Old Sep 10, 2005, 02:22 AM
RMac is offline
Find More Posts by RMac
Seattle
Joined Feb 2004
How to drill out GWS HD Props to fit MP jet collet adapters
Is there a trick to drilling or widening the opening of the GWS HD props so that the adapter fits properly, any specific drill sizes, or instructions would be appreciated. Thanks RMac
RMac is offline Find More Posts by RMac
Old Sep 10, 2005, 10:20 AM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
You can use a prop reamer, but I've never had one of those. I simply use as many imperial drill sizes as I can, as intermediaries before using the 5mm or 6mm metric drill bit to get the final hole.
3mm and 3.2mm MP Jet adapters need 5mm bore, 4mm need 6mm bore, 5mm need a stepped 7-8mm........
To get from the original 4mm bore GWS HD hub to 5mm bore: use
(first)11/64 = 4.3656mm
(then) 3/16 = 4.7625mm
(finally) 5mm
To continue to 6mm: use
(first) 13/64 = 5.1594mm
(then) 7/32 = 5.5562mm
(then) 15/64 = 5.9531mm
(finally) 6mm
Cheers, Phil
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Sep 10, 2005, 12:30 PM
RMac is offline
Seattle
Joined Feb 2004
Phil, can I use a hand drill or should I track someone down who has a drill press. Thanks for the info RMac
Old Sep 10, 2005, 01:15 PM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
I sometimes use my drill press, but usually I'm in a hurry so I put the prop hub in a vise and just hand-hold my cordless 14.4v Makita power drill on high speed. I don't imagine you could do it well with a real old-fashioned "hand drill", since the bit will "bite" even at low rpm on the power drill, let alone the minimal rpm of a hand drill.
Cheers, Phil
Old Sep 10, 2005, 05:31 PM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
I actually do use a hand-drill when I am in the field. I get a flying buddy to hold the prop flat against my van floor and go for it (but turning it slowly). Once it bites to the bottom I hand spin the prop down onto the drill bit to finish the hole off.
NitroCharged is offline Find More Posts by NitroCharged
Old Sep 11, 2005, 01:50 AM
RMac is offline
Seattle
Joined Feb 2004
My mistake Dr Kiwi & NC, I meant a cordless electric drill. I was able to find a tapered round file and used that to enlarge the opening, prop adapter fits well. I am eager to try these new props out as I have been using APC slow fly's and have heard that the HD can draw less Amps and provide similiar thrust.Also added a Watt's up to the flight box. Great info as usual. Thanks RMac
Old Sep 11, 2005, 08:58 AM
-=SLaPPiE=- is offline
Find More Posts by -=SLaPPiE=-
Designer of Flying Things
-=SLaPPiE=-'s Avatar
Overland Park,Kansas
Joined Apr 2004
An electricians step bit, with only one cutting edge is what I use.
Rich
-=SLaPPiE=- is offline Find More Posts by -=SLaPPiE=-
Old Sep 11, 2005, 09:31 AM
John O'Sullivan is offline
Find More Posts by John O'Sullivan
John O'Sullivan's Avatar
Nova Scotia Canada
Joined Jan 2004
If you don't have a proper reamer readily available, the tang of a suitably sized file does a good job.
John O'Sullivan
John O'Sullivan is offline Find More Posts by John O'Sullivan
Discussion HOw to Mount GWS HD Props stuka GWS (Grand Wing Servo) 6 Apr 10, 2007 12:37 AM
Question How far do you dare push GWS HD props?? BEC Power Systems 27 Aug 08, 2006 10:38 AM
Nippy and GWS HD props Dr Kiwi Power Systems 8 Dec 16, 2003 08:15 PM
How to drill out a pinion? avdflyer Electric Plane Talk 2 Oct 22, 2001 01:50 PM
How to make the new APC Electric props fit your adapter Joe Elston Electric Plane Talk 6 Jun 17, 2001 01:56 AM
