Old Sep 08, 2005, 09:39 PM
Hovertime is offline
Find More Posts by Hovertime
Always right
Hovertime's Avatar
Chicago
Joined Feb 2003
Yippee!
ARC - New brushless motors!
Got me ARC 20-34-110 motor from www.lightflightrc.com , which surprised me quite a bit when I saw it. If you get combo deal with Phoenix 10 then motor costs practically nothing too, keeping in mind regular P10 prices around. Gotta love those combo deals popping up lately!
Anyway, it will be used to replace GWS 350 motor, now I need to get me some pinions and props and try to find the sweet gearing spot and prop for it first.
More details later.
Hovertime is offline Find More Posts by Hovertime
Old Sep 09, 2005, 08:01 AM
Seawolf 24 is offline
Find More Posts by Seawolf 24
FLY NAVY!
Seawolf 24's Avatar
Clinton, TN
Joined Oct 2003
What's the shaft diam.?
Duke
Seawolf 24 is offline Find More Posts by Seawolf 24
Old Sep 09, 2005, 08:22 AM
BigSky81 is offline
Find More Posts by BigSky81
Northeast CT
Joined Sep 2005
It's gotta be 2mm for a speed 300 size. They say it fits the GWS and HiMax gearboxes. Some of those motors are real high Kv, 4500 and 4600 might be good for a fan or something. How are you going to set that puppy up hovertime?
BigSky81 is offline Find More Posts by BigSky81
Old Sep 09, 2005, 11:08 PM
Always right
Hovertime's Avatar
Chicago
Joined Feb 2003
OK, turned everything upside down only to remember later that a friend of mine borrowed my digicam LOL.. so pics in a few days.
Actually 4500 and 4600 rpm/v would be better for my application, I am using 2S lipos for my small planes, and 3100kV motor is not the best choise... I should have gotten smaller ARC 80W motor instead, would be still plenty for GWS Beaver.
PS - GWS 350 motor has kV of 5330. Beaver has gearing of 5.33, so prop shaft kV is 1000 rpm per volt. So ill try to keep it same and to get a 1000 rpm per volt at prop shaft I will need around 3:1 gearing for my ARC 110 3100 kV motor. So will pick one of the closest GWS gear sets later.
Motocalc numbers look good - close to 1 hour cruising with 9x7 prop and 1320 2S pack.
Old Sep 09, 2005, 11:20 PM
LostintheTrees is offline
Find More Posts by LostintheTrees
Colorado
Joined Jul 2004
I don't wish to disillusion you, but 1 hour on a 2s 1320 batt means you plan to be flying on about 20 watts. Don't expect much performance if your plane weighs more than about 4 or 5 ounces AUW.
LitT
LostintheTrees is offline Find More Posts by LostintheTrees
Old Sep 09, 2005, 11:36 PM
Always right
Hovertime's Avatar
Chicago
Joined Feb 2003
Actually I had calculations with Slow Stick airframe, just redid it, it predicts 80 minutes for Beaver. Motocalc is good for general reference, although its as precise as the numbers you punch in, and they are not precise
PS I have heard of guys flying for a long time with Beavers on stock motor and NiCd 270mAh packs... and they are definitely heavier than 5 ounces, double or triple that..
I am not trying to get performance with Beaver but rather high efficiency / long flights.
Anyways - fired up this motor again, it has very strong cogging, when turning by hand, and runs smooth as silk when it gets rolling. In fact it has zero vibrations, (and I was thinking that my small Neu motor is vibrating due to its strong cogging... hmm.. maybe its just out of balance??, I should try to contact Steve Neu... I wonder if they balance rotors?)
Old Sep 13, 2005, 07:04 PM
aV8ter is offline
Find More Posts by aV8ter
aV8ter's Avatar
Alpharetta, GA
Joined Sep 2004
Any flight report? I want to hear how the motor compares with factory numbers.
Kevin
aV8ter is offline Find More Posts by aV8ter
Old Sep 13, 2005, 07:18 PM
Always right
Hovertime's Avatar
Chicago
Joined Feb 2003
Seavolf 24 - I have just assumed its 2 mm shaft, and it looks so, as soon as I get GWS pinion/press it on I will let you know for sure.
Kevin - waiting for pinion/gear for GWS box, so no flight report. I am particularly interested to see how it compares to the stock GWS 350 motor, turning same prop at same voltage. My goal is - much better efficiency, and some extra power is welcome too
So far have measured kV which matches, and no load current, which is dead on too.
Old Sep 13, 2005, 08:16 PM
aV8ter is offline
aV8ter's Avatar
Alpharetta, GA
Joined Sep 2004
I was originaly planing on using the 130w in my e-flight Yah 54f in combonation with a new thunderbird controller but it doesn't seem like CC is getting there act together. I will just get a cool running Esc A-12 instead.
Kevin
Old Sep 14, 2005, 06:47 PM
Always right
Hovertime's Avatar
Chicago
Joined Feb 2003
Snapped a pic with my web cam, will post some better ones when I get my better camera back... Motor with adapter plate mounted, alongside GWS 300/350 motor.
Got the pinions, will try them on tomorrow.
Old Sep 14, 2005, 06:55 PM
aV8ter is offline
aV8ter's Avatar
Alpharetta, GA
Joined Sep 2004
Is that what the wire comes looking like?
Kevin
Old Sep 14, 2005, 07:24 PM
aeropylot is offline
Find More Posts by aeropylot
aeropylot's Avatar
United States, ID, Boise
Joined Oct 2003
I bought a couple ARC motors from LightFlightRC also over the past couple weeks. First start out by saying WOW....and also there is nobody better in the business than LightFlightRC.
I bought the 80W and the 130W. I have the 130 in a HOB Chipmunk and i get great performance out of it. I have been running a GWS 10X6 HD prop in a GWS 350 gearbox with a C gearing. According to my numbers I have been pulling 12.7 A on a 3C lipoly and getting about 35 oz T at 45 mph Pitch Speed and never had any heat in it. Needless to say the Little Chipmunk goes up and up and......I am hooked on these great little motors.
Some more Numbers on the 130
D gear 3C lipoly
10X8 14A 34oz T 50 MPH
9X7 11.8A 24oz T 47 mph
C Gear 3C
8X6 9.6A 23oz T 45 mph
aeropylot is offline Find More Posts by aeropylot
Old Sep 14, 2005, 09:52 PM
Always right
Hovertime's Avatar
Chicago
Joined Feb 2003
Kevin
Yes, you directly solder it to esc. Often I remove factory attached bullet plugs if they are present, and solder direct to esc anyway.
Most (all?) 20 mm size motors have wires that looks like that under the cover..
Old Sep 17, 2005, 08:19 PM
Always right
Hovertime's Avatar
Chicago
Joined Feb 2003
Mounted it, better picks :
Had some troubles pressing pinion on - rear shaft end is recessed, and had to be supported by 2 mm screw to protect bearings. Otherwise rear bearing may get damaged during pinion installation.
Time for power testing!
Old Sep 17, 2005, 10:30 PM
mrebman is offline
Find More Posts by mrebman
Cincinnati, Ohio USA
Joined Nov 2000
Hovertime:
I just got an Email response from Dave at LightFlightRC. He is recommending the 110 Watt motor as a replacement for my Himax 2015-4100 in "C" & "D" Gearboxes. What is the difference between the 110W & the 130W that you have? Is it just the KV rating?
-Thanks-
mrebman is offline Find More Posts by mrebman
new to brushless motors. question Josh9 Power Systems 4 Feb 26, 2003 11:03 AM
New Brushless motors are here! Todd Long Vendor Talk 0 Nov 08, 2002 12:02 AM
Are these new brushless motors ? Patrick Plawner Electric Plane Talk 4 Oct 15, 2002 01:54 PM
New Brushless motors check it out Eco8gator Electric Heli Talk 5 Nov 06, 2001 02:50 AM
Simpro new Brushless motors chrisc Electric Plane Talk 0 Jun 12, 2001 11:36 PM
