Old May 07, 2002, 03:25 PM
William A is offline
Find More Posts by William A
Tacoma, WA, USA
William A's Avatar
Joined Jun 2001
Battery discharge/equalizing trays/racks that the cars guys use
I've seen these battery 'discharge/equalizing' trays/racks that the cars guys use.
Might be a little tough to set up for our kind of packs, but I'm thinking that this might be just the ticket for that 'once in a while' conditioning phase.
One would have to tap into each cell individually(almost impossible on end to end packs). Then discharge each cell to 0? Or ?.
Sure would 'level' the pack out, wouldn't it ?.
Any thoughts ?.
William A is offline Find More Posts by William A
Old May 08, 2002, 07:21 AM
Arizona Chuck is offline
Find More Posts by Arizona Chuck
Old Desert Rat
Arizona Chuck's Avatar
Rimrock AZ. USA
Joined Mar 2000
I don't think it would be worth the effort. A slow charge will do the same thing.
I only discharge individual cells if I'm looking for a bad cell or building a pack out of used batteries.
Arizona Chuck is offline Find More Posts by Arizona Chuck
Old May 08, 2002, 07:41 AM
Marten is offline
Find More Posts by Marten
..teach monkeys to fly..
Marten's Avatar
Ottawa Intl, Canada
Joined Oct 2000
I have a 12 cell pack of 1200's that came bundled with my Astro 15G more than ten years ago. It doesn't see much service, so YMMV, but I soldered either 32 or 40 ohm (I forget exactly which, or the wattage, which is either 1/2 or 1) resistors across each cell, causing each cell to discharge to zero over a few days.
It takes a few cycles to get full capacity out of the packs, but judging from the voltage at the end of charge, their resistance hasn't changed, and they are balanced. The way they dump at the end is a bit of a disadvantage, in a way, since Murphy will ensure I'm downwind, low and inverted when it happens. :eek
Marten
Marten is offline Find More Posts by Marten
Battery discharge rates and amps? jf ryan Batteries and Chargers 14 Sep 12, 2007 01:14 PM
how to discharge a battery for equalizing? Joel K. Scholz Batteries and Chargers 3 Jun 28, 2005 10:09 AM
What kind of battery packs do you guys use??? andyg Hand Launch 16 Nov 11, 2004 08:26 AM
Battery discharge data......... HankF Electric Heli Talk 3 Mar 29, 2002 09:56 PM
Hinge tape for Omega 1.5; what do you guys use? jbrundt Electric Sailplanes 8 Mar 23, 2002 09:08 PM
