Old Jul 07, 2001, 07:03 PM
mrebman is offline
Find More Posts by mrebman
Cincinnati, Ohio USA
Joined Nov 2000
Where should the Litestick CG be?
I have just finished my Litestick, the Instructions say the CG should be at about 60MM from the wings leading edge. The best I can do is like CG at 70 MM, I've got all the stuff slid almost up to the motor. How far back should the wing & Radio gear be from the motor?
mrebman is offline Find More Posts by mrebman
Old Jul 07, 2001, 08:39 PM
jeffs555 is offline
Find More Posts by jeffs555
"Simplify, then add lightness"
Raleigh,NC
Joined Nov 2000
You just need to slide your wing back toward the tail a little. Mine has crashed and been repaired so much I don't know how far back the wing should be on a stock Stik.
jeffs555 is offline Find More Posts by jeffs555
Old Jul 07, 2001, 08:55 PM
Rekit is offline
Find More Posts by Rekit
Garland, Texas
Joined Jul 2000
Somewhere between 25 to 35% of the wing cord
Lynn
Rekit is offline Find More Posts by Rekit
Old Jul 08, 2001, 03:03 AM
JJfromUK is offline
Find More Posts by JJfromUK
Spent too much already..
JJfromUK's Avatar
East Yorkshire, England
Joined May 2001
I'm sure these things aren't too critical, my Picostick flies quite happily at 80mm from the LE, over 48%.
It has a large tail area to stabilise it.
I have been flying a few years now but I'm not THAT good, wouldn't dream of trying a conventional model so tail heavy.
[This message has been edited by JJfromUK (edited 07-08-2001).]
JJfromUK is offline Find More Posts by JJfromUK
Old Jul 09, 2001, 12:04 AM
Paul Susbauer is offline
Find More Posts by Paul Susbauer
Balsa Builder
Paul Susbauer's Avatar
United States, OR, Hillsboro
Joined Apr 2001
I'd leave it slightly tail heavy, and turn up the throws a lot and you will have a really manueverable ship. Everytime that I've built lite stiks I don't even bother to check the CG
Paul Susbauer is offline Find More Posts by Paul Susbauer
Discussion Where should the antenna wire be soldered? Twin-Jet-Crash Radios 5 Jul 09, 2006 05:00 PM
Where should the true CG be on the GWS BN2 Islander?? mrebman GWS (Grand Wing Servo) 5 Nov 07, 2005 08:40 PM
Need Help! - Where should Formosa CG be? mrebman Parkflyers 5 Apr 02, 2005 06:25 PM
About to maiden Estarter - Where should I have CG? mrebman Parkflyers 12 Sep 03, 2003 11:59 PM
Another New Zagi owner, where should the C.G. be?? thor4944 Foamies (Kits) 1 Feb 06, 2002 08:02 PM
