Old Sep 09, 2005, 11:25 PM
ortoyegon is offline
Find More Posts by ortoyegon
"Got Dunes?"
ortoyegon's Avatar
Coos Bay, Oregon USA
Joined Jul 2005
Electron 6 RX w/ JR TX questions
I lost my "where to plug the servos for dummies book"
Plane: Mini Blade w/flaps one rudder servo
RX: Electron 6
TX: xp8103
So, where do i plug the Flap and rudder servos in to the receiver( that comes with no instructions)?. What basic settings do i need to input on the TX just to get it to work right? don't need advanced stuff just want the surfaces to move the right direction on the correct stick. I've only dealt with planes with two control surfaces so far, so i'm a little lost. Thanks
ortoyegon is offline Find More Posts by ortoyegon
Old Sep 10, 2005, 04:46 AM
hydrogin is offline
Find More Posts by hydrogin
Santa Barbara, CA
Joined Feb 2004
Below are the channel assignments from the 8103 manual. You can download the online manual from Horozon Hobby's website:
Channel Assignment, Airplane Version Transmitter–Glider Mode
1. SPOI Spoiler Channel
2. AIL1 Left Aileron Channel
3. ELEV Elevator Channel
4. RUDD Rudder Channel
5. AIL2 Gear Channel (Right Aileron Channel–AILE 2)
6. FLAP Auxiliary 1 Channel (Left Flap Channel for Dual Flaps)
7. AUX 2 Auxiliary 2 Channel (Right Flap Channel for Dual Flaps)
8. AUX 3 Auxiliary 3 Channel
Lance
hydrogin is offline Find More Posts by hydrogin
Old Sep 10, 2005, 10:44 AM
"Got Dunes?"
ortoyegon's Avatar
Joined Jul 2005
Thanks...but
so.. i'm supposed to plug the left flap in to channel 7 of a 6 channel receiver, that's gonna be a little challenge, wheres my dremel
Old Sep 10, 2005, 10:49 AM
"Got Dunes?"
ortoyegon's Avatar
Joined Jul 2005
is this how they go ?
1. rt. or lft.? flap
2. left ail.
3. right ail.
4. Rudder
5. Batt.
6. rt. or lft.? flap
Old Sep 10, 2005, 11:12 AM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Originally Posted by ortoyegon
IPlane: Mini Blade w/flaps one rudder servo
RX: Electron 6
TX: xp8103
The Rx instructions won't help you; you need the TX instructions. Unless you can get your Tx to use ch6 for "flaps", forget about using the Electron 6...
But if you're mistakenly calling full span ailerons the "flaps", then I think it would be ch 1 and 5 or 6 for the ailerons, and channel 2 for the v-tail.
Please describe what your are trying to do better, and I will see if I can find the manual for your radio online....
Target
target is offline Find More Posts by target
Old Sep 10, 2005, 11:20 AM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Here's the manual. After reading the other posts, sounds to me like you'll have to use a "y" servo connector, with a reverser on one leg, and hook into channel 6...
http://www.jrradios.com/ProdInfo/Fil...103-manual.pdf
Old Sep 10, 2005, 11:25 AM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
I think you need this for channel 6, but you will only be able to get the flaps to go up and down together, not opposite like the ailerons. For that you will need 7 channels, I guess. That is why I like my EVO 9 radio, I can assign ANY function to ANY channel. I have a six servo plane that I'm flying with an electron 6....
http://www.cermark.com/Merchant2/mer...Code=246JRYGSR
Good luck,
Target
Old Sep 10, 2005, 11:27 AM
"Got Dunes?"
ortoyegon's Avatar
Joined Jul 2005
Electron 6
Target
The TX destructions say where to plug stuff into an 8 channel RX. I need to know where to plug servos into an electron 6
A Blade w/ Flaps has 4 control surfaces on the wing, in case you didn't know.
i think i gave plenty of info.I'm trying to figure out where to plug the servo plugs into the receiver that many people use in this very same plane. Thanks for the help
Old Sep 10, 2005, 11:37 AM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Sorry. You sounded kinda Newbie-ish by the one rudder servo description....
Good luck with the build/maiden
I think you'll either have to use the "Y" with reverser, of go to a 7 or more channel Rx...
OR maybe there is a different "mode" for the Tx your using, where you can get your ailerons on 2 and 5, then slave channel 4 to channel 6, and have the flaps there, if you follow that?
T
jdcook54 is offline
Find More Posts by jdcook54
PlaneCrazy
jdcook54's Avatar
Central California
Joined Sep 2003
I use the electron 6 with my JR 9303
dont know if its the same with the 8103 but here is mine, use your TX manual if your not sure, they also have manuals online.
1-LA
2-RA
3-Elev
4-Rudder (or power if you dont need the rudder)
5-RF
6-LF
I use all 6 servos, so in that case I just tap into one of the servo lines.
Doug
jdcook54 is offline Find More Posts by jdcook54
Old Sep 10, 2005, 11:42 AM
"Got Dunes?"
ortoyegon's Avatar
Joined Jul 2005
Good luck,
Target
Damn, nobody ever said nothing about having to do this in all the convos i had about this setup. I wanted to fly this weekend and no way am i gonna fly this plane without flaps . I was a stupider newb than i am now when i bought the 8103, if i only would have had the knowledge before i had the money .
Old Sep 10, 2005, 11:43 AM
"Got Dunes?"
ortoyegon's Avatar
Joined Jul 2005
T
I am a newb, but can count to four
Old Sep 10, 2005, 11:46 AM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
I feel that you are off to a good start, then. Possibly ahead of the average sloper!
Gotta go.
Please post what the end solution is that you choose.
Target
PS. Hindsight is 20/20.... Don't beat yourself up over the purchases you've made. Both items are sound sloping tools.
Old Sep 10, 2005, 11:47 AM
"Got Dunes?"
ortoyegon's Avatar
Joined Jul 2005
Jk
T
So, what does a know it all expert top gun master call it?
JK....Roy
Old Sep 10, 2005, 11:52 AM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Single elevator servo v-tail, not rudder. With one servo for the tail, I'm more interested in going up and down, than left and right.
Don't mind me, Roy, I mean well. I'm just a little bit(tiny) of a smart A$$....
T
Sold Electron 6 RX (w/3 xtals) + Deans 2PC Base Loaded Antenna GoRgOyL Aircraft - Electric - Helis (FS/W) 1 Nov 10, 2005 09:24 AM
Hitec RX w/ JR TX Keith R. Slope 13 Sep 24, 2005 07:00 PM
Hitec Electron 6 Rx for JR/AirtZ For Sale jimmy6819 Aircraft - Electric - Airplanes (FS/W) 1 Oct 30, 2003 04:10 AM
FS- New Glider Flight Pk- Hitec Electron 6 Rx w/xtal, 270mah rx battery and 2 HS-81's Etonic Aircraft - Electric - Airplanes (FS/W) 5 Oct 26, 2003 10:02 AM
FS- Hitec Electron 6 Rx w/ ch 27 crystal - Brand New! Etonic Aircraft - Electric - Airplanes (FS/W) 2 Mar 25, 2003 12:05 PM
