Old Aug 30, 2005, 12:19 PM
hb888 is offline
Find More Posts by hb888
Monmouth UK
DIY Blade balancer
Cost 50p
hb888 is offline Find More Posts by hb888
Old Aug 30, 2005, 07:35 PM
Eeeeky is offline
Find More Posts by Eeeeky
Eeeeky's Avatar
Roosevelt UT
good idea dude!!!!!!thank you now i can balance the little !@#$%
Eeeeky is offline Find More Posts by Eeeeky
Old Aug 31, 2005, 02:39 AM
ChRiS OnG is offline
Find More Posts by ChRiS OnG
Heli Newbie!
singapore
Joined Jun 2005
do u have to put both blades wif the leading edge facing up
OR
one facing up and the other's leading edge facing down?
ChRiS OnG is offline Find More Posts by ChRiS OnG
Old Aug 31, 2005, 02:50 AM
hb888 is offline
Monmouth UK
Hi Chris,
I placed the leading edge of both blades facing down as this was the wider than the trailing edge and so I could line it up on the table surface to ensure both blades were horizontal before tightening up the nut and bolt in the middle.
Old Aug 31, 2005, 07:29 AM
Heli Newbie!
singapore
Joined Jun 2005
ok thnkx!
Old Aug 31, 2005, 07:39 AM
HoverDown3K is offline
Find More Posts by HoverDown3K
Vampyre Inc
HoverDown3K's Avatar
Rochester, New York
Joined Nov 2004
Great Idea!!! I am making one!
You can paint or use marker to color the credit cards, it will give it a more finished
look.
Well Done!
HoverDown3K is offline Find More Posts by HoverDown3K
Old Aug 31, 2005, 07:58 AM
kwikee is offline
Find More Posts by kwikee
Heli-addicted
Melbourne, Australia
Joined May 2005
This is only half of the balancing equation, though. Both blades need to have the same Centre of Gravity, or it doesn't work. To c of g the blades, hold a blade of some sort (ie knife) on edge and lay the blade across it, moving it along until it balances. Mark this point on the blade. Do the same to the other one. Compare the marks. If they are not equal, add weight (tape of some sort) to the tip of a blade to move the c of g out, or near the root to move it in. When they are equal, balance as per the pics, and add weight to the lighter blade at its c of g. They are now static balanced. Bear in mind that static and dynamic balance are not always the same, but are usually near enough for us!
Cheers
James
kwikee is offline Find More Posts by kwikee
Old Aug 31, 2005, 08:02 AM
Vampyre Inc
Rochester, New York
Joined Nov 2004
Originally Posted by kwikee
This is only half of the balancing equation.....
Cheers
James
Yes 100% agree that is only 1/2 the balacing act!, for more info or a picture of what Kwikee is talking about check out this link.
http://www.helihobby.com/html/balancing_blades.html
Old Aug 31, 2005, 08:32 AM
hb888 is offline
Monmouth UK
Yes correct about the process. I'm following the guide on www.trextuning.com.
The other modification I made to the process was to bluetac the kitchen knife to the table with the handle hanging off the table in order to get the knife blade truly vertical. The yellow plastic rotor blades tended to slip off the knife edge very easily if it was not 100% vertical.
Old Aug 31, 2005, 09:41 AM
Beige is online now
Find More Posts by Beige
Got my ears on
Beige's Avatar
England (oxfordshire)
Joined Sep 2001
My hi-tech approach...
2 cans of custard, on a nice level surface (checked with a level) bit of piano wire and a couple of collets
And i stick a bit of thin alu in a vice to get the CoG
Beige is online now Find More Posts by Beige
Old Aug 31, 2005, 11:55 AM
thanhTran is offline
Find More Posts by thanhTran
That tree again!!!!
thanhTran's Avatar
Germantown, MD, US
Joined Sep 2004
...To c of g the blades, hold a blade of some sort (ie knife) on edge and lay the blade across it, moving it along until it balances. Mark this point on the blade. Do the same to the other one. Compare the marks. ...
I followed this method from advices from one of the fellow members here. I found it's hard to find a perfect CG for the blade. When doing it on the knife (hold by a vice), I found that if I move the blade just a little, the blade tilt to one side. Move back just a little, the blade tilted the other side. I can't never find a position that the blade can balance by itself on the knife. I could only find a position that the blade seems to balance because it changes its level slower than other position. How do you work around this? I.e Are you able to set the blade level on the knife by itself? Without a perfect CG, I found most of the blades coming out from manufacture have identical cg, but they are not really smooth.
thanh
thanhTran is offline Find More Posts by thanhTran
Old Aug 31, 2005, 07:39 PM
Santini is offline
Find More Posts by Santini
The Great Santini
Santini's Avatar
Madison, NJ 07940
Joined Dec 2004
I find the cog using a razor blade taped to the corner of a tape measure placed on its side. The edge of the which gives a good guide to make sure the blade is perpendicular to the blade. It is very low to the table, so my hands are steadied on the table and I use my index fingers to move the blade around.
Sure, it takes some trial and error, but a razor is a bit "grippy", so I am able to lift and move the blade a smidge at a time until it hangs there for a few seconds or more and does not appear to a have bias to teeter either way. That is where I mark the blade. I get really good results every time and after a little practice it only takes a few minutes to mark the blades and complete this part of the balancing.
Santini is offline Find More Posts by Santini
Old Aug 31, 2005, 08:09 PM
Tonystott is offline
Find More Posts by Tonystott
Its all fun
Tonystott's Avatar
Australia, NSW, Forster
Can someone please send me a couple of their credit cars so I can do this too?
Tonystott is offline Find More Posts by Tonystott
Old Oct 01, 2005, 04:03 PM
Johnny B is offline
Find More Posts by Johnny B
Kentucky
Joined Dec 2003
Good to know.
Johnny B is offline Find More Posts by Johnny B
Old Oct 01, 2005, 10:29 PM
That tree again!!!!
thanhTran's Avatar
Germantown, MD, US
Joined Sep 2004
It takes me about 3 - 4 mins each blade to decide which point is better for the CG to mark the line. I wonder if the professionally made balancer would allow us to balance the blade faster? Anyone has any experience?
thanh
helicopter blade balancer xxcysxx Electric Heli Talk 19 Mar 08, 2007 06:01 PM
KSJ Blade Balancer Question Orion_V Electric Heli Talk 19 May 08, 2005 09:39 PM
K&S Blade Balancer w/ Corona Blades Shiba Electric Heli Talk 2 Feb 24, 2004 12:37 PM
homemade simple Corona blade balancer Tom Cardiff Electric Heli Talk 9 Nov 08, 2003 10:49 AM
KSJ-528 blade balancer mod TMorita Electric Heli Talk 1 Jan 26, 2003 05:34 AM
