Old Sep 07, 2005, 06:03 PM
Garry Reinhold is offline
Find More Posts by Garry Reinhold
Joined Aug 2005
to grease or not to grease
i am in the process of replacing the oneway bearing in the main gear, should i grease it or not and if so what sort of grease. of even oil?
Garry Reinhold is offline Find More Posts by Garry Reinhold
Old Sep 07, 2005, 11:49 PM
tippy is offline
Find More Posts by tippy
tippy's Avatar
Alabama
Joined Feb 2003
The "greaser" from Heliproz.
http://www4.mailordercentral.com/hel...?number=169165
The "grease" from Heliproz. (EP grease)
http://www4.mailordercentral.com/hel...?number=169169
d.tipton
tippy is offline Find More Posts by tippy
Old Sep 08, 2005, 02:12 PM
barracudahockey is offline
Find More Posts by barracudahockey
Multi-Platform Pilot
barracudahockey's Avatar
United States, FL, Jacksonville
Joined Sep 2004
The one way, or auto hub isn't a bearing its a torrington clutch. Clean all the grease you can out of it. Coat everything with a light coat of tri-flo or atf (tranny fluid)
Drip some tri flo down onto it once in a while and it should be fine.
Also if its a Raptor, don't over tighten the lower jesus bolt, that will distort the gear and make the auto hub lock up.
barracudahockey is offline Find More Posts by barracudahockey
Old Sep 08, 2005, 05:04 PM
Joined Aug 2005
thanks guys that is a lot of help
To grease or Not to grease One Way Bearing??? Hovertime Electric Heli Talk 21 Oct 25, 2008 09:23 PM
Do you guys grease or oil the motors and gearboxes? motoadve Electric Plane Talk 6 May 23, 2005 12:12 PM
gear drive or not? sms Parkflyers 4 Jul 12, 2001 02:11 PM
Speed 280BB - direct drive or not? Tyson Electric Plane Talk 9 Jun 04, 2001 06:12 AM
P-40 Warhawk FLY or NOT Cosmic Shane Parkflyers 0 May 17, 2001 12:54 AM
