Old Sep 02, 2005, 01:33 PM
karl51 is offline
Find More Posts by karl51
Baraboo, WI
Joined Aug 2003
World Models J-3 Cub EP What Servos?
Hi All, I've been reading the threads and can't find what type of servos I need to order for my new world models airplane J-3 cub EP with a 48.5 in wingspan. I was going to order four hs-55's or do you all feel that I should use a different servo? Do I also need a "Y" adopter for the two aileron servos? Thanks for your help....
karl51 is offline Find More Posts by karl51
Old Sep 02, 2005, 02:16 PM
WolfeWind is offline
Find More Posts by WolfeWind
Joined Apr 2004
I am using HS-55's on a couple of other WM planes - no problems with them so far.
WolfeWind is offline Find More Posts by WolfeWind
Old Sep 02, 2005, 02:19 PM
karl51 is offline
Baraboo, WI
Joined Aug 2003
Answer:::
Thanks I am looking at the HS-55's I've used them in other airplanes and I've had no problems with them also Hobby People have them on sale...thanks!!!
Old Sep 02, 2005, 04:41 PM
bernoo is offline
Find More Posts by bernoo
Closed Account
Joined Oct 2003
I havw just fitted Park Flyer R/C servos to my WM Cub. They fit fine and are reliable and inexpensive.
Cheers
bernoo is offline Find More Posts by bernoo
Old Sep 02, 2005, 08:14 PM
karl51 is offline
Baraboo, WI
Joined Aug 2003
My Airplane Arrived!!!
Hi All, The WM Cub arrived today and looks great so far. I did order 4 HS-55. Something new on the WM cub is the servo's no longer mount in the rear of the airplane but now have a servo tray inside the airplane. Now the only problem is the plastic windows are yellow. I think that is going to take away from the piper cub look, but I am going to install the yellow window. I want to make this cub as close to stock as possible. I am making a change to the controller. I am not using a 15 amp but will use a 35A I don't believe a 15 or 20 amp controller will work with 4 servos and a 400 motor. I also will be adding 2 1/2" wheels so I can land on grass. Last problem DO I NEED A "Y" HARNESS for the AILERON?
For Sale FS: World Models Piper J-3 Cub EP BrandoUno Aircraft - Electric - Airplanes (FS/W) 2 Jun 21, 2005 02:27 PM
World Models J-3 Cub and floats?? BrandoUno Waterplanes 3 Jun 03, 2005 10:23 AM
World Models $100 Piper J-3 Cub EP 400 ARF aeropal Parkflyers 1 May 23, 2004 11:42 AM
World models Piper J-3 Cub 26 WHAT MOTOR? exempt Sport Planes 16 Mar 01, 2004 03:43 PM
World Models J-3 Cub-48 Trroscoe Aircraft - Fuel - Airplanes (FS/W) 0 Oct 27, 2003 03:20 PM
