Old May 07, 2002, 10:11 PM
Heli Slime is offline
Find More Posts by Heli Slime
Formerly Black96Z
Heli Slime's Avatar
Mckinney, TX
Joined Apr 2002
Is my zero just slow?
I fly it with a 1080 prop, stock setup with 7 cells. then as I am looking through Ebay, I see this:
http://members.shaw.ca/ebaypics/zero.wmv
I don't know whose this is, but geez, I wish mine was that fast.
David
Heli Slime is offline Find More Posts by Heli Slime
Old May 07, 2002, 10:17 PM
Martin Hunter is offline
Find More Posts by Martin Hunter
Leave me alone!
Martin Hunter's Avatar
Kamloops, BC, Canada
Joined Feb 2002
Don't call your zero slow. You'll give it a complex!
"Speed-challenged"?
I don't fly the zero, so I can't comment on the speed, but I've never seen a video of one flying, so thanks for pointing that one out!
Martin Hunter is offline Find More Posts by Martin Hunter
Old May 07, 2002, 10:27 PM
Jim McPherson is offline
Find More Posts by Jim McPherson
Just an average RC'er
Jim McPherson's Avatar
Laurel, Maryland USA
Joined Aug 2000
With 8 cells and WOT mine is almost that fast. He could be using the 300C-A drive which has a lower gear ratio but a faster pitch speed. It wouldn't be hard to make the Zero go that fast.
Jim McPherson is offline Find More Posts by Jim McPherson
Old May 07, 2002, 10:43 PM
Fred Bronk is offline
Find More Posts by Fred Bronk
Our Daddy and Heli Junkie
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
You should try 8 cells. It will surprize you what just 1 cell can do.
Fred Bronk is offline Find More Posts by Fred Bronk
Old May 08, 2002, 12:30 AM
Jim Lin is offline
Find More Posts by Jim Lin
Taiwan
Joined May 2002
It is Engine
Believe me. I knew the history.
I live in Taiwan. This video came from Taiwan. This flyer modified GWS Zero by using engine as power system.
Of course his Zero will be faster than yours.
Jim
Jim Lin is offline Find More Posts by Jim Lin
Old May 08, 2002, 09:22 AM
rclark is offline
Find More Posts by rclark
A Clinger
rclark's Avatar
Butte, MT
Joined Sep 2001
I too was a little disappointed with the stock speed with 7 cell 600 Nicad and 10x8 (3B 9x6 is even slower). Appears to be slower than my SS Pro which I didn't expect. Still fun to fly, and I suspect one can add cells, change motors....... Part of the 'fun' of flying electrics . It is designated as a 'park flyer' so should have expected it. Neat to fly anyway!
rclark is offline Find More Posts by rclark
Old May 08, 2002, 09:47 AM
Joined Aug 2000
Re: It is Engine
Jim
Jim,
Do you happen to know what motor he is using?
Old May 08, 2002, 08:23 PM
Jim Lin is offline
Taiwan
Joined May 2002
I am not familiar with engine. I think he said 10 c.c. engine.
That will be better to read his web site http://home.kimo.com.tw/m52602/z.htm First generation Zero
http://www.m5260.netfirms.com/z-.htm Second generation Zero
if you can read Chinese.
But any way, you can reference his images of working.
Old May 09, 2002, 12:31 AM
Leave me alone!
Joined Feb 2002
if it is indeed an engire as opposed to a motor, it's the quietest I've ever heard. In fact, it sounds identical to my switchback. Hmmm.
Old May 09, 2002, 03:47 AM
Jason M is offline
Find More Posts by Jason M
20 years on RCG!
United States, IL, Champaign
Joined Dec 1996
Ours here in Vegas are nearly as fast!
We use 8 cell packs of Maxell 700 NiMHs. An 8 cell pack of these weighs 3.5 ounces - nearly 1.5-2 ounces LESS than 7 and 8 cell 500/600 MaH NiCad packs with MORE power and the SAME flight time (5 minutes WOT)!
These packs are by far the best value going - you can buy these Maxell 700 cells (AAA sized) for just 75 cents EACH here on the EZone! For $6 a pack, there is no better alternative! Excellent speed, low weight, good duration - CHEAP!
He may have a different motor and gearing, but out box stock Zeros would easily give him a run for the money using these 8 cell packs. 4 foot take off rolls, 45 degree climb outs - Id guess around 25-30 mph top speed for ours! Just remember - keep it light!
Jason
Jason M is offline Find More Posts by Jason M
MY Zero's first Flight joystix Parkflyers 2 Apr 12, 2002 07:20 PM
Got my Zero! Need some advice on Rx and battery pack cfossa Parkflyers 0 Apr 01, 2002 10:37 PM
i finished my ZERO!! Muah Parkflyers 18 Apr 01, 2002 10:19 AM
PIC. of Kyosho my ZERO before crash speedo Scale Kit/Scratch Built 9 Mar 04, 2002 10:28 AM
My LiteStik just arrived.. questions stjobs Parkflyers 16 Sep 27, 2001 07:16 AM
