Old Sep 04, 2005, 02:17 PM
kryptoniteRxn is offline
Find More Posts by kryptoniteRxn
NO NO come back...spLAT!!
United States, CA, Anaheim
Joined Sep 2005
Differences bt electronic (piezo) & mechanical gyro?
anyone know the true differences between the electrical (piezo) and mechanical gyro? Some have dual rate and reverse functions, wat that? i'm guessing reverse func is for 3d when inverted, but not so sure...thoughts?
kryptoniteRxn is offline Find More Posts by kryptoniteRxn
Old Sep 04, 2005, 02:45 PM
Rickenbacker is offline
Find More Posts by Rickenbacker
Sunday Flier
Rickenbacker's Avatar
Sweden
Joined May 2005
Piezo has no moving parts, mechanical has a spinning wheel. Don't know if you can actually still get mechanical ones, and don't know why you would...
You reverse the gyro if it compensates in the wrong direction, doesn't matter if it's upside down (the gyro doesn't know it's upside down, it only knows about rotation in a single plane, yaw).
Dunno what you mean by dual rate. Some gyros have a Heading Hold mode, some don't, and the HH ones can usually switch to Rate mode (where the gyro compensates for all movement, even commanded by you). This might be what you mean...
Rickenbacker is offline Find More Posts by Rickenbacker
Old Sep 04, 2005, 03:22 PM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Piezo gyros weigh less, use less power and can be made to function at larger yaw rates than mechanical ones.
As far as I know none of the mechanical ones offer heading hold.
I still have mechanical gyros in some of my older helicopters and they work fine, but the newer piezo ones are a definite improvement.
If I flew the old ones much, they would probably get new piezo gyros.
Pat MacKenzie
pmackenzie is offline Find More Posts by pmackenzie
Old Sep 04, 2005, 03:31 PM
pmackenzie's Avatar
Joined Dec 2002
I missed two of your questions.
The reverse switch on any gyro is there so that when mounted right side up the feedback can be applied in the correct direction.
This depends on the servo and tail rotor arrangement so there has to be a switch, or you have to flip the gyro upside down.
Dual rates on older gyros were a way to allow high gain when the head speed was low for hovering and lower gain when the head speed was higher or in fast forward flight.
Higher end mechanical gyros had variable gain controlled from the transmitter, just like some piezo gyros (GY401 for example)
Pat MacKenzie
Old Sep 04, 2005, 05:25 PM
Joined Sep 2005
well said, thank you all, i have a GY401 gyro on a gas heli i recently acquired, was planning on strip the heli aprt and sell the parts to generate fund for a trex, now i dont think i'll sell that gyro, lol.
gas heli is such a @#$%, the fuel mess everywhere! i might say that everytime youfly, it's like the heli went thru a period of diahrea. so i'm goin all electric.
Old Sep 05, 2005, 03:22 AM
mattijs321 is offline
Find More Posts by mattijs321
Joined Nov 2003
piezo gyros do have moving parts...the crystal sensor vibrates and the coriolis forces caused by the yaw are measured.
State of the art gyro's now use arrays of micro machined parts and basicly are mechanical gyros again. Albeit being very very very small.
The futuba line of gyros is the only type of gyro that uses a round sensor (instead of just one string of crystal material) that is more accurate than most other gyros. They are less prone to vibration as the round shape helps it to be inneffected by vibration.
That's why futuba gyros don't need damping with foam while others can benifit greatly from physical damping.
If you've ever seen a futuba gyro from the inside you'll notice that about 60 procent of it's weight comes from the sensor alone. (very big metal case inside)
This makes am so heavy compared to others but it's als the reason that for the micro's they are the best hands down.
mattijs321 is offline Find More Posts by mattijs321
Old Sep 05, 2005, 04:55 AM
Joined Sep 2005
we need more peopl like you (matt), answer with actual knowledge and not just personal like or dislike. thnx
Old Sep 05, 2005, 07:02 AM
Joined Nov 2003
nice to hear
I might be biased too as i've only tried GY's and csm gyros.
The sensor on futuba's being very good quality is fact though.
They have less temperature drift and are less prone to vibration.
The fact that csm recommends you to warm up the gyro for 2 minutes for "competition usage" says alot to me !
BTW some very good threads about the workings of gyros have been posted here but i can't be bothered tp look them up as i've got alot on my mind lately. I'm applying for a secondary master education and i have an entrance exam tomorrow
Sold FS Century piezo rate Gyro used disciple Aircraft - Electric - Helis (FS/W) 4 Aug 16, 2005 09:47 PM
F/S Ms-44 Heading lock piezo rate gyro. reznikvova Aircraft - Electric - Helis (FS/W) 3 Dec 31, 2004 04:33 PM
Cool JR 400 Piezo Rate Gyro fenderjw Aircraft - Fuel - Airplanes (FS/W) 0 Jan 07, 2004 09:10 PM
LMH mechanical gyro or piezo jschick Electric Heli Talk 6 Sep 07, 2001 11:38 PM
