Old Sep 01, 2005, 08:43 PM
Dhammapol is offline
Find More Posts by Dhammapol
Joined Jan 2005
Question
FET & Max. Amp for BL speed controller
Hi
As my bl speed controller burnt out, I cannot find the same FET to replace. Howerve, I can find different FET in my local with slightly different spec.
So, I have a question about how to rate the max. amp for my speed that used new FET. Anyone counld give suggestion to approximate for this?
Dhammapol is offline Find More Posts by Dhammapol
Old Sep 03, 2005, 09:29 AM
Franck is offline
Find More Posts by Franck
-plancks only-
Franck's Avatar
The Netherlands, UT, Benschop
Joined Oct 2001
If you want a decent answer to your question you should give more info on this. What controller, FET replacement etc etc.
I have had very little succes with replacing burned out fets, even when replacements were of the same type.
Regards,
Franck
Franck is offline Find More Posts by Franck
Old Sep 04, 2005, 08:22 PM
Joined Jan 2005
Thanks for your suggestion.
The original pFET is SI4425 in Jeti 30Amp.
Rated for SI4425: Ron @ 4.5v 0.019Ohm, Id = 9.1Amp
But I have IRF7424
Rated for IRF7424: Ron @ 4.5v 0.022Ohm, Id = 8.8Amp
In the controller, it use 3 FET for each phase.
One more question, It will has any effect for different FET spec. in each phase.
Old Sep 05, 2005, 03:34 AM
Rajesh L G is offline
Find More Posts by Rajesh L G
Bangalore, India
Joined Nov 2003
Better not mix up different types of FETs in parallel. Unless the characteristics are very similar, the current will not be distributed in all the parallel branches uniformly. The branch sinking more current might burn out.
If your FET has nearly the same threshold and Rds ratings, you could however replace all FETs of that type with the new one. You also have to make sure gate charge value is not very different either.
-- Rajesh
Rajesh L G is offline Find More Posts by Rajesh L G
Old Sep 05, 2005, 05:26 AM
Franck is offline
-plancks only-
Franck's Avatar
Joined Oct 2001
Correct.
I have a strong feeling that the FET's on the controllers are matched, so replacing just one FET even if it is the same type will probably mess things up.
I had very little succes replacing single FETs on a number of controllers.
Old Sep 05, 2005, 08:32 AM
Joined Jan 2005
Many Thanks for suggestions.
How I can estimate the max amp for new replancement FET?
Old Sep 05, 2005, 10:42 AM
Bangalore, India
Joined Nov 2003
In ESC applications where heatsink is small or not present at all, the current is limited by the power dissipation, not the max current rating. The actual power dissipation will depend on the load type and rise time, but I have found a thumb rule of about 0.4W works well for SO8 package. Actually this might be conservative since my designs barely gets warm.
I assume your controller has a uC driving the mosfets working off a 5V supply as usual. Find the Vds vs Id graph for Vgs = 4 or 4.5V(covering for uC output stage losses). Your max practical Id will be the value where Vds*Id = 0.4W along the graph.
-- Rajesh
Old Sep 06, 2005, 10:30 PM
Joined Jan 2005
Thanks Rajesh,
DP
Trade Norvel 074 for CC 25 amp brush less speed controller. mike7130 Aircraft - Fuel - Airplanes (FS/W) 1 Jan 03, 2005 01:57 PM
max amp for miniAC 1215-16 geared fourstarforty Power Systems 35 Aug 27, 2003 01:40 PM
website for Eflite speed controller's taekwondo Power Systems 5 Jul 07, 2003 07:32 AM
max current for Graupner Speed 480 BB Race? joey221 Power Systems 2 May 02, 2002 07:40 PM
Max amps for Graupner speed 280 race version? Vonbaron Power Systems 2 Apr 08, 2002 04:57 AM
