Old Aug 31, 2005, 10:56 AM
Keep off the Grass!!
Adrian Britton's Avatar
Cardiff Wales UK
Joined Jun 2003
"BRAVE CHICKEN" - or call it wot you like!
Well! I've reached the age and/or stage where I turn up to fly - and hardly ever do
My scale models, and their vulnerability (?) are making me turn "chicken"
So I'm breaking away for a bit to conjure up a little 400 thing that shouldn't scare me. As I am not sure exactly what it's going to turn into, some of you might like to build it along with me and innovate as you please.
I had shoulder, mid and low wing in mind. I think I'll go for low though - can put little legs on it!
Wing menu is....
3/32 sheet front sub-spar capped after structure completed with 1/8 LE.
1/8 sq main spars.
1/8 sheet rear sub spar. Ailerons will be of 1/8 sheet. Stock 1" x 1/4 TE will be used acroos the centre section and at the tips.
Structure begins by attaching 1/8 sq bottom spar to 1/32 sheet LE sheeting,
which should be cut approx 1-5/8 wide. This assembly is then pinned down, packed up, followed by the pinning down of the 1/8 sub TE (packed up with 1/8 scrap). Use a rib to line this up as you pin down.
The attached pics show the rib dimensions in millimetres.
The ribs on the outer panels are 60 mm apart. The centre section is intended to be fully sheeted wher it joins the fuselage....somewhere
From tip rib to tip rib is 30". So you can play with these pics or go pencil and ruler!
This is what happens when you can't sleep, and get up before dawn - and eat kippers
I'll be back when I've don a bit more....
Ade
Adrian Britton is offline Find More Posts by Adrian Britton
Old Aug 31, 2005, 12:31 PM
Cardiff Wales UK
Joined Jun 2003
Wing section
Vertical grain 1/32 sheet spar webs should complete the "D" box.
Ade - report later...
Old Sep 01, 2005, 01:41 AM
Cardiff Wales UK
Joined Jun 2003
What to do Today?
Am I in the right forum for this one
Maybe I should convert it into a control liner and get into even more of a tangle
Well here's a three - view anyway.
Left side has smoothed out tip corners... trickier, now that I've practically built the wing.
I'm going to start on the fuselage today, mainly from 1/16 sheet with 3/32 formers. The sides should blend into the fin at the rear. The 400 (or maybe a 480) will be clamped into a rolled 1/32 tube. That will determine the width.
I think I'll make this a one-piece model with a top hatch.
Ade
Old Sep 01, 2005, 07:43 AM
Having Fun!!!
FredN's Avatar
Cary, North Carolina, United States
Joined Jun 2001
Looks Cool. Should be a fun little plane.
Fred
FredN is offline Find More Posts by FredN
Old Sep 01, 2005, 07:54 AM
What power line?
PoudreDerf's Avatar
Rocky Mountains
Joined Aug 2004
Bored, Adrian?
Adrian, if you're turly bored, you can come and work on my Aircraft Carrier for me. I think the idea of this vehicle came from your part of the Earth, didn't it? Well, I need windscreen scrapers for mine, and the local car guys are laughing at me. Of course, they're not laughing as hard as I am when I pass by the gasoline stations.
PoudreDerf is offline Find More Posts by PoudreDerf
Old Sep 01, 2005, 08:17 AM
FLYWINGFAN's Avatar
Minneapolis MN
Joined Sep 2002
Looks great Adrian, what do you have cooked up for a power system?
Sam
FLYWINGFAN is offline Find More Posts by FLYWINGFAN
Old Sep 01, 2005, 08:20 AM
designer/builder
madrob's Avatar
Kars, Ontario, Canada
Joined Apr 2004
Very cool Adrian!
I say go for the rounded wing tip! Looks a little more refined.
Rob
madrob is offline Find More Posts by madrob
Old Sep 01, 2005, 08:44 AM
Glenn
wellington53's Avatar
United States, WI, Oconto Falls
Joined Jan 2004
DoudreDerf, I've found something for you!!
http://cgi.ebay.com/MINI-CHROME-WIPE...QQcmdZViewItem
Glenn.
wellington53 is offline Find More Posts by wellington53
Old Sep 01, 2005, 09:20 AM
rtherbe's Avatar
Lancaster,PA
Joined Apr 2003
Nice. I like the three view, I have so many projects going, or I would build along. Maybe over the winter?? I still have the plans and wood set aside for the Daddy "O", so many planes so little time.
rtherbe is offline Find More Posts by rtherbe
Old Sep 01, 2005, 12:12 PM
Cardiff Wales UK
Joined Jun 2003
Have a Jenny on your Mini!
Look what a mess you've made of your roof by smashing it with choppers
It's got a Cooper grille - is it a Cooper? Quite valuable if so!
Anyway, thanks, you chappies
My digi batteries died so I have got quite a bit further than these pics.
The motor tube is from 1/32 sheet, edge joined and rolled around the 400 can. Once it's dry, it's easy to cut out the cooling holes. Then draw round it and cut out 3/32 sheet which will become the nose formers which carry it. A small piece of hardwood is to be bound and glued under it - drilled to accept a screw to lock the motor in position.
Most of my designs incorporate crutch and former structure. In this case I simply glued the 1/4 x 1/8 on to the sides, measured up the formers to give me the width for my 1500 3S lipo, and stuck 'em on!
I'll be back...
Ade
BTW How do I create a .pdf from a .dxf CAD drawing? Want to post A4 plans eventually.
Old Sep 01, 2005, 06:42 PM
an earth bound misfit, I
Basketcase's Avatar
St. Pete, Florida
Joined Sep 2001
Very nice Adrian.
It migh be your Brave Chicken and plane to take risks with but it still nicer and has more work in it than my best plane. I'd be too chicken to fly it except on perfect days, and then very conservatively.
Wayne
Basketcase is offline Find More Posts by Basketcase
Old Sep 01, 2005, 06:56 PM
It's been a while.
Daniel G's Avatar
Irvine, CA
Joined Jan 2005
http://www.rcgroups.com/forums/showt...highlight=pdf+
You've got a nice plane in the works.
Daniel G is offline Find More Posts by Daniel G
Old Sep 02, 2005, 01:48 AM
Cardiff Wales UK
Joined Jun 2003
Been Trying!
Thanks Daniel!
I promise not to crash it till it's flown a few yards!
I've been playing with .wmf here. The drawing bits then become A4 standard .doc and are simply opened and printed from Microsoft Word.
So here's that rib which should measure what it says. If this does not work, then I'll post .dxf in zips once I've drawn them up.
Ade
Old Sep 02, 2005, 05:45 AM
Cardiff Wales UK
Joined Jun 2003
Camera batteries charged!
Here there are a couple of simple formers designed "on-the-job" to be drawn later.
3/32 doublers are balsa cemented to the wing mount and nose areas.
Drew round the mount tube and roughed out an assembly. Trial and error fitting with 1 degree (about) side thrust. Then tack cyano in place, reinforce with PVA.
Next up the tail bits and controls.
I've opted now to make a removable wing instead of a top hatch.
Going to the Pub now
Ade
(ps RTHERBE - I do like that "Daddy -O"
Old Sep 02, 2005, 11:50 PM
Registered Snoozer
Ju388's Avatar
Huffman Texas
Joined Jun 2002
Love your Aircraft Carrier. REAL Mini's rock!
Ju388 is offline Find More Posts by Ju388
What Prop do you Like Best GWS or APC 2dogrc Power Systems 10 Oct 27, 2007 09:41 PM
Round nose or rectangular nose? Which do you like better? Jeremy Z Parkflyers 6 Dec 04, 2005 11:38 PM
Which came first T-Hawk or Aerobird Challenger? Which do you like better? Smokescreen38 Beginner Training Area (Aircraft-Electric) 7 Oct 26, 2005 02:13 PM
Do you like twin boom aircraft? Real OR Fantasy ones? Then, you will like this link! Thomas B Scale Electric Planes 3 Sep 05, 2005 01:26 PM
which one do you like better, the Zero or ME109? jeff262 GWS (Grand Wing Servo) 14 Feb 22, 2004 10:08 PM
