Old Sep 07, 2005, 08:45 PM
terryh1313 is offline
Find More Posts by terryh1313
black cat squadon
terryh1313's Avatar
Joined Nov 2004
looking for a cheap brushless setup for parkzone p-51
ihave removed all parkzone equipment an need some advice on a new setup
terryh1313 is offline Find More Posts by terryh1313
Old Sep 08, 2005, 10:58 AM
latrans is offline
Find More Posts by latrans
Joined Aug 2004
What (roughly) will your finished flying weight be and what kind of performance are you looking for, scale or insane? Do you plan on using the 10in 3 bladed stock prop or will you go to something else? What batteries do you want use? Lots'a questions.
Latrans
latrans is offline Find More Posts by latrans
Old Sep 08, 2005, 08:10 PM
black cat squadon
terryh1313's Avatar
Joined Nov 2004
30oz scale like fight an 3 blade prop wth the stock battery
Old Sep 09, 2005, 11:38 AM
latrans is offline
Joined Aug 2004
Terry,
I think that you will find the info that you need in the parkflyers forum. There is a thread dedicated on converting the PZ P51 to brushless, try the search function. Have you considered building your motor from a GoBrushless kit? I think that it'd be interesting to see what a GBX triple would do for one of these.
Latrans
Old Sep 09, 2005, 09:30 PM
black cat squadon
terryh1313's Avatar
Joined Nov 2004
thanks for the information let you know how it goes
Old Sep 29, 2005, 12:11 AM
mlh1961 is offline
Find More Posts by mlh1961
Indio, CA.
Joined Sep 2005
Terry,
Check out Justgofly.com. They have a video of a super sportster flying on a geared 400df. That plane weighs 3 pounds. So that set-up would definately fly the PKZ P51.
That will be the upgrade for mine when I wear out the stock set-up.
Mitch
mlh1961 is offline Find More Posts by mlh1961
Old Sep 29, 2005, 06:49 AM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
A 400DF geared 3.89:1 can get you almost 40oz thrust at 18.45A with an 12x8 GWS HD - a 9" or 10" 3-blade might draw about the same:
MMM 400DF 3.89:1
10.5v, 18.45A, 193W, 5880rpm, 44.5mph, 1119g, 39.40oz, 5.80g/W
Cheers, Phil
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Sep 29, 2005, 09:28 PM
black cat squadon
terryh1313's Avatar
Joined Nov 2004
well i am waiting on a walkera 3200, so now iwill pick up a gearbox an let you in on the results
Old Sep 29, 2005, 09:36 PM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
Here are a few numbers for the Walkera 3200.
If you need speed try a TM 2000 gearbox with 3:1 ratio.
Cheers, Phil
Old Sep 29, 2005, 09:40 PM
black cat squadon
terryh1313's Avatar
Joined Nov 2004
thanks for your help dr kiwi
Old Sep 30, 2005, 05:50 AM
guapoman2000 is offline
Find More Posts by guapoman2000
Account closed
Joined Oct 2002
Does anyone have a web site for the so called ...walkera 3200???
guapoman2000 is offline Find More Posts by guapoman2000
Old Oct 01, 2005, 08:12 PM
black cat squadon
terryh1313's Avatar
Joined Nov 2004
dr kiwi who makes the tm-2000
Off Site Anyone lookin for a cheap brushless setup? thedave172 Aircraft - Electric - Power Systems (FS/W) 3 Jan 28, 2007 09:55 AM
Discussion brushless setup for gws p-51 malibu43 Electric Warbirds 1 Sep 24, 2006 08:42 PM
Shogun - Looking for a cheap Brushless setup Legion Mini Helis 3 Nov 29, 2004 09:04 PM
Brushless for a GWS P-51 StevePala Power Systems 1 Mar 28, 2003 09:20 AM
WTB Cheap Replacement Motors for GWS P-51 / Zero also GWS crystals Ch 21 Justin Jackson Aircraft - Electric - Airplanes (FS/W) 0 Feb 23, 2003 02:11 PM
