Old Sep 10, 2005, 06:35 PM
RD Blakeslee is offline
Find More Posts by RD Blakeslee
Joined Jan 2002
TP 2100-15C CBA Graph
Another example of this cell is graphed and discussed at:
http://www.rcgroups.com/forums/showthread.php?t=412007
- RD
RD Blakeslee is offline Find More Posts by RD Blakeslee
Old Sep 10, 2005, 07:01 PM
RC Man is offline
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
Those new cells sure are impressive! Some of those other brands really loose capacity but these hold capacity and voltage to the very end.
RC Man is offline Find More Posts by RC Man
Old Sep 10, 2005, 07:15 PM
Charlie Wang is offline
Find More Posts by Charlie Wang
Joined Dec 2002
Thanks RD,
You discharge curve is almost indentical to mine at 10C(21A),
I used the voltage sensing pin, so, my discharge curve is about 0.06V higher at 15C(31.5A)due to no voltage loss at 31.5A
We have almost perfect match cell performance.
Comfirm this cell deliver over 97% of rated capacity at 15C.
Regards,
Charlie
Charlie Wang is offline Find More Posts by Charlie Wang
Old Sep 10, 2005, 10:34 PM
fly_boy99 is offline
Find More Posts by fly_boy99
Flying motor mount master
fly_boy99's Avatar
San Jose, California, United States
Hey Charlie-
I'm getting some Prolite 3S 2100's and I'm intending to run them
at 10C so with my game plan how many cycles do you think I'll
get out of them?
fb
fly_boy99 is offline Find More Posts by fly_boy99
Old Sep 10, 2005, 10:40 PM
Hugeone is offline
Find More Posts by Hugeone
Hugeone's Avatar
Canada,Quebec
Joined Jan 2005
If I should not run my pack over 145F, why the TP2100 show 149F at 10C?
Hugeone is offline Find More Posts by Hugeone
Old Sep 10, 2005, 11:31 PM
717 is offline
717
Find More Posts by 717
717
717's Avatar
SF Bay Area, CA, USA
Joined Apr 2003
Do CBA test temps run higher than in-flight due to air flow?
717 is offline Find More Posts by 717
Old Sep 11, 2005, 01:51 AM
luc is offline
luc
Find More Posts by luc
luc
I plant balsa sticks too
luc's Avatar
France
Joined Feb 2000
here is the cell and a 3S pack I did. The 3S pack is very light as you can se on the scale.
I use them on a 6S setup on my H9 warbirds (previously 8lbs, but now rather 7lbs due to these light cells).
That's another advantage of these cells: very light, hence an easier landing, which saves plane and money...
luc is offline Find More Posts by luc
Old Sep 11, 2005, 03:35 AM
mikekomm is offline
Find More Posts by mikekomm
mikekomm's Avatar
Los Angeles
Joined Aug 2002
Please help clarify somthing for me. I've read many other posts that say temperatures od 160 F damage LIPO cells and dramatically cut the number of cycles that you can use these packs for. Can the Thunder Power packs handle 169 F ?
mikekomm is offline Find More Posts by mikekomm
Old Sep 11, 2005, 03:42 AM
luc is offline
luc
luc
luc's Avatar
France
Joined Feb 2000
they sure can handle it but their lifespan will be decreased.
Note that on a cba, there is no airflow, which you should provide in an airplane. Besides, the discharge @ 15C is continuous on a CBA, whereas, you could expect on your plane to slightly move the stick up and down from time to time...
Old Sep 11, 2005, 03:53 AM
Joined Dec 2002
Some comparisiom of temperature :
Kokam 3200 tested at max discharge rate
Start temperature 72F, end temprature 185F. delta temperature=113F
This mean if Kokam 3200 cell starting temp at 80F,end temperature would be at alarming 192F!!(80+113=192)
TP ProLite 2100 tested at max discharge rate
Start temperature 80F, end temperature 169F. delta temperature=89F
Yes, any lab constant current discharge at max discharge rate run very high temperature due to no cooling, this is not limited to TP(many temperature reference can be found in battery vault)
Regards,
Charlie
Old Sep 11, 2005, 04:00 AM
mikekomm is offline
mikekomm's Avatar
Los Angeles
Joined Aug 2002
Thanks for the replies. So if I use one of these TP2100 packs at close to their limit, how charge / discharge cycles can I expect from one of these packs.
Old Sep 11, 2005, 04:41 AM
Joined Jan 2002
Originally Posted by Charlie Wang
... I used the voltage sensing pin, so, my discharge curve is about 0.06V higher at 15C(31.5A)due to no voltage loss at 31.5A...
I did too, Charlie. Also, I used the latest software update.
My full-charge voltage may have been a little lower than yours - I charge to 4.002 and run a graph if that voltage holds for a minute or so. I've noticed that the voltage will drop to 4.195 or so, within an hour or two. But it's a matter of time versus extreme accuracy - it's already taking me a day and a half per graph, without waiting an hour after each charge.
Regards,
- RD
Old Sep 11, 2005, 04:43 AM
Joined Dec 2002
Cycle life is affected by many factors:
1)Discharge to 90% or less if operating close to battery's limit, discharge porpotion to the capacity loss(4% lost of capacity per 50 cycles adjustment)
2)Store batteries at room temperature at less than 75% charge, 50% for long term storage(avoid direct sunlight and in vehical storage).
3)Cut short flight if abiance temperature is above 90F
4)Battery temperature should keep below 140F, this could be achieve with some cooling.
If close to their limit means something like 35-40A static
For 3D and sport plane, my estimate is 200 to 300 cycles .
Regards,
Charlie
Old Sep 11, 2005, 04:47 AM
Joined Dec 2002
Regards,
- RD
Thanks RD.
Old Sep 11, 2005, 04:52 AM
Neil Morse is offline
Find More Posts by Neil Morse
Registered Snoozer
Neil Morse's Avatar
San Francisco, CA, USA
Joined Jul 1999
I have found these cells to be outstanding. I am using a 3S pack in my Quiet Storm, pulling 32 amps at WOT. After a six minute flight, with air flowing over the pack and managing the throttle for aggressive pattern aerobatics, the pack comes down at about 115 degrees F and takes about 1500 mAh back in when I charge it. I would hope to get many cycles at that rate.
Neil
Neil Morse is offline Find More Posts by Neil Morse
Data Apex Mk3 1350 15C CBA Graph RD Blakeslee Batteries and Chargers 15 Sep 12, 2006 10:50 AM
Data GraysonPower 2100 15C, CBA+10X Amp. Graph RD Blakeslee Batteries and Chargers 11 Sep 05, 2006 09:41 AM
Discussion Apex 2100 15C, CBA/10X Amp. Graph RD Blakeslee Batteries and Chargers 12 Jul 26, 2006 11:01 PM
Data Kokam 1250-15C CBA Graph RD Blakeslee Batteries and Chargers 27 May 01, 2006 07:42 PM
Data Kokam 2000(1800)15C CBA Graph RD Blakeslee Batteries and Chargers 3 Apr 25, 2006 08:28 PM
