Old Oct 31, 2005, 06:50 PM
Monterey Bay California
Joined Feb 2004
Looking good, Pat! Looks like a fairly robust structure but have you encountered or do you anticipate there being any 'oil canning' problems with the plastic sheet skin?
Aerominded is offline Find More Posts by Aerominded
Old Oct 31, 2005, 09:12 PM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Aero, I'm not anticipating any problems with the skin at all. The CC 19' Racer had less sub-structure and hasn't been any problem either. Using that stuff to skin hulls was truely a stroke of genious over at Dumas -- very inovative thinking.
PAT
P. Tritle is offline Find More Posts by P. Tritle
Old Nov 02, 2005, 08:09 PM
Joined Feb 2004
Cool deal! It does look like this type of construction will reduce finishing time significantly!
Old Nov 04, 2005, 02:31 PM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Starting the Cabin Assembly
The cabin assembly is pretty straight forward on the cavalier. The major assembly is done right on the hull, so when it's all done there's no doubt that it'll fit. For themost part, parts fit has been pretty good, although a couple of the innere frames were a bit short and needed shimming. Not a big deal, just requires a bit of time to get things lined up nicely.
Once the main cabin sub-assembly is finished, the mahogany veneer is applied. It goes on in several pieces which are fitted individually. So far, so good. Will follow up with more pics as things progress.
PAT
Old Nov 06, 2005, 08:56 AM
Lipoly Killer
Frank Hurd's Avatar
Gulfport/Biloxi Biloxi Reg, Mississippi, United States
Joined Dec 2000
Hi, Pat!
Pat, you are a master builder and very few of us can even approach your level of skill. (I'm not one of the few). The one thing that bothers me about your Cavelier build article is that you mention several times that that some of the pieces don't fit and you have had to make allowance for these errors. Believe me, I appreciate your honesty in reporting these errors! However, has the manufacturer made any indication that they will correct these errors? The price of the kit is a large investment and then when you consider running gear, batteries and radio, the builder has tied up a substantial amount of cash in the boat. I know we have come a long way from the old Berkeley and Sterling kits of yesterday but so have the prices.
Frank
Frank Hurd is offline Find More Posts by Frank Hurd
Old Nov 06, 2005, 02:44 PM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Frank, Thanks for the kind comments, I really apreciate it. Don't let the minor parts fit problems scare you. The main reason I mentioned them was to give a heads up that a dab of tweaking here and there is needed to get things just right. As kits go, this one really is very well done, and the minor "infractions" are really easy to work with. When the build is done, I'll send a list over to Rich and we'll review all of it. I wouldn't be right to "not mention" the small problems which have come up, then let someone who thinks all is -- for lack of a better term, perfect -- be blindsided by some of the minor discrepancies. I'm not one to slam a kit, unless, it's REALY bad, but it's not right to gloss over the potencial problem ares either.
PAT
Old Nov 17, 2005, 11:09 AM
Joined Feb 2004
Any time for the Cavalier lately, Pat?
Old Dec 08, 2005, 08:23 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Back on the Project Again
Had a BIG commercial project in late October and most of November that knocked the schedual clear out of whack, but am now getting caught up with the regular stuff again, and am back on the Cavalier.
Work on the cabin is just about finished. The wood top, which will be painted, has been sealed with 3 coats of nitrate dope and puttied to fill the wood grain. The next step will be to get it primed and fill the last of the flaws.
Old Dec 08, 2005, 08:30 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Adding the Mahogany Veneer
The mahogany veneer is added to the inside of the aft cabin sides and to the rear cabin wall. The parts are trimmed to fit, glued in with medium Cya and clamped till the glue sets up. Veneer will be added to the edges once the big pieces are in and all will be smoothed up together. Then once all the veneer is finished and sealed, paint work can get underway.
Old Dec 08, 2005, 08:37 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Small Parts and Sub Assemblies
While the sealer is drying here and there, the time was used to jump ahead a bit and start working up the small sub-assemblies.
The rear seat was built up and sanded, along with the cushions for the deck chair assembly. The cushions will be sealed with 4 coats of nitrate dope and painted.
The mahogany instrument console was built up and sanded to shape. Once the rest of the mahoganny work is finished in the cabin area, the whole thing will be sealed up with several coats of varethane varnish.
PAT
Old Dec 08, 2005, 01:25 PM
Joined Feb 2004
Looking great Pat!!! The cut outs on the instrument panel are a nice touch! is that the way the kit comes or did you modify that? should look great with the instrument faces in place!
Old Dec 08, 2005, 05:15 PM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Aero, That's the way the panel came. The holes are laser cut so are nice and clean. Made som more progress today, will post more pics a little later.
PAT
Old Dec 10, 2005, 08:32 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Adding the Aft Cabin Veneer
Got the last of the veneer on the aft cabin today. Decided to add veneer to the top of the aft railings to keep it all nice and uniform. Once it was all shaped and finish sanded a coat of resin was applied. The shop is a bit shall we say, a bit cool this time of year so the resin is curing a bit slow. Will get it re-sanded and a second coat on next week. Also got 3 coats of nitrate dope on the seat cusions to, so they're ready for paint. And finally, the second coat of resin is on the instrument console too, and it's looking pretty good, so will stop there.
PAT
Old Dec 12, 2005, 08:56 PM
Joined Nov 2004
Hey Pat lookin great!!!
I'm enjoying following your build. And like everyone else I'm always excited to see what you will build next.
I like the way Rich did this cabin apposed to my Dumas Commander.
bluezephyr is offline Find More Posts by bluezephyr
Old Dec 15, 2005, 06:27 PM
USA, NY, Mahopac
Joined Dec 2002
Just got one off ebay new in sealed box with mack power, lights and horn 178.00!!! can't wait
vett is offline Find More Posts by vett
Legend Model Boats "Thunderbolt" Kit Review P. Tritle Scale Boats 122 Feb 28, 2013 03:06 PM
Discussion Legend Model Boats Lyman? Aerominded Scale Boats 19 Nov 19, 2006 09:34 AM
Article Isthmus Model's Zephyr 2 Built Up Kit Review spaulj Sailplane Talk 3 Feb 03, 2005 03:00 PM
Kit Review on the Klien "American Beauty" P-51 Mustang from Hobby-Lobby latch66 Electric Plane Talk 43 May 19, 2004 10:09 PM
