Old Sep 01, 2005, 05:22 PM
putt_13 is offline
Find More Posts by putt_13
putt_13's Avatar
Minneapolis, MN
Joined Aug 2002
Need info on an AC Lithium-Polymer Charger??
Hello,
I am looking for some input on what a good AC-compatible LIPO charger would be. I will be charging mostly 3-cell 2500mah batteries.
I wont have the availability of a car battery while in my dorm room, so I need a charger I can plug into the wall.
Thanx -Patrick
PS- If I was to connect my DC Charger to one of those wall converters, what would the output need to be to charge 3-cell batteries? I know it would need to be 12V DC, but what about the MAH output.
putt_13 is offline Find More Posts by putt_13
Old Sep 01, 2005, 05:30 PM
flybike is offline
Find More Posts by flybike
Lance Armstrong- 7 times!
flybike's Avatar
Madison, Wisconsin
Joined Sep 2001
It depends what your charge rate is. 1C for a 2500 is 2.5 amps, so any adapter that puts out 3 amps will work. Of course, if you have a smaller adapter, you can just charge at a lower rate. Just make sure you dont push the adapter too much or the voltage will drop.
I finally broke down and bought a Radio Shack 15 amp power supply, but you can get computer power supplies much cheaper.
-Hans
flybike is offline Find More Posts by flybike
Old Sep 01, 2005, 05:33 PM
hall woo is offline
Find More Posts by hall woo
Permanently Banned
San Jose Ca / RSA flyer
Joined May 2003
Or surplus switching power supplies
hall woo is offline Find More Posts by hall woo
Old Sep 01, 2005, 05:43 PM
Patrick Plawner is offline
Find More Posts by Patrick Plawner
Patrick Plawner's Avatar
Joined Sep 2001
putt_13, per your request, moved to the battery forum.
Cheers,
Patrick.
Patrick Plawner is offline Find More Posts by Patrick Plawner
Old Sep 01, 2005, 05:59 PM
MrHmmm is offline
Find More Posts by MrHmmm
Multi discipline RC'er
MrHmmm's Avatar
Netherlands
Joined Aug 2005
Maybe you can use an old computer power supply. Check the wattage of the supply and do some internet research on how to make it work with a normal switch. Most computer power supplies can't be put on without a load, so you need a resistor to make things work. Check the internet for instructions (I used dutch instructions, don't think you can read dutch )
MrHmmm is offline Find More Posts by MrHmmm
Old Sep 01, 2005, 06:36 PM
BEC is online now
BEC
Find More Posts by BEC
BEC
BEC's Avatar
Auburn, Washington USA
Joined Jan 2001
Alternatively, there IS one AC/DC lithium-capable charger I'm aware of. I've just started testing one - it's called the WattAge Charge-It-All Sport. So far it is doing exactly what is claimed for it. http://www.hobbypeople.net/gallery/130116.asp
I'm generally not in favor of multi-chemistry chargers simply because all it takes is one mistake of charging lithium on the nickel setting and you have "venting with flames". But on this one which mode it's in is pretty clearly displayed and easy to verify before pushing "start".
Of course if you have a suitable DC charger you can get an adequate power supply for much less than the cost of this WattAge charger.
BEC is online now Find More Posts by BEC
Old Sep 01, 2005, 10:26 PM
ptglass is offline
Find More Posts by ptglass
ptglass's Avatar
USA, TX, Live Oak
Joined Oct 2002
Take a look at Balsa Products. They have a plug-in AC charger for 3 cell lipos for only $12 It will take a little longer to charge, but what a deal!
Link: http://www.balsapr.com/catalog/battN...ductId=V723156
ptglass is offline Find More Posts by ptglass
Old Sep 09, 2005, 12:18 AM
docprego is offline
Find More Posts by docprego
Henderson, Nevada
Joined Mar 2000
Has anyone ever used this type of charger at Balsa Products for $12.00? It seems fairly foolproof, plug it in and wait for the green light. I only need AC LiPo charging, this seems ideal. Any opinions and experiences?
docprego is offline Find More Posts by docprego
Old Sep 24, 2005, 08:54 PM
savydad is offline
Find More Posts by savydad
Indianapolis, IN
Joined Aug 2005
bec, have you made any conclusions on your testing of the charge-it-all? What I'm looking for is does it charge lipos anywhere close to as much capacity as possible or near what a af109,triton,ice,schultze, similar charger? I was looking at the hobbico mkII, and the pro-peak prodigy II, how would this one compare? Besides the obvious of ac/dc, can you compare it with these two? Does it charge, say a 2 cell lipo to 8.4v or like the mkII ~8.2v? Interested in your testing results. Thanks
Todd
savydad is offline Find More Posts by savydad
Last edited by savydad; Sep 24, 2005 at 08:58 PM. Reason: pf12 doesn't charge lipo, changed to pro-peak prodigyII
Old Sep 24, 2005, 08:58 PM
deSelby is offline
Find More Posts by deSelby
Undecided, Canada
Joined Aug 2005
The Vision Peak Ultra is worth looking at. Will do all types of cell and has a few bells and whistles.
deSelby is offline Find More Posts by deSelby
Old Sep 24, 2005, 09:10 PM
adamg is offline
Find More Posts by adamg
adamg's Avatar
Saskatoon, Canada
Joined Feb 2004
http://parts.rctoys.com/rc-toys-hobbies/Items/410110?
adamg is offline Find More Posts by adamg
Old Sep 24, 2005, 11:19 PM
BEC is online now
BEC
BEC
BEC's Avatar
Joined Jan 2001
Todd,
I went to my graphs and I've only done one of this charger on lithium - it brought a 3s Kokam 910 pack up to about 12.55V. So, if that's typical it charges more fully than the much discussed Hobbico Mk. II. I don't have any experience or knowledge of the ProPeak Prodigy. This level is a touch below what the AF 109 does, but I, for one, would not quibble about 0.05V (or less than 0.02V per cell).
deSelby - that looks interesting. It seems to have similar capabilities to the WattAge charger I suggested along with a readout of current and voltage.
Adamg - that's not a bad idea - teaming the TP-425 with an adequate power supply. Strangely enough I have a DC power supply that looks like the one Dragan is selling from a dead flat panel monitor that drives the TP-425 nicely and the plugs are even compatible.
Old Sep 25, 2005, 12:48 AM
savydad is offline
Indianapolis, IN
Joined Aug 2005
ok, thanks bec. I've been doing some research on chargers as I need one soon for my smaller nimh's at the field. I plan on lipos sometime in the near future and trying to find which would best suit my needs. the wattage also charges at up to 3 amps on lipos, which would seriously help if I go to 2000mah or up as the mkII only does 1 amp max. I looked over hobbypeople's site, and they have a different brand charger with the exact case the wattage has, called the "black widow" and it has a lcd screen. Lots of info to explore still, and I'll research it to death before I decide. Thanks for the report, it does charge a bit more than the mkII.
Todd
Old Sep 25, 2005, 12:18 PM
LTChip is offline
Find More Posts by LTChip
LTChip's Avatar
Helena, MT
Joined Feb 2003
http://www.balsapr.com/catalog/battN...ductId=V936375
Add that to any charger and you are set.
LTChip is offline Find More Posts by LTChip
Old Sep 25, 2005, 10:13 PM
savydad is offline
Indianapolis, IN
Joined Aug 2005
thanks LT, but ac/dc isn't really a concern for me, just fuller charging and all types compatible. I've got a pyramid 15A ps for the house, and both my chargers are dc.
Todd
Question Need Info on an Orion Motor I have Dan_eflyer Power Systems 4 Sep 02, 2004 07:47 AM
Need info on an Ikarus pack! Please help! doc-e Batteries and Chargers 0 Aug 09, 2003 07:41 PM
Need some info on the Mini Ac motors kushal_22 Power Systems 6 Feb 17, 2003 03:16 AM
Need info on Lithium batteries thor4944 Batteries and Chargers 7 Dec 23, 2002 05:10 PM
Still need info on how to retime a motor with an Astro Super Whattmeter Joe Elston Electric Plane Talk 8 May 19, 2001 11:42 PM
