Old Jul 08, 2001, 09:25 PM
Dave Hederich is offline
Find More Posts by Dave Hederich
Walled Lake, MI, USA
Joined Feb 2000
GWS DX Motor Prop Recommendations
The GWS DX motor system has become one of the most popular power options in slowflight, thanks to the popularity of the Lite Stik and similar aircraft that come with this system, reasonable cost and good performance. Each DX system (A through F) has a different gear ratio, with A being numerically the lowest and E the highest. However, there is a lot of confusion about what prop GWS recommends for each of its different DX systems because their original recommendations have been revised, but many internet sites still have the old recommendations posted. Below is a reproduction of the prop recommendation chart reproduced from the back of the package from a retail DX motor with explanations:
GEAR RATIOS
DX-A = 5.86:1
DX-B = 7:1
DX-C = 8.6:1
DX-D = 9.66:1
DX-E = 10.7:1
DX-F = 11.8:1
PROP IDENTIFICATION
First 2 digits of prop = diameter in inches
Second 2 digits of prop = pitch
PROP RATINGS
3 = Excellent
2 = Good
1 = Fair
0 = Don't Use
PROP A B C D E F
0947 1 0 0 0 0 0
0970 2 0 0 0 0 0
1047 3 1 0 0 0 0
1080 0 2 0 0 0 0
1147 0 3 1 0 0 0
1180 0 0 2 1 0 0
1260 0 0 3 3 1 0
1280 0 0 2 2 2 1
1365 0 0 0 2 3 2
1390 0 0 0 0 2 3
1470 0 0 0 0 0 2
Dave Hederich is offline Find More Posts by Dave Hederich
Old Jul 08, 2001, 11:04 PM
Rekit is offline
Find More Posts by Rekit
Garland, Texas
Joined Jul 2000
I would have never dreamed that a dx would swing a 14x7 prop
Rekit is offline Find More Posts by Rekit
Old Jul 09, 2001, 09:39 AM
Fly_joy is offline
Find More Posts by Fly_joy
Fly_joy's Avatar
Rochester, NY
Joined Mar 2001
I flew my stik with a 1047 and a 0970 and to be honest I didn't notice much differnce. Both worked fine with 7.2v lithium bat.
Caveats:
1) I'm a beginner 2) It was fairly windy
What difference in performance should I see between these two props?
Fly_joy is offline Find More Posts by Fly_joy
Old Jul 09, 2001, 09:54 AM
Megowcoupe is offline
Find More Posts by Megowcoupe
Balsa Flies Better!
Stamford, CT
Joined Oct 2000
Todd Long pointed out to me that going to higher gear ratios (C and over motors) required some pretty unusual designs. Essentially to use a D ratio motor, you need about 350 square inches with a single surface undercambered airfoil and the airplanes all up weight has to be under 10 ounces or so. Pure float in a pretty large airplane. Taking his suggestion- I used a B motor instead on my Super Snooper- a rubber powered duration model of about 200 square inches (with a big lifting stab)all up weight of about 8.5 ounces, and I think its swinging a 10 x 7 prop. Flies wonderfully, but it isn't very fast. In short- for most practical airplanes, only the A and B motor make a lot of sense because the pitch speed of the other motors is too low.
Sam Brauer
Norwalk, CT
Megowcoupe is offline Find More Posts by Megowcoupe
Old Jul 09, 2001, 03:12 PM
mattk17 is offline
Find More Posts by mattk17
mattk17's Avatar
Dallas,TX
Joined Jul 2001
I can share my findings using the 10x4.7 and the 9x7 on my lite stick. For reference, my stick has about 1" dihedral added with a thread running from outer leading edge to outer leading edge. I use a factory GWS-A motor and power with a rayovac 9v (8.4) nimh. I use the GWS pico servos and receiver and did not add any stickers to keep weight down.
The 10x4.7 does give quicker ROG and a little better climb rate. The 9x7 gives better speed which is very handy when flying into wind. Battery run times are just about the same. All in all, my vote goes to the 9x7 for outdoor flying.
mattk17 is offline Find More Posts by mattk17
F/S NIB Carbon Falcon and GWS DX-a Motor drive and Prop guyde Aircraft - Electric - Airplanes (FS/W) 0 Jun 15, 2004 10:10 AM
F/S: NIB CARBON FALCON and GWS DX-A motor drive and 8x6 prop. guyde Aircraft - Electric - Airplanes (FS/W) 0 Jun 13, 2004 06:57 PM
Motor/Prop recommendations for GWS warbirds Dog1 GWS (Grand Wing Servo) 6 Dec 02, 2003 08:44 PM
GWS motor/prop recommendations??? sreding Foamies (Kits) 4 Aug 31, 2002 10:44 AM
GWS DX Motor Heat Sink Dave Hederich Parkflyers 10 Jul 25, 2001 02:56 PM
