is up and running to maintain and service, if the servo is under the conning tower. Everybody I know with a U47 fitted a waterproof servo under the conning tower.
However, it's your boat and your call. There's no right or wrong way to do things, only easier and better or difficult and not so good.
Anyway, your doing very well. Keep up the good work.
Gunner508
gunner508 is offline Find More Posts by gunner508
Old Sep 16, 2005, 07:41 AM
SJ is offline
SJ
SJ
SJ's Avatar
Denmark EKCH
Joined Apr 2001
Ohh....I thought that you glued the middle deck on, ans left the fore and aft decks removable. Better read the manual again
Heres the tower in primer.
Not perfect, but it will do.
Old Sep 16, 2005, 08:15 AM
SJ is offline
SJ
SJ
SJ's Avatar
Denmark EKCH
Joined Apr 2001
Anyone have any good pictures of U-47 ?
I have only managed to find these.
Old Sep 16, 2005, 02:03 PM
SJ is offline
SJ
SJ
SJ's Avatar
Denmark EKCH
Joined Apr 2001
MMMmmmm.....bigger is better
Old Sep 16, 2005, 02:15 PM
himszy is offline
Find More Posts by himszy
Scratch Builder
himszy's Avatar
Birmingham, England
Joined Sep 2004
Look at that bit that sticks out the conning tower. It makes me want to chop it off
Well done, it's comming along nicely.
Michael
himszy is offline Find More Posts by himszy
Old Sep 20, 2005, 10:17 AM
SJ is offline
SJ
SJ
SJ's Avatar
Denmark EKCH
Joined Apr 2001
well, I have been working......so not very much progress.
But I keep finding pictures that are more detailed which forces me to modify my tower all the time
I have also read a little about the real U-47, and found out that the boat was re-fitted a few times during the war. The most visable modifications ae on the tower ofcourse. I have some pictures of the same sub, with different conning towers. That confused me a little to begin with The robbe tower is "acurate" as it is of the later U-47. Im building mine as the early version.
Old Sep 20, 2005, 11:43 AM
SJ is offline
SJ
SJ
SJ's Avatar
Denmark EKCH
Joined Apr 2001
Primed again.
Old Sep 20, 2005, 05:36 PM
CaptainNemo12 is offline
Find More Posts by CaptainNemo12
RC sub dude
CaptainNemo12's Avatar
Montreal, Quebec, CANADA
Joined Nov 2004
Hi SJ, if I'm not wrong, I believe the Robbe version of the U-47 tower was the early version of the boat, not the later one, as it did not have the AA gun modification nor the enlarged wintergarden. Good progress!
CaptainNemo12 is offline Find More Posts by CaptainNemo12
Problems with Robbe U-47 English Nige Submarines 29 May 26, 2015 01:17 AM
Build Log Building the Robbe U-47 P. Tritle Submarines 61 Nov 09, 2008 10:53 AM
For Sale FS: Robbe U-47 Complete ThunderboltV12 Boats (FS/W) 2 May 28, 2007 08:18 AM
Sold Robbe U-47 vett Boats (FS/W) 0 Jun 11, 2006 08:09 AM
Robbe U-2540 1jordis Submarines 0 Nov 15, 2004 04:18 PM
