Old Aug 31, 2005, 12:58 PM
killerstick is online now
Find More Posts by killerstick
electric fly
3rd rock from the sun--east coast
Joined Sep 2004
Great Planes Seawind amphibian
Looking at the Great Planes Seawind for possible electric power using AXI 4120 series motor. There's plenty of room under the cockpit and mounting the motor looks easy with a lot of room under the cowl.
Looking for input.
Thanks, Wayne...
killerstick is online now Find More Posts by killerstick
Old Aug 31, 2005, 01:20 PM
gwh is offline
gwh
Find More Posts by gwh
gwh
Fort Worth, Texas
Joined Dec 1996
Based on the suggested weight of 10 to 12 pounds, I would suggest that you consider the 4130/16 on 6S instead. In the manual it mentions that a 3 bladed prop is required for prop clearance. You will also probably want to go with a 3 or 4 blade Vario Prop so that you can adjust the pitch to load the motor and keep the diameter to 13 or 14 inches. It is not possible to determine for sure that a 14 inch prop will fit from browsing the manual. Depending on the type of performance that you desire, it may be better to go with a geared inrunner motor to allow for more rpm with a smaller prop because of the limited prop diameter.
gwh is offline Find More Posts by gwh
Old Aug 31, 2005, 01:28 PM
electric fly
Joined Sep 2004
Great input about the prop clearance. Thanks
Need to get the centerline distance to the fuse for motor selection.
Old Sep 05, 2005, 05:06 PM
lymantok is offline
Find More Posts by lymantok
San Diego, CA
Joined May 2000
Any thoughts on using an electric ducted fan for this sharp looking seawind kit? Too heavy? Too much fuselage rework?
lymantok is offline Find More Posts by lymantok
Old Sep 13, 2005, 07:59 PM
rcmob is offline
Find More Posts by rcmob
Joined Aug 2004
A 14" prop does not fit the Seawind. 13" is the maximum.
rcmob is offline Find More Posts by rcmob
Old Sep 14, 2005, 10:06 AM
Fredrik W is offline
Find More Posts by Fredrik W
Fredrik W's Avatar
Stockholm, Sweden
Joined Jul 2002
Thanks for the input RCMob. Have you measured it yourself or did you hear it some where?
Does any one knew if it is possible to use the retractable gears when flying of water? Or is the wheel wells not water tight?
// Fredrik Wergeland
Sweden
Fredrik W is offline Find More Posts by Fredrik W
Old Sep 14, 2005, 11:08 AM
jonnyjetprop is offline
Find More Posts by jonnyjetprop
jonnyjetprop's Avatar
USA, FL, Apopka
Joined Sep 2003
Any thoughts about going with something like this:
Mega 22/30/4
8s lipo
Low gear ratio like 2:1
13x10 APC e prop
It seem like a good direction when I pluged it into motocalc. I don't have any experience with this setup, but thought it might spur you to look in a different direction.
John
jonnyjetprop is offline Find More Posts by jonnyjetprop
Old Sep 20, 2005, 12:30 PM
gouda is offline
Find More Posts by gouda
Is it summer yet?
gouda's Avatar
Flight Level 46 X 92
Joined Feb 2002
Fredrik. Robart is making retracts for this plane. On towerhobby.com search @ enter robq1622. You'll find them. I really like this plane. I thinks it's going to be a 12 pounder by the time it EP'ed, maybe a bit more. Any ideas for power? A Axi would be nice, but if the prop diameter is limited, that may not be the best choice.
jonnyjetprop, looks like a good idea, what weight did you use?
gouda is offline Find More Posts by gouda
Old Sep 23, 2005, 06:50 PM
workshop is offline
Find More Posts by workshop
Closed Account
Joined Nov 2004
I'm using an AXI 4120/10 with a 12x10x3 prop and I'm getting almost 8000 rpm at 60A on 5s...
I think low winding (i.e.10) AXI's work well with smallish diameters of a 3 blade prop...
Jeff
p.s. more motor info at:
http://www.rcgroups.com/forums/showthread.php?t=372589
workshop is offline Find More Posts by workshop
Old Sep 24, 2005, 03:51 AM
Fredrik W's Avatar
Stockholm, Sweden
Joined Jul 2002
4120/10??? Never heard about that motor before. And I cant find it on Model Motors site either! Where did you buy it?
Sweden
Old Oct 04, 2005, 02:04 PM
Thomas B is offline
Find More Posts by Thomas B
Electric Coolhunter
Thomas B's Avatar
United States, TX, Fort Worth
Joined Jun 2000
Sweden
With the stock setup, you cannot use the retracts on a flight off water, as GP suggests taping the nose gear well closed with some type of cover.
An enterprising modeler could probably modify the aircraft with a fully sealed nose gear retract bay and some water resistant doors.
Thomas B is offline Find More Posts by Thomas B
Latest blog entry: 2014 events and travel
Old Oct 04, 2005, 08:04 PM
fhhuber506771 is offline
Find More Posts by fhhuber506771
Deletedfor proving Nauga wrong
Joined Mar 2005
There's another thread about the use of retracts and operating off water...
Basicly.. they want you to seal the door with tape to protect the retract mechanism from being damaged by immersion-corrosion.
Its not hard to seal up the "bay" the retract is in and still operate the retracts.. and the plane accelerating in the water should drain the bay quickly if the door is not sealed. So all you have to do is make sure the main hull won't flood via the gear bay.
It may be possible to grease the retracts on a regular basis and prevent corrosion damage... but they are not designed for being immersed...
And if it has foam tires.. you'd want differnt tires. You don't want them acting as sponges when you taxi into the water, pull the wheels up and do a take-off.
fhhuber506771 is offline Find More Posts by fhhuber506771
Article Great Planes Seawind 71" ARF E-Conversion Review kingsflyer Glow to Electric Conversions 377 Sep 25, 2015 03:33 AM
Build Log Great Planes Seawind - Electric Conversion kingsflyer Waterplanes 41 Aug 09, 2007 07:26 PM
Video Great Planes Seawind electric conversion SaulOhio Electric Plane Talk 0 May 26, 2007 09:05 PM
Great Planes Mfg. Seawind .60-.91 Sport-Scale Amphibian ARF Dave Lauck Product Announcements 0 Jul 19, 2005 03:21 PM
