Old Sep 09, 2005, 09:09 AM
extreme is offline
Find More Posts by extreme
Joined Jul 2004
Futaba FC-16 range problem.
Hi guys, I own a Futaba FC-16 (european), and recently my signal range has dropped significantly. With antena at it's shortest position I get about 50 meters on the ground. Sometimes when the signal is lost (stil on the ground) I get as near as 15-20 meters till receiver catches it (im using PPM). Changed both aerials (rx & tx), cleaned everything up, still performance is poor. I'd like to get a new radio but good ones are'nt for free. It would be great if anyone could help me solve the problem... ]
Robert
extreme is offline Find More Posts by extreme
Old Sep 09, 2005, 09:42 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
If it is indeed the Transmitter causing the problem then most likely the RF section has been damaged( has been reduced in out put power). Most common reason is operating the transmitter with the antenna collapsed for extended period of time such as when setting up an aircraft or being left turned on by mistake. Before everyone says they do this all the tie and their's is still fine,great! The RF section is a tuned circuit and when the antenna is not fully extended it is way out of tune which causes their RF Finals to overheat. Some transmitter may have protection circuits but not a radio are created equal. Most radio manufactures will void the warranty if a Rubber Ducky Antenna is used for this very reason. The Transmitter is tuned for use with the factory supplied antenna only and it is only tuned(matched) when fully extended.
Charles
Old Sep 09, 2005, 03:49 PM
extreme is offline
Joined Jul 2004
So what should I do ? Is it repairable ?
Old Sep 10, 2005, 08:54 AM
Skysoarer is offline
Find More Posts by Skysoarer
Surrey
Joined Sep 2005
Perhaps I just found out my problem then. Over the years my Sanwa has been used to setup a few models with the aerial down for practical reasons. I can't say I ever noticed it warm though.
Graeme
Skysoarer is offline Find More Posts by Skysoarer
Old Sep 10, 2005, 09:55 AM
Southern Pride
A repair shop could check the RF output and if it is less than it should be replace the RF power transistors . If it is / was a RF Module Transmitter a new Module would fix it.
Charles
Old Sep 11, 2005, 01:46 PM
extreme is offline
Joined Jul 2004
Thanks, will see what can be done.
Old Sep 12, 2005, 05:27 PM
extreme is offline
Joined Jul 2004
Tried another Rx today and ir works just fine.
Old Sep 14, 2005, 09:33 AM
Surrey
Joined Sep 2005
Nuts.. I tried another rx with a new tx crystal and the problem remains. I'm meeting up with a friend who has a Sanwa tx, so we'll get to the bottom of this!
Graeme
Looking for Robbe Futaba FC-18 manual Theuns Electric Plane Talk 4 Dec 11, 2012 09:07 PM
Multiplex USB Sim Interface Cable and Futaba FC-16, need help. Puff Simulators 5 Jun 23, 2005 04:30 PM
Help! Futaba FC-16 Q's RNAF Fuel Heli Talk 4 May 26, 2005 10:04 AM
Question Futaba FC-16 manual pecka Beginner Training Area (Aircraft-Electric) 8 Nov 19, 2004 02:33 AM
Futaba FC-18 teacher to FC-16 pupil problem . jmquetin Radios 5 Nov 02, 2004 07:48 AM
