Espritmodel.com Heli Air
Old Aug 30, 2005, 05:02 PM
Carnifax's Avatar
Cleveland
Joined Jun 2002
Ace Simple 400 build thread
SO I finally got around to starting this plane. I had to put the Moutnain Models Hellcat off to the side but thats fine. I am going to explain as many steps as possible here so be patient if you have seen all this before.
The first thing you notice is the splashy graphics on the box. Cool. Open opening there is not really a whole lot to this plane. A few sticks of balsa and ply and some foam wings. The instructions are printed on the plans so read over them carefully before you begin. Also, try and think a few steps ahead to figure out how each step affects the next. For a building board, I am using an old door on two sawhorses with a sheet of foam core on top of that. Then I lay the plans down on that with wax paper over the plans (to protect the plans from the adhesives).
I took out all the parts and everything seems to be here. One thing I noticed is the parts are not labelled. Thats fine. If you read the instructions, everything seems to be pretty self explanatory. Also, the parts are die-cut and not laser cut. Thats fine too, they did a pretty nice job and the parts were east to seperate. Some people like to label the parts as they pull them off the plank but its not really necessary here as there are not THAT many parts.
Carnifax is offline Find More Posts by Carnifax
Old Aug 30, 2005, 05:32 PM
Carnifax's Avatar
Cleveland
Joined Jun 2002
SO the first step is to assemble the fuselage sides. There is a top, middle and bottom to the sides. You just line them up and then zap it with some thing CA. I try my best and stop the CA from "wicking" too much but I alwasy seem to wind up with a couple of spots under the piece Im glueing. Thats ok though, I will sand it a little before covering.
Old Aug 30, 2005, 05:35 PM
Carnifax's Avatar
Cleveland
Joined Jun 2002
At this point, the instructions request you to drill the motor mount for either gas or electric. Im going to go electric but since Im not sure of the motors mounting screw configuration, Im going to glue it in place and drill it when I get my grubby mitts on a motor. Anyway, there are only 2 formers that you glue in place. Of course these have to be 90 degrees to the fuselage sides.
Old Aug 30, 2005, 05:45 PM
Carnifax's Avatar
Cleveland
Joined Jun 2002
Next Im looking at the wing halves. There are little extrusion "dots" or points that have to be sanded off at some point. I think it might be just as easy to sand them when the wing is one piece. I tried to illustrate that in the pic. The next steo will be to glue the wings pieces together. I will do that tomorrow and also add a carbon fiber spar. I have to make a decision to go with a single or double aileron setup. Obviously you have to decide this before you cover it. I like the covering on the box but I like to be creative so I have to decide on a cover scheme.
Also looking forward, I think this plane would benefit from some cooling ports but I will do this a little down the road before covering.
A lot of the kit planes have a weak area near the wing saddles but this kit seems pretty beefy so I dont think I will do anything to reinforce. I try and think about weak areas on planes and build a fix into it while I can. I dont see too much other than the spar in the wing. I will do a little research here too before I get too much further. The instructions are a little hazy as to how to mount the wing. I have always hated the rubber band method but it has undoubtedly saved a wing or two in my day. The instructions reference both methods. Let me think about it.
Old Aug 30, 2005, 05:47 PM
one game away...
PerfectStranger's Avatar
Willoughby, Ohio
Joined Apr 2004
very nice.
ma
PerfectStranger is offline Find More Posts by PerfectStranger
Old Aug 30, 2005, 07:31 PM
Lazy dog
OhioPete's Avatar
Lakewood, Ohio
Joined May 2005
Great write up so far. I'm sure I'll be referring to it soon.
OhioPete is offline Find More Posts by OhioPete
Old Aug 30, 2005, 07:34 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Sounds like we can have a pylon race now!
The Don is offline Find More Posts by The Don
Old Aug 30, 2005, 08:06 PM
Brunswick, Ohio
BrunswickOH's Avatar
Joined Aug 2003
I may have to order one myself!!
BrunswickOH is offline Find More Posts by BrunswickOH
Old Aug 30, 2005, 08:16 PM
Mentor, OH
Joined Dec 2004
ahhh. geez....i know i'll get corralled into ordering one too.
your making it look almost to easy.
sgtdirt is offline Find More Posts by sgtdirt
Reply With Quote  (Disabled)
Old Aug 31, 2005, 05:53 PM
one game away...
Willoughby, Ohio
Joined Apr 2004
dan
which power setup are you going with. let me know so we can be on the same page. i do have a cc pixiie20 laying around so i'm good on the esc. i guess it's just motor and batts.
matt
Old Sep 01, 2005, 09:50 AM
Carnifax's Avatar
Cleveland
Joined Jun 2002
I am going to use a graupner brand speed 400 6volt motor. These are more or less the industry standard for this class of airplane. Many people distribute speed 400 motors. HobbyTown Strongsville has some under the GreatPlanes name. I would be interested in seeing some comparisons in various motors. I will search here and post the results.
After kayaking last night, I did a little more building. Let me download tha camera and post the pics.
Old Sep 02, 2005, 09:50 AM
Carnifax's Avatar
Cleveland
Joined Jun 2002
More build
Busy week, back to building. When we last spoke we had the basic fuselage side together. After aligning the tail, I glued that. As a modeler, we sometimes have to get creative to solve problems. This is not a huge creative solution but I found that a little tape measure works well as a 90 degree block to glue the front face on. I was using thin CA but that didnt seem to hold very well. I then put thick CA to reinforce. I am on the fence on using CA for this application. I have found that CA sometimes can break under stress and vibration but I am going to gamble on it.
Old Sep 02, 2005, 09:54 AM
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
carnifax, just leave the tail end open and stick the pushrod straight out, no holes in the fuse side and since the elevator is one piece with no rudder interferance it works really well.
Simple build eh? Fantastic airplane.
pda4you is online now Find More Posts by pda4you
Old Sep 02, 2005, 10:07 AM
Carnifax's Avatar
Cleveland
Joined Jun 2002
I thought about keeping the back open. Thats a very good idea especially if you plan on going brushless and need the cooling. For now, Im trying to build stock for now and mod it after (or 2nd kit). Thanks for the tip, anything else you can add would be appreciated.
Discussion Ace Simple 400 - Build the wing stock? Tram High Performance 8 Jul 22, 2006 02:48 PM
Ace Simple 400 build thread, pics, or advice Mac8 High Performance 7 Aug 09, 2004 03:06 PM
19-20 oz Ace Simple 400 jnyoun High Performance 4 Jun 05, 2001 08:37 PM
My ace simple 400 pictures jnyoun High Performance 7 Jun 02, 2001 11:36 AM
ACE SIMPLE 400 modification ? jnyoun High Performance 7 May 31, 2001 11:10 AM
