Old May 28, 2009, 12:23 PM
Capt.Crash is offline
Find More Posts by Capt.Crash
**NOT GUILTY**
Capt.Crash's Avatar
Millbrook, Alabama
Joined Jun 2004
Thanks guys...hey now that I've waxed her (Mother's California Gold Carnuba) and got it in the crack...I wonder how the CA will take?
Capt.Crash is offline Find More Posts by Capt.Crash
Old May 28, 2009, 02:47 PM
charlie eaton is offline
Find More Posts by charlie eaton
charlie eaton's Avatar
N.E.Mass.
Joined Apr 2007
I mentioned a built in battery box under a the aft seat deck on another thread about this boat. Here is several pictures to show what I ment.
charlie eaton is offline Find More Posts by charlie eaton
Old May 29, 2009, 12:44 PM
tim slocum is offline
Find More Posts by tim slocum
tim slocum's Avatar
Central Missouri,USA Along the banks of the Missouri River
Joined Jun 2005
Charlie, nice idea with the battery location. The stock location is a bit of a pain. Can you replace the floor with the battery in there?
Tom, is the Villian 14.4v Titan the one that says Titan Marine on it? Im not sure which one I have, maybe they relabled them differently now. God, I hope they didnt stop making the one like I have, its been GREAT. I never thought you could run as fast as my runabout does on 7.2v and without watercooling!
tim slocum is offline Find More Posts by tim slocum
Old May 29, 2009, 01:17 PM
**NOT GUILTY**
Capt.Crash's Avatar
Millbrook, Alabama
Joined Jun 2004
Originally Posted by tim slocum
C
Looks that way...I'm interested too! Is this the really good one Tom or is it the 19 turn?
This is the Titan 550 Marine Motor for the Traxxas Villain EX boat.
FEATURES: Fan-cooled 23 turns 14 volt
INCLUDES: One Titan 550 marine motor for the Traxxas Villain EX boat
REQUIRES: Installing in boat
SPECS: Length to end of armature: 78mm (3.07") Diameter of can: 37mm (1.46") Length of motor leads: 75mm (2.96") Shaft diameter: 3.2mm (.125")
I never thought about putting the batteries under the floor board. I like the location right behind the rear seat cross wise...it's easy to get to.
Old May 29, 2009, 03:05 PM
tim slocum's Avatar
Joined Jun 2005
Thanks for the info, 23turn, wow it runs like a 12turn!!!!
Old May 29, 2009, 03:08 PM
tim slocum's Avatar
Joined Jun 2005
Hey, just remembered, if anyone has any luck fixing the plank problem, let me/us know. I've thought about trying to get some epoxy in behind the plank and then clamping it down.?????
Old May 29, 2009, 03:16 PM
N.E.Mass.
Joined Apr 2007
Tim the biggest advantage is it moves weight foreward and brings the bow down at high speeds. Deck fits just fine over a 7.2 stick pack. I used thin CA and let it flow under the planks,no more problem.
Old Aug 24, 2009, 05:31 PM
jschneider is offline
Find More Posts by jschneider
jschneider's Avatar
SE Wisconsin
Joined Mar 2009
Just yesterday I was changing the batteries in my transmitter and broke both wires off that connect the battery holder to the transmitter. I have to say the design that pro boat uses is one of the worst I have ever seen, it is nearly impossible to get that battery holder out of the transmitter. Anyway, I have searched all over the net looking for a replacement without any luck. Even the proboat website doesn't show a replacement. Does anyone know first off who manufactures the radio and secondly where I might find a replacement battery holder?
John
jschneider is offline Find More Posts by jschneider
Old Aug 24, 2009, 06:00 PM
Kmot is offline
Find More Posts by Kmot
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
Have you thought about soldering the wires back into position?
Kmot is offline Find More Posts by Kmot
Old Aug 25, 2009, 12:37 AM
tim slocum's Avatar
Joined Jun 2005
I agree, the battery holder/lid is a poor design. Its hard to get the lid back on correctly and it will fall off at the worst time. I think Futaba makes their Tx's. If you can find the right charger, you can put rechargable AA's in the Tx and use the port to charge from. The trick is getting the right charger as the Proboats charge port is the opposite of most brands chargers. I believe this is how I found out that their Tx's are made by Futaba.
Old Aug 25, 2009, 09:23 AM
jschneider's Avatar
SE Wisconsin
Joined Mar 2009
Kmot,
I tried that, but something wasn't right. The TX would only work if I bent the wires a certain way which makes me think there may be more damage than just the wires. I will take a closer look at it, maybe it is salvageable.
Tim, if the TX is made by Futaba couldn't I just buy a Futaba brand battery holder? I would think that should work.
Thanks.
John
Found Pro Boat Classic Runabout or Aquacraft Pro Fisherman Bass boat wanted... Snooptalian Boats (FS/W) 0 Aug 31, 2006 11:17 PM
Discussion Classic Runabout's Tight Prop Shaft...HALP! Tim Stolle Scale Boats 17 Aug 01, 2006 12:47 PM
Help! Proboat classic runabout review artilce wanted Ray C Dock Talk 3 Feb 04, 2006 11:12 PM
Rave ProBoat Classic EP Runabout genastro Racing Boats - Electric 0 Jul 21, 2005 06:16 PM
